SteamyTea
    198
  1. During that episode, they often cut to video of the wife looking miserable. That may have been post editing license. I also suspect that the things she initially liked about her alpha male husband, vanished when it all went wrong. And who knows, she may have met someone else and the sparks just flew. Or he may have.
  2. A bit more digging and the Bude Canal will be complete.
  3. Typical Devon, half their shit ends up in Cornwall.
  4. And almost certainly got his fees.
  5. Yes, just a standard GRP system. Nothing new about a powdered hardener, been around for decades.
  6. Heat does not 'rise' in a solid, so I am not sure how much difference where the elements are located actually makes in practice. But I still think that fitting wet UFH pipes us the way to go, then from an educational viewpoint, you can play about with different heat sources later.
  7. That may be an issue with one particular company, but the same is true of a few mass building companies too.
  8. That is probably a good thing, they have more knowledge. Got to be better than many local builders that have limited knowledge.
  9. Funny how people have different favourite equations, mine is Newton's Law if Cooking. I would type it properly if I switched auto correct off on my phone.
  10. When I did my surveyors course I seem to remember that you had to get online quite quick after gathering the data to get accurate readings, that was in 2006. Did manage to map the halls of residence at Exeter university to within 100mm. Not bad for a first go. Got over 90% in that assignment.
  11. Ah, that makes sense, my least favourite of the equations.
  12. Where does that come from as it is pretty useful for estimating.
  13. If you watched 4 GD's back to back, I would say that is a sign of stress. Get some help.
  14. I liked living down that way, though my house was in what, was 30 years ago, scummy Weymouth. Interesting that the nexgen website is not active. Maybe we have had some real influence on a company.
  15. Not sure how things have developed in 35 years, but we used to incorporate this sort of heating element into moulds for insitu post curing. They were very 'patchy ' to say the least. Some areas got very hot, other areas had no heating at all. Also I don't think you can reliably run directly from PV. You will need some voltage regulation. A normal domestic solar module runs at about 72V. So outside the scope of ELF I think. And that is before power point tracking is considered. If you can fit normal wet UFH, the water can be heated with just about any energy source i.e. Heat pump, wood burner, bottled gas, oil fired, electricity, small boy scouts rubbing their knees together etc.
  16. I used to manufacture both log and panel saunas. These are basically small houses. Panel saunas, when outside had worse thermal performance i.e. they cost more to run. Log saunas had, as @JSHarrissaid, large coach bolts though the timber that had be periodically tightened. I preferred making and installing log saunas as they were more profitable and the finished product was, in my opinion, much better.
  17. Welcome Don't confuse low voltage with low energy. Voltage is only part of Ohms Law. There are, and I am sure an electrical person will come along and say more about it, different rules for High and Low voltage. Low voltage is anything under 1000V, but then there is Extra Low Voltage. If you have not read this, may be worth it NextGen. Sounds like an interesting project you are involved in, where about on South Coast are you?
  18. Have you updated and upgrades recently? sudo apt-get update && upgrade
  19. Give the fans a go, it is a cheap way to eliminate one thing.
  20. Never criticise a your wife's choices, look who she married. Though I often find find they are like kitchens, better than what I have at home.
  21. He looked a bit young for that. Think he was a producer. There are some jobs that are not that costly when you make a mistake, and/or cost other people money. Other jobs drag you down with it. Kevin did joke that he may not live long enough to see it finished. He should have done it in stages. The tower could have been put up later, it was only a steel structure after all.
  22. I think @JSHarris had one of those combined cylinders with the F&E tank on top. Mine is just a bog standard cylinder. The F&E is in the loft. Have insulated the pipes.
  23. Renovate it properly and any dampness should be a thing of the past.
  24. I would forget PV, seems you are surrounded by trees. As for ASHP, that is just a sizing issue. Work out your current heat load, that will give you an idea what will be needed in future. I don't understand why you want a limecrete floor. Better to dig out what you have, lay some proper insulation, then a concrete floor with under floor heating. At least you will know that the floor will set hard. Regarding an wood burner, why, they are inefficient, very polluting and hard work.
  25. Landscaping a lake at the moment I would have thought.
