matt-shrops
Everything posted by matt-shrops
brought mine from Hyt-ten in Wolverhampton. Cheapest I could find and delivered.
@ProDave where did you buy your woodfibre board from - I have had a look at SIG and don't think sell it, well not yet! 100mm stuff must be expensive but guess you saved using frametherm rather than warm cell?
Thanks @Big Jimbo, 600 centres with 300mm I Joists.
@Big Jimbo can I ask where did you get the rockwool from and what type was it? Were they any problems fitting it around the flanges of the IJoists. I have come to a similar conclusion as yourself- Warmcell for the roof and DIY for the walls. Trying to workout the best solution for the walls but have time to think as they are not up yet!
How much was the vapour shield OSB and any prices for wood fibre board? I have been looking and for 50mm woodfibre board it is around 4 times the price of OSB3.
that looks good stuff! Will try to find out how much it is.
Getting close to putting the sole plate down. Trying to work out the best method. 300mm I joists will sit on the sole plate. The sole plate is 150mm on the concrete slab and 150mm on the perimeter XPS insulation. Couple of details I am unsure off! 1. the level of the concrete and XPS differs by a few mm in places- what is the best way to ensure this is sealed and insulated? Have thought about something like compriband to seal it. 2 DPM- where is the best place to fix it. I have a DPM that the XPS sits on and comes up the outside of the XPS and I used a DPM under the concrete slab that comes up the inside of the XPS. Do I need a DPC under the sole plate as well? The sole plate will be 49mm LVL possibly sitting on 36 x 89 treated timber with insulation in the gap. Thanks Matt
Good morning all. After a busy few weeks I now have the 260mm of insulation down ready for the reinforcing mesh and bars then the concrete pour a week on monday. To stop the insulation upstand from moving and while the concrete is poured I am considering moving some soil or stones against it. The DPM will be wrapped around the insulation. What is the best material to use to protect the DPM and insulation from the soil/stone? I have wondered about paving slabs, or some sort of weather proof board? Ideally once down in will remain in place! And is there a better method of keeping the insulation upstand (200mmx200mm) in place ? It will be stuck down using low expansion foam. I will upload some photos of my work so far! Many thanks!!
Evening All, I have ordered Jackodur XPS PLUS 260mm which will have a 200mmx 200mm upstand foam glued on.
I have looked at Nulok to- also not far from Birmingham so might follow in your footsteps !
Mine is 115m2 with 47m of upstand. Quotes below: Polarwall Atlas System (U 0.10) £7855. DIY (cut and glue) (U 0.95) £5370 but with "shaped" boards Kingspan DIY (U.10) around £6000 depending on supplier Fibran XPS DIY (u.10) £4680 ISOQUICK (U.09) £8053 (u.11) £6886 Styrodur DIY (U.10) £4628 DOW Floormate DIY(U.10) £6306 Stylite 300EPS DIY (u.10) £3962 Jackodur Plus DIY (U.95) £3792 AFT System (EPS) (U.10) £8082 All prices plus VAT(reclaimable)
oh, did you have the ATLAS system ? Looks very good but unfortunately about 2K more expensive than cutting and glueing the upstand.
Polar Quote was OK- £140 m3 for the Jackodur Plus board which has an excellent value of 0.027. Also found Jackon UK that has given good quotes on Jackodur XPS to. Insulation4less have Fibran XPS at a similar price to- 100mm at £12.50m2
Unfortunately Insulation superstore have suddenly increased their price from £69.90 a pack to £141 a pack... blaming a price increase from the supplier. Back to the drawing board!
did you buy anyXPS Plus?
- 1 reply
- insulation
- underfloor
Evening all, Had a very (very!) good quote from @PeterW advice- thanks. However, what is the best product to use XPS or EPS or do they perform equally under a slab?
Thanks, I am in contact with polar wall, he is sending prices tomorrow.
Afternoon, My house has started- I have dug the hole and it has been inspected by BC. I need to order the insulation for under the slab this week. I have had around 10 quotes for EPS and XPS. The SE has said I need 300kpa which makes EPS very expensive. The cheapest XPS 300kkpa I could find comes from Germany and is about 1.5K cheaper than ones made in the UK?-DOW, Kingspan. Polyfoam. Plus a few others imported-Fibran, BASF. I contacted some of the manufactures but the all refused to sell to me and directed me to a distributer with their markup! Seems crazy to me and the Kingspan Factory is an hour away! The base will be have be U.10 and I will be cutting the gluing(or foaming) the 200mm upstand as this was by far the cheaper option. comes in at about £30.20m2 and £320 for the 200mmx200mm upstand (47m) Anyone found a good price/supplier? Cheers Matt
I noticed you used XPS in your photos. The slab looks very level! That is very similar to how I was thinking of doing the concrete.Was he on his own?
Just about to start on my slab... any tips? I am planning to use Jackodur XPS for the insulation as it works cheaper than EPS. I am worried about getting the slab level and smooth!
New entrance over council Verge
matt-shrops replied to matt-shrops's topic in Party Wall & Property Legal Issues
@Jml Thanks will follow that up tomorrow with the council here- hopefully as straightforward as yours was! -
Anyone had any experience of crossing council owned verge to access the road? I have planning permission to build a house and make an entrance onto the road but this will mean crossing over the verge-approx 1 metre deep by 8m long. I have emailed the council for advice but no response yet. Any ideas of the best way to get things moving? Thanks Matt
Moira- Good looking windows- who did you use? Cheers
Moira- looking great! I have visited PYC including their new factory in Welshpool. Unfortunately their quote was the most expensive. @ProDave- sorry I did not explain properly- my stud wall will go to the outside of the oak frame, essentially a separate structure (but will be tied in). I am looking at smartply passive OSB or a similar product for the internal air barrier. MBC quote was a competitive quote from the ones I had but still expensive and did not include the slab (20k). Matt
Evening all. Thanks for your comments. I understand that I am potentialy doubling up by having an oak frame and then a stud wall. However the oak frame was was a very good price (built reasonably locally) and I have time at the moment to give to the stud wall. I have had a good quote for warm cell and will act as labourer to save a few more ££. The MBC frame quote has gone up by about £20k in about a year. Otherwise I might of gone that route. Understand it is the attention to detail that will determine the overall airtightness. However it is going to be my house so I am prepared to spend extra time on airtightness and details. I am just in Shropshire, so no sprinkler system required and CIL exempt which was remarkably easy to apply for. Cheers Matt
