We could, just for a laugh, all make a mug of tea and measure the temperature of the mug from a distance of 12", midway up the china. A white much would be best (cause I only have white ones). Then we can all see what readings we have. Best to do it before the teabag is stirred, say 60 seconds after pouring in boiling water.
A felt tip pen that you can sniff when there is nothing else. 70°C is about as hot as a dry hand can stand.
Right, well assuming the gauge is good, that should be OK
When you take the TS temperature, are you finding a bit that is exposed i.e. no insulation covering it?
I have met a few women that are mutton dressed up as lamb Yes, just while Nick sorts out the parts list. Do you think they only slept and fixed Apollo 13 as they circled the dark side of the moon, no, they discussed their favourite meals and how nice it would be not to pee in a suit. That is the real conspiracy of manned space flight. Why they all say that the Earth smells so nice. Unlike the cafe I was in earlier. Large family with small farting baby, that kept screaming until mother popped her tit out and smothered the little bugger. My girlfriend said that 'In Portugal, you would be arrested for that'. So I am now going to join a political party, probably the Greens, and see if i can get voted in on having small children arrested, along with building in green fields and the banning of nylon clothes (see this weeks comic about that). I think I am going to have a lay down in the sun now before I have an attack of the vapours.
Only takes me minutes to walk to MacSalvers, everything ever needed for the home and heart, and guerilla warfare.
Pre second world war, it was usual that shops delivered and when my sister lived in Brazil in the 90s they always got things delivered. Seems that picking stuff up from a shop is is just a short blip in normal retail service. A failed experiment that lasted 80 years, which is nothing in real terms. Still with Amazon Prime and a decent interweb line, you get to watch our brave boys drive cars too fast on the Grand Tour. I just have to do illegal downloads at no cost!
Odd isn't it, we ponder how far it is to a fast food place. When I was a baby, we lived in Brunei, The nearest 'western' hospital was in Singapore, about 850 miles away. Great time for my parents to find out I had serious asthma caused by the dog they had. Luckily we had 10,000 British troops keeping the 8,000 Bruneiese in order.
Sounds like Cornwall, in the 1990s!! Had to go to Devon to get a McCheese
And a KFC
We like a video on here. @Construction Channel is the man to edit it. He can make changing a door lock entertaining.
Does your holiday let have permanent internet connection? Failing that, you will have to leave a phone there that does has a 4G, possibly 3G signal.
Called lager Or, in a way, it is what plumbers do
Well the big rig is in place now. It is bigger than the palms, the obelisk and St Mick's Mound, from the right angle.
I am off out for a coffee and a look at the sea, as I have been sitting here doing silly things in Excel. I shall return and look forward to seeing what is happening.
You have not read much else on here, you have just about invited half of Buildhub around!! Can it be reprogrammed to be a boat. You have to try and get the manifold or a pipe, not the roof in general because of what @Onoff says. My IR thermometer is pretty good over a distance, I scare animals and small children away with it at night.
They drilled the pilot hole with the 'little rig' the other day. Hopefully the 'big rig' will be there now so they can finish off the 1.5 km bore. https://www.cornwalllive.com/news/cornwall-news/jubilee-pool-penzance-takes-step-1152275
Ah, then the 3 hours is not so odd. I don't know where I got the 200 lt figure from. That would raise the temp by 17°C, so if it started at 30°C, would be about right for a shower. (that does assume that the whole store is heated evenly, which is not the case)
Yes, but it is still 9 kWh being pumped in and only 1 shower taken. I seem to remember that the TS was 200 lt, is that right? And also read on here that it can drop by 20°C in a few hours, which seems ridiculous. Really about time that 'heating engineers' separated space heating and DHW as standard, combining the two is not good in my opinion. This will become more important as we shift over to electrical heating, though we access to so much natural gas that it is not going to happen that fast. Could just set up this system to heat the house and put in a Sunamp for the DHW . Take down the ST and replace it with PV. Not the cheapest option, but if it is burning though 9 kWh a day of electricity to get a shower is costly too.
That much energy would heat 200 lt of water by 39°C. So if your TS was at 25°C, it should end up at 64°C after 3 hours, and that would be enough for about 3 baths of water. I get a bath out of about 1.5 kWh, a shower about a third of that. My DHW cylinder is 200 lt and rarely goes below 30°C and I limit the upper temperature to 50°C. I think there is a lot of energy leaking out of your system somewhere. When you get the IR thermometer, see if you can point it at the solar thermal collector at night (bit hard I know). Be worth eliminating that part of it.
If it is a 3 kW element and it runs for 3 hours, that is 9 kWh. You must take very long showers, or the heat (the old word for energy) is going somewhere else. Re the above picture. Isn't it limited to 65°C now, what the reset is for?
You will, it is the crack cocaine of building technology
Pointing an IR thermometer all over the place (if it turns up tomorrow). will be very interesting. I frighten myself with mine sometimes. But as @newhome has an IT background, it won't be long until her place is wired up with environmental monitors (just share the code as my ESP2866 with a DHT22 and a BME280 decide to stop playing when I moved my router )
Yes you can, easily. Earl Grey always tastes like someone put washing up liquid in it.
Male workplace banter, which can creep over to quite vicious criticism, is often a way to highlight problems before they become too serious. Called 'keeping it real'. A lot of it depends on knowing your workmates well and outsiders (or management) are often excluded. I was an outsider on a job one time, and the chippy did not like something he thought I had done (was some badly fitted skirting I was trying to put right). He kept saying the same story 'about this bloke he knew' that had made the same mistake. I just used to stare at him while he repeated the story for the umpteenth time, then laugh. I was helping out a friend's son by doing whatever I could, he was paid to put things right. He never put anything right, but make one big mistake with me, thinking that I was a bit dumb. He was a bit shocked when I left early to deliver a lecture at the university I worked at. I generally find that idiotic humour gets me out of most problems. I have only had one problem in the last decade with a workmate. Young lad who was work shy, arrogant and a snowflake. He thought he knew a lot, when he was shown to be wrong, he would never accept it and tried to bluff his way out (bit like Trump). Eventually he said he was being bullied and refused to come in again. Thankfully the owner of the business, who worked with us, said he had not been bullied and was just a dick. I have seen workplace bullying and it is not pretty (I had to clear up the mess it left in the company afterwards), normal male work place banter is not bullying. Bullying is systematic and usually done by someone that has serious problems. Why, I do not know, spotting it and sorting it out is the tricky bit.
