Dillsue
    1
Everything posted by Dillsue
  1. I think that to do what the OP is doing you'd need a few extra bits and bobs off the roof to get the same functionality with micro inverters. The thing to be conscious of with anything active up on the roof is replacement if they go wrong. I don't know what the failure rate is of micro inverters but we're waiting delivery of the 3rd failed optimiser from one of our systems. They come with a 25yr guarantee but that's not an indication of how long they'll last, just means we get the part free. Fortunately I have the kit to replace them so it's just my time to put up a scaffold tower but if you have to pay someone to change them it can be £100s
  2. Google "Ofgem fit guidance" and youll find- https://www.ofgem.gov.uk/publications/feed-tariffs-guidance-licensed-electricity-suppliers And- https://www.ofgem.gov.uk/publications/feed-tariffs-guidance-fit-generators
  3. The FIT rules changed in December 21 to allow alterations and batteries so make sure you find the version dated then or later
  4. Read the FIT rules!! Your config is likely allowable with a new bidirectional meter doing net metering. Anything drawn from the grid and put into batteries is deducted from energy flow to the house/grid giving a net reading of what was generated from solar. It's all covered in the FIT generator rules and/or guidance docs from Ofgem. Don't expect or trust that BG staff will understand the finer details so you could well have a bit of an uphill struggle but you'll get paid in the end if you know and stick to the rules. There's also a guidance doc for FIT payers(BG) detailing how they should manage you so that's worth a read of the sections covering what you want to do. Have fun!
  5. Great that you got your 8kw export. If you've not already done it have a read of the FIT rules re system extensions so you get all the total and net installed capacities correct
  6. That's a G100 concept doc. Have you checked the ENA type test register for a compliance cert as a previous post reckoned Victron weren't going through certification?? Is it a G99 application you made to your DNO rather than a "notification"?
  7. SEG is the government's successor to FIT and is regulated and must be paid if you apply with a qualifying system. Outside of SEG, Octopus and maybe others can buy your surplus on a Power Purchase Agreement(PPA) which is an unregulated contract between you and them. Octopus offer both a PPA and SEG but no point in going for SEG when you can get much more on their Fixed or Agile Outgoing tariff
  8. Title is "help with first solar PV system". Bit confusing when you're actually expanding an existing system! The answer to your question about getting paid for FIT generation and separately paid for metered export on a PPA, is yes you can. We do exactly that. Scottish Power pay the FIT generation on our 4kw FIT system and Octopus pay the 15p/unit on the export from the total 12kw we have. You can only change between metered and deemed payments once every 12 months. If your extending your FIT system to 8kw you'll only get FIT payments on the original registered capacity of 2kw so as you say you'll get paid on 25% of what goes through the generation meter
  9. The FIT scheme ended in 2019. If you mean SEG, last time I looked that generally pays a pittance- Octopuses 15p rate isn't SEG, it's a power purchase agreement that Octopus offer, can end anytime, and doesn't carry any government backing which SEG has, hence the G on the end
  10. If you can't get consent for 8kw then you wont(shouldn't)get approval as your inverter eemingly doesn't have G100 certification to limit export below 8kw. Anything with more than 3.68kw rating and your DNO should always be your first port of call. Your MCS installer shouldn't power up, commission and certify for you without DNO consent. I'd speak to your DNO ASAP and hope you can blag 8kw.
  11. AFAIK you need the system designed and commissioned by an MCS certified outfit to get the grant.
  12. Up until the last few days we'd had 1 day of rain in the last 2 months.....witness the wildfires we've been seeing in the media. The nearest reservoir to us is only half full as we come out of winter. Might be worth being a bit conservative with something we really don't want to run short of??
  13. Just a heads up for what they may offer. Our detailed heat loss cals show a heat loss of 6.5kw at -2. This winter when it was zero outside, we maintained house temp around 19/20 degrees with 4kw of fan heaters running so I'm quite confident the calculated loss is fairly representative at 6.5kw Seeing the Coolenergy offer of a free kit of parts with me sorting the installation I made an enquiry and fell off my chair when they quoted for an 18kw unit. The 18kw unit won't even modulate down to my max heat loss so will spend its life short cycling and putting a significant dent in my bank account. When I shared my detailed calcs with them they stopped talking to me! By all means go down the Coolenergy route but get your heat loss worked out by someone else and don't accept a massively oversized heat pump
  14. Maybe wait till you've agreed an export limit before you decide on the kit you'll use??
  15. Assuming your roof is in fair condition and doesn't need reroofing anyway, there's lots of videos on YouTube showing roof hook installation on slate roofs without a complete strip and relay. I'd be tempted to use an experienced slate roofer to fit the hooks rather than a PV installer, unless they employ a good roofer themselves. Let the PV installer fit rails, panels, wiring etc
  16. Totally agree on the MCS pricing but just giving you the heads up on export constraints. I beleive Octopus also want to see building control sign off so there's another cost to add to the Octopus fee.
  17. Octopus do accept self installed systems but there's hoops to jump through and £ to pay! Have a search on here for discussion but I think consensus seems to be it's typically not worthwhile to bag an export tariff that can be withdrawn at any time.
  18. You mention profit from export. Currently you generally need an MCS certified installer to get paid for export so you may want to get your installer involved in the design/spec to get their buy in.
  19. You don't need to hunt for the rafters as there will be screws/nails in the battens which hold the batten onto the rafters. These will show you the position of the rafters for you to fit the roof hooks. I'd check your battens and slates have been fitted correctly as there's usually space between the top of the felt and underside of the battens to allow ventilation/water run off. Im no roofer but AFAIK the felt usually sags between rafters to form this space or if there's boards below the felt, counter battens are used. If that needs changing get it done before you fit the panels and get the roof hooks fitted while the slates are being laid.
  20. If you're running weather compensation on the heat pump and it's been set up correctly, why do you need Wiser TRVs connected to the heat pump?? The WC should take care of individual room temps via balanced flow through the rads. Connecting the Wiser system to the boiler will control the house temp when the HP tells the boiler to run. If there's a valid reason for the HP to have a signal from the Wiser system then install a relay, as Sharpener suggested. With a 2 pole relay in place the Wiser system will switch the relay and separate contacts from the relay will separately switch the HP and boiler enable/call for heat signals. What has your installer said about the boiler overheating the house??
  21. If you're not sure on the config you want/need, get yourself a secondhand inverter off ebay to get the panels up and running. No pressure to make uninformed decisions and fair chance youll be able to sell it again when you know what you want.
  22. A concept often missed in our quick/cheap fix world
  23. Shouldn't be a problem with the right sized pipes. Remember that your not pumping up to the loft but circulating up there and back down again. The flow up to the loft will be working against gravity but the return back down to ground floor will be working with gravity and the two gravitational "resistances" cancel each other out. All your circulation pump needs to overcome is the restistance of the pipe work and fittings
  24. I know for a fact that at least one DNO has accepted self installed and N/A for qualifications on both G98 and G99 commissioning docs. G98 is a notification and I truly belive any DNO will appreciate receiving them regardless of the installers details
  25. That's good going. I played email ping pong for a few days, then they asked for the detailed calcs which I sent them and they never replied.
