cwr
Everything posted by cwr
Hi folks Any recommendations for a supplier of corrugated roof sheeting in NI? I'm after rolled material for a curved roof for a workshop/garage, the likes of 13/3. Thanks
Thoughts on Different Brands of Unvented Cylinders
cwr replied to steveoelliott's topic in General Plumbing
You were lucky. I tried that 3 years ago, but no discount. Wasn't a great experience to be honest, and looks like i need need to go back to them as one of the cylinders appears to be leaking... -
A Shelly relay will allow remote (via app) control as well as a switch in the cottage for people there to use, it won't prevent a simple switch being used as well.
Anyone tried to re-calibrate a Huepar laser level? Mine had a bit of a fall resulting in it being out by a couple of mm per m. Couldn't find anything on t'internet other than only the manufacturer can calibrate, and looking inside it after disassembly there is nothing terribly obvious to make fine adjustments. So, feeling I'd nothing to loose I had a go with some hot glue to rebalance it, carefully applying blobs to the 'high' side. Manged to get it within 1mm at 7m, which will do well enough for what I need. Perhaps there is a proper way to do this, rather than my bodge...
Thanks for the suggestion. I phoned around a few places. Macblair have gypsum products, but just the rolls. Jp Corry do Siniat but also just carry the rolls. I did however manage to get something suitable today. It's a plastic unequal angle with paper bonded to it. Apparently hardly anyone buys it now and I was lucky to get it. Just put it on and really pleased with it so fat. Nice and straight, easy to fill around.
This Siniat GTEC stuff looks gd, tho I'm still to find somewhere in NI that sells it, or an equivalen. Any suggestions? Presumably it would be better than the rolls that have two strips of metal, but at at least I can get them online.
Can you get ones for fill and sand? I've seen some at 2 or 3 mm but surely they're for wet plater as would stick out too far? Unless possibly along the tapered edge but I can't always arrange that.
Hi folks Any advice on best method of doing external plasterboarded corners with tape/fill/sand? I've used paper tape before and the results were aesthetically good, but was very susceptible to chipping. Is the paper tape with a metal film good, or is there a more robust solution out there (that's not wet plastering)? Thanks
Hi folks With a floor slab for a garage / outbuilding to be poured next week I'm looking at bull floats. There appear to be different sizes available, 1200 x 300, 1200 x 200, 900 x 200, etc. Any advice on a good size to use on a 10m x 5m floor slab, or is it as much personal preference? Thanks
Hi folks Does anyone know, does the polypipe UG427 back inlet bottle gully come with a trap? In photos I find online it doesn't look like it, which seems strange? Thanks
Having a read through the relevant pages of the pavingexpert.com website would be a good starting point, if you haven't already. I was going to post a link, but can't seem to get onto that site right now for some reason...
Wasn't until I did this that I realised just green it had got in only 3 years!
Just report back, I looked for algon but our local place had patio magic so trued that. Did a test area and was very impressed with the results. 5l diluted as per the instructions applied with a weed sprayer did the whole house. The photo shows the test area after 3 days.
Hi folks I've couple of garden walls built from concrete block to render, and would like them to match the house. The house (also concrete block) I believe was done with the following, and appears to be a good job. Weberend aid Weberend MPR Weber PR310 Webersil TF There is a good bit of Weberend MPR left over, but I am wondering if the Weberend aid and PR310 are really necessary for an 800mm high garden wall? I guess a lot of folks would just sand/cement render and paint, but I have the MPR and want to match the house. Thanks
Thanks for the replies and suggestions. I had tried diluted bleach but it had no effect, it may have been too weak a mix though.
Hi folks Any recommendations for something to spray on render to get rid of green algae? It's a white thin coat Weber render. Plenty of trees near by so guess I'll be doing this every couple of years... Thanks
I'd guess that water sitting behind the wall is not great. Some info on this page may be useful if you've not already seen it. Scroll down a good bit to get to retaining walls. https://www.pavingexpert.com/featur03
I think I would go 'A', as I think it would suit the room shapes and also be continuous between rooms with no joins. But that's just my take, others may prefer other approaches. We had herringbone continuous through several rooms, aligned it centrally in the biggest room, and the rest were dictated by that. More than happy with it. Why don't you get a few boxes and lay some and play about with it?
Yes, but at cost. (I'm really watching the pennies now...) On the last stairs I did I bought lengths of planed whitewood and cut to length as I needed over 900mm, and then bought 900mm spindles for the landing. Wre v similar cost. The 'proper' spindles had a much better surface finish, edges better and less knots.
Hi folks, Could anyone suggest somewhere to get 41mm plain square stair spindles in northern ireland, that are 1100mm long? Primed or unprimed. Anywhere local I've tried only do 900mm long, and can't find any mainland GB suppliers that would send over to NI. Thanks
vent-axia sentinel wired remote
cwr replied to Ajm's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I have had exactly the same issue. We have 2 vent axia's. On one the display was not great but worked, the other did not show anything. By swapping the controls over i was able to show the control was not the issue. I went back to the supplier who sent me a new main control pcb, having it swapped has helped. Its still the case though that neither are particularly impressive. Mine do not appear to have back lights, which would have been helpful. -
Practicalities of Static on site
cwr replied to Post and beam's topic in General Self Build & DIY Discussion
If you can get or build a small shelter or shed for the washing machine you'll likely be glad of it. It would take up valuable space and produce noise in a caravan. I can't think of a reason that 100ft would be a problem for water or electric, assuming the wires/pipes are suitable spec'd and installed. We were about 80m away, which was good. Wouldn't want to be really close, but depends on the site etc. Big lorries, diggers, things falling off scaffolding need to be considered. And if you have kids, that's another factor. -
Thinking about this again, and looking at the 'panels, battery, inverter, AC heating element' option. If I get four panels around 400w each, would this inverter be suitable? https://www.cityplumbing.co.uk/p/solax-power-x-1-1-0-7kw-single-phase-inverter-1-x-mppt-inc-dc-switch-x-1-0-7/p/628024 And what size of battery would be recommended? Bearing in mind the battery is only to smooth out, not be used as a storage device.
Ended up pretty much as per the drawing above, except with 100mm pir, and osb instead of ply. We also went for Rationel aluclad frames instead of pvc. Standard concrete cills, though might have been better with ones with a narrower part for the window to sit on.
Beefy ridge beam check and plan to reduce size
cwr replied to NandM's topic in RSJs, Lintels & Steelwork
Out of curiosity I asked my SE why he'd spec'd a UC for a horizontal beam and not a deeper lighter UB. He said due to torsional buckling. Slightly different situation as was supporting a wall, but no doubt you SE will have a justification for the choice.
