Everything posted by Roger440
SketchUp fantasy Garage. Drawings for building control
Roger440 replied to Russdl's topic in Garages & Workshops
What ewas the reason for the foma glass? Ive used it , so am familiar with it, just not sure why in a new build garage? When i did mine, i created an insulated bucket of EPS to put the concrete in, so like yours an insulated slab.- 27 replies
- detached garage
- structural engineer
Having used seconds and co a couple of times, the stock i bought showed no discernable issues aside from the odd chipped corner. Id have no hestitation doing so for something like this. For both layers.
Detached garage, thermally broken entrance.
Interesting approach (get it!!) I failed to come up with a solution on the garage i built at my first house, and so had that big thermal bridge. Was never happy with that. -
Or hardcore/stone (thickness dependant on ground) with sand blinding. 150mm PIR, 100mm concrete. Even less digging. Only negative if you can call it that is slower response time on heating. Worked fine for me in an old house with uninsulated walls. It just sat at a constant temp all winter. Without knowing the foundations situation less digging = better in my world.
Light refurb/renovation & building regs
Roger440 replied to Roger440's topic in Building Regulations
Agreed The work signed off in my case, was, afterall, done by the developer not the BCO But it was signed off by the enforcers of said regs. At best it was gross negligence, maybe corruption, but i cant prove that. I guess my biggest issue is that there is no comeback on the inspector. They cannot be held responsible for anything, unless you have extremely deep pockets.. Which is of course why we are where we are with the latest round of changes. And why i question the value of the process and the certificate. In my case it wasnt worth the value of the paper it was printed on. Anyway, this is largely a diversion -
Ok, heres some crude sketches of my plans as they stand at the moment. As you will see, the back of the house is cavity wall, not solid. Ive not worried about this too much at moment as this is a bit more conventional, though still going round in circles re EPS beards. The insulation system referred to is: https://woodfibre.co.uk/internal-wall-insulation-iwi-28-w.asp Hopefully its mostly self explanatory? Any comments welcome. -
I think you may have taken that out of context a touch. If im going to do something that either complies, or in this case is otherwise acceptable, then it is fact that it adds cost. It doesnt add anything beyond this. The overall outcome isnt "better" in any way because they are involved. Their additional cost in isolation isnt that big, but the costs of generating drawings, SAP assesments and whatever else they ask for all start to stack up quickly as these are things i cannot do myself. All to do something that is a well recognised solution to insulating an old stone building. I would however take issue with the assertion they keep standards high. From my limited experience, its been anything but as i have previously posted. The latest round of changes to the system reflect the fact it wasnt working and standard were not high, ie, like my old place, where they were happy to sign off any old crap. Indeed, stuff that wasnt actually there. Im not in any postion to have big arguments with them as its not my specialist field of knowledge, so am really keen not to find myself in that situation. Nor can i "add budget" to the job, as indeed you might as a professional in the field. Off to do some sketches. -
i will do some sketches and post them. They will be just that though, sketches. You are a professional and in the trade. A BCO is rather more likely to take notice of you, than a DIYer like me. My, limited, experience of BCO's hast been a good one. Hence i now, in the recent past, simply havent bothered. Its adds nothing except cost to the end result. And I wasnt concerned as there was virtually no risk of any enforcement action. Thats seems to have changed. One question before i go and do some drawings, your discussions with the BCO, do they still do that? Under the new regulations, my understanding is they can no longer offer advice and suggestions? (or at least are not supposed to). -
Currently, it's cheaper to buy oil than to to do the work. Based solely on the financials, no rational person would do anything. However I do prefer the increased comfort from said insulation. Yes, you are correct that the BBA certification should be ok, but often isn't with some of the less mainstream stuff. Essentially though, if I understand correctly, I will need to pay for drawings plans of my proposed works, bearing mind until I strip everything, I don't know for sure what's there, in order to pay for an sap assessment. Just guessing, but what, £2-3k in reports before I've done any work? Assuming it all goes to plan and there's no surprises that require the reports to be reworked to reflect reality. -
I may not have explained myself well. I'm sure the report will be fine for the proposed works. My concern, given the construction method of the house, is I will need to use something like wood fibre and lime plaster, for example, which, clearly, many BCO's dont understand and/or are unwilling to sign off. Under this scenario you then have to go round the loop again with an alternative proposal . Repeat until agreement is reached. What the going rate for such an assessment for a whole house project? I've never done such a thing. I assume I'm going to need to provide a detailed plan/drawings for them to work from too? So another person to pay. -
Thanks. So now I have to pay someone (someone suitably qualified) to write a report on the payback. Potentially more than once if the BCO doesn't like my solution. How do you guys work with this nonsense. Or more accurately budget for anything. It's essentially open ended expenditure. -
I really don't understand how you arrive at the conclusion reading the document. On another forum I use, the couple of BCO on there have a very different interpretation from yours. Their view is, 10 year enforcement applies to everything covered by building regs. Accept of course, that until some of this stuff happens in real life and gets tested in court, we can't really know. But the document specifically refers to ALL notifiable work, but with more stringent regs around high rise buildings. -
It's still not straight forward though is it? As has happened many times, the BCO wants a "modern" solution, probably because it's what they understand, even where that is incompatible with the building, as, in this case, stone with no dpc. In this scenario, the BCO has all the power. Even if they are wrong. This is the situation I'm seeking to avoid more than anything else. I can't say no, thats nonsense I want to do this instead. Well I can, but they are not under any obligation to accept it. I want aware of the 15 year payback. Thank you for that. Does it detail anywhere how this is calculated? Given I'm on oil and the price goes up and down like a yo you, how does one work if out? When I've done calculation before I can double of halves the payback just by changing the price of the oil. And more importantly demonstrate to the BCO? Maybe you think I'm over thinking it, but I absolutely don't want to get into a debate with the BCO once I'm into the job. Simply because if the disagree I have no recourse to challenge that -
Which part are you looking at please? It clearly states that the BSR applies to all buildings, both new and refurbishment, as well as high rise buildings. As far as the penalties are concerned, they are not confined to hrb's as far as I can tell. -
That's not my understanding. The new arrangement means that enforcement if building regs can take place up to 20 years. I get that the new arrangements were to a large part due to such things as grenfell and the blantent disregard of regs by developers, but the enforcement powers apply across all areas. -
I appreciate the reply. However I'm thinking I'm more confused now than before I'm not sure I really understand how any of this doesn't require BC involvement? If we take the insulation specifically, my understanding is if more than 25% of a walk or a ceiling is disturbed then I need to comply. As I intend to take a while house approach then surely I must comply to some extent. The phrase in so far as reasonably practicable, is great, but is wide open to interpretation. The issue is only the bc's view is actually relevant. It purely luck who I end up with, and therefore how much it might ultimately cost Once I engage with them, I'm on the radar at that point. If they want me to do things I consider wrong or unaffordable, and I then choose to proceed another way, they will know that it is likely I've done just that. Under the new rules that came in last October, if I ignore it, and they know, the potential penalties are extreme to say the least If they don't know, then nothing can happen. The only way anyone would ever know is if I subsequently got another eoc which would show a large improvement! My experience at my last place is that the various certificates were worthless as none of the work complied fully, in one case, not at all. So what value do they really have? Especially as it's almost impossible to take action against BC for negligence -
Hmmm, back in bucks having a conversation wast a thing. Make an application was the only answer available, regardless of the question. Maybe where I am now is better? But again, don't want to alert them to activity. Private BCO might work, though it seems lots have ceased trading. As I continue to ponder, I'm wondering if I should just claim I did everything that's not visible from a satellite or the road before October 23? Ref the windows, I've used the Jeremy spreadsheet. I struggle with it as I'm not good with maths, but essentially, there's a limit to what we can achieve with the walls before we start to create new issues with dew points in the wall and the like. There's quite a lot of windows, so going triple glazed did, usefully improve things. At a price. But given the existing windows are early 80's uPVC with lots of blown units and something like 12mm between the panes, replacement was always necessary. -
Therin lies the issue though. You are entirely at the mercy of the BCO. They have no concern if you can afford what they say. That is not there concern. So one runs the significant risk of having to do something different. The traditional building groups have plenty of examples of the BCO forcing people to do things that are to the detriment of the building fabric. Of course, under the new regulations, they are not allowed to advise. In a situation where there is a lot of grey, as there will be deviation, that's really quite difficult. The real issue is, having invited them in, as it were, they now know you intend to do work. If you disagree with the requirements, they know you are doing it, so enforcement action would be very easy for them . -
Yes, the work won't comply. I can't achieve many of the requirements. The insulation I will apply to the roof for example simply won't be and cannot be deep enough to meet the regs. Therefore my options, in theory, is to leave as is, ie, uninsulated, or to do it without approval. I can't meet the regs. Well I could buy re roofing for example, but that's just plain daft. -
I agree. But those responsibilities and liabilities is exposure to enforcement action for up to 10 years, with unlimited fines and jail time. So I can fit the windows, and always could, but the risk and repercussions were low. And rather more proportionate. I'm now sitting here pondering what to do as I can't comply practically, nor can afford to if I need to pay BC every time I do something. Even the windows, the supplier has no installers that will come here and sign off themselves. Which wasn't a concern because I'm perfectly capable of doing so myself. Also experience suggests many holders of a fensa certificate either don't want to or incapable of a decent quality installation. -
Ive an old cottage with a 70's extension on it. Its in resonable condition and we live in it. It is, however, a thermal disaster. We are munching circa 1700 litres of oil on heating a year. Anyway, in my mind ive formed a plan of what i can do to improve, bearing in mind stone walls with no DPC. Nothing silly, just the usual stuff, probably lime and wood fibre to the walls, triple glazing to achive as much as possible, and some works to the slopy part of the celings with PIR. And a small extension to the existing single story extension. Normally, id just crack on. Ive little time for building regs having, at the previous house a whole suite of certificates, mostly not worth the paper they were written on, as lots of stuff didnt comply, including some pretty serious stuff id never consider doing! One of which cost £17k to rectify. However, the change of enforcement period from 12 months to 10 years plus unlimited fines and prision have caused me to ponder for a moment. Clearly, the works i wish to do dont have a hope of compliance, and even if i wanted to comply, aside from being in many cases impossible, in order to demonstrae compliance with involve paying lots of somcalled professionals to assesments etc. These two factors combined would render the works both unachievable practically and unaffordable. I couldnt even fit some windows myself if we follow this to its logical conclusion. So, i was wondering what others in a similar postion did? Obviously with a new build or major extension etc, its clearly unavoidable, after all, you need that final certificate. Especially as i will be doing it in stages, i can see compliance costing me many thousands extra in "fees".
Jotun do an epoxy which i think is suffixed AL. It has aluminium flakes in ut, is super drable and greyish silver in colour. Check which version though, you need the one that is a topcoat is is UV stable. I get mine from here: https://www.smlmarinepaints.co.uk/ Very helpful as are promain. You actually get to speak to a real person who has knowledge. Crazy, it will never catch on!
Water installation quote. Seems excessive.
Roger440 replied to flanagaj's topic in General Self Build & DIY Discussion
Seems like a bargin to me. I got a quote for £17.5K + vat for an electrical connection thats 50 feet away on my own land with me doing all the work. But as Conor suggested, they just look up a table. Theres no common sense or reasoning applied. Just before i moved a new build in the next village needed a water connection. Much like this one. Mains in the verge. Almost identical in fact. Traffic boys turned up, set up their traffic lights for one way working and retired to their van for the rest of the day.. Except it was a single track road. So the passing traffic was three feet from the guy doing the work, just as it would have been without the traffic lights. Except it was now chaos because, having seen a green light you entered the section only to be greeted by another car waiting at the red light with nowhere to go. Its not a busy road, but still chaos nonetheless. A classic example of the utter stupidity of the people in these organisations. This excercise gave the chaps doing the work no additional protection at all, cost the homeowner an extra bunch of cash, inconvinienced everone using the road, and lined the pockets of the traffic management firm. -
As Tom suggest, services can be expensive. They wanted £17k plus VAt, with me doing the trenching, to get a supply from a pole that was 50 feet away, in my oen field! Yes, it needed a new transformer, but if the supply is a hundred meters awaym across other people land, it can get expensive really quick Im not sure Tom is correct re the 3 years. My understanding was on class Q its three years to complete. Unlike any other planning. As well as a decent structural survey, you need to establish 100% you can have a sewage treatment system. If you cant, the plot is, frankly, useless. Again, that will need a survey to confirm it can be done in compliance with all the requirements.
Dead easy to avoid thermal bridging at foundation level if using an insulated raft too.
