Dillsue
    1
Everything posted by Dillsue
  1. Great and keep it that way until you've done a full QA check. I have an inkling that if you complain to MCS they'll send someone out to have a look
  2. Using 0.504 gives a dT50 equivalent 2530 watts radiator for bed 2 with the rad fitted seemingly around 2100 watts output. Given the gain/loss from the room below wasn't accounted for and some rads might not be positioned optimally, I think I'd be tempted to revisit all the heat loss calcs and verify rad sizing at least meets the heat loss. What you do now will likely be in place for decades and if you're upping flow temps to deal with undersized rads, you've potentially got decades of throttled COP!!
  3. From stelrad tables a 600x1200 k2/type 22 puts out about 2100watts at dT50. That's a bit short of the calculated loss so how's things in the real world..... does that rad keep the room up to temp when it's freezing outside??
  4. Having just bought a Leaf I'm intrigued to know how you've done the V2H interface. Have you been on one of the trials or via another route??
  5. After a look at Stelrads conversion factors I think to get the rad size the table needs rejigging to divide the heat loss by the conversion factor. Your bed 2 would need a rad size of 1276/0.396= 3222 Watts at the standard dT 50. Is that roughly what you ended up with??
  6. Not sure that applies to optimisers?? Certainly our Solaredge units run cool. Is the MCS guidance in respect of micro inverters and optimisers or just inverters??
  7. The table has fixed rad sizes(existing??) showing the output at various flow temps to guide on choosing the minimum flow temp. I'm working on fixed flow temp/heat loss with a calculation to show dT50 equivalent rad output for running at 35c. I'm wanting to keep flow temps low to get a good COP so it's the rad size I'm interested in rather than the flow temp needed for a preset rad size. For your bedroom 2 the rad output shown falls way below the heat loss. Are you running like that??
  8. So it's not a case of "you're not allowed" to install optimisers in the roof space, it's only an MCS requirement/guideline not to.
  9. Did you do heat loss calcs for each room to size the rads and factor in the the massive reduction in output for low temp flow?? I'm working my way through all our rooms/rads just now to resize everything for 35 degree flow and intrigued to know the approach you took??
  10. Is that a statutory requirement, manufacturer guidance or word on the street??
  11. I think the general guidelines are for on roof mounting where there's plenty of opportunity for the wind to get under the panels the nearer to the edge of the roof they are. If it's an in roof install then I guess its the detail of how the mounting trays are fixed on the edge of the roof??
  12. Have a look at PVGIS to see what youre likely to get year round. You can get figures by the hour/day/month etc so should give you something meaningful to crunch your figures with
  13. Does the BUS grant even apply to new builds?? Isn't it for replacing fossil fuelled heating.
  14. With our DNO I just put self installed and all went through OK. You're not bound to use the installer on the form so you can just put down any company you want and change the installer later on.....perfectly legit to change installer any time you want.
  15. An MCS install covers structural assessment of your roof so not just electrical work
  16. There's an awful lot of clever people advising governments around the world that climate change can be slowed then stopped then reversed, to some degree. The full ramifications of climate change, or more accurately climate unpredictability, won't be known until they happen but it's a massive risk to leave it to happen and "best deal with it" after it's happened. How would you forsee we deal with this- global population is forecast to peak at 10 billion, 2 billion more than current. African population is forecast to grow by 1 billion in a continent not known to be able to always feed itsself. Let's say future unpredictable weather events trigger half a billion Africans to go on the march looking for food. How do you see the global community dealing with that? The farmer at the back of us told me last year he'd lost circa £60k of root veg and winter wheat in the last few years due to flooding. Looking at the areas that were flooded I'd guess at 20% of his land was under water for a prolonged period. There's around half of an 80 acre field of carrots still in the ground at the back of us that got left when the field partly flooded at the end of November. It's all looking pretty dead now but I don't know if they'll be salvageable if it dries out. This winter Our plot has been the wettest it's been in the 24 years we've been here so I don't see the farmers rate of flooding getting anything other than worse than it is now. How do you see the global farming community dealing with increasingly destructive weather events? You're correct in assuming I believe that if everyone did their we can manage climate change. You, me and everyone in the first world caused the problem so we need to all do our bit to sort it out
  17. It's mentioned often enough that dealing with climate change is going to come at enormous cost and that is undoubtedly going to change our way of life. If everyone engaged with it, the cost will be less. To resist is only growing the problem and pushing the problem onto future generations which is a very selfish thing to do.
  18. Maybe Labour have a cunning plan but the BEIS think differently https://www.gov.uk/government/publications/energy-and-emissions-projections-2023-to-2050
  19. Octopus do heat pumps from £500. If you look at any deprived area via Google earth the roads are rammed with cars and vans each of which will fairly likely cost more than £500 to keep on the road. I'd be fairly certain that eco grants/zero interest loans are available for those struggling to find £500 It's all about choices and very few people give a toss about climate change so the right choices aren't being made.
  20. My lad lives in S Korea and all the services in his block of flats are individually metered incl hot water. All managed centrally within the block and distributed to all the flats. All tried and tested as its the norm over there and I guess lots of other countries
  21. For anyone thinking we're heading to electricity being from 100% renewables and the end of gas you probably want to look at gov forecasts here https://www.gov.uk/government/publications/energy-and-emissions-projections-2023-to-2050 section 4. A couple of years ago, gov forecasts showed 14% natural gas generation in 2050, presumably with carbon capture, if they can get it to work.
  22. The 10 panels we have on the ground are on a 2x1" roof batten frame sat on 9" hollow concrete blocks half buried in the ground end on. Strategically placed strips of damp course keep any rain off the timber where it comes through the gaps between panels. It's bone dry and on its 3rd winter so seems to be holding up.
  23. If you're considering space heating backup then a fan heater may well give you alot more resilience than an immersion
  24. Any inverter thats supports export limitation will have an energy meter/CT clamp to monitor how much is going to the grid and throttle output if there's too much being exported. You can have whatever size inverter you want so long as it is certified to G100 for export limitation.... that's what G100 is for.
  25. Octopus Outgoing pays 15p/kwh so seemingly triple what youre getting now. Worth the faff for over a grand a year??
