SteamyTea
    200
  1. Light would be on the outside though. I have an ugly house already.
  2. No idea. It is not used in the PU industry. They use it to decaffeinate coffee and tea. It used to be sold on eBay. I think Nitomors has it as the active ingredient.
  3. Bit tricky, especially as that switch is on the wall. You would need to make a thin, timber frame that fits around the whole of the windows, but comes into the room enough to miss the handle, then two panels that fit to the new frame. May need a bit of an overlap in the middle, but that is easy enough. It is the kind of thing that is easier to just make than actually design. This is what I knocked up last year.
  4. Said it many times, acetone is the wrong solvent for polyurethanes. Works well with polyester and vinyl ester, while in the liquid state, but not with polyurethanes at all really. Use dichloromethane, but no one ever listens to me, even though I worked with polyurethane, epoxy, polyester and vinyl ester resins for decades.
  5. Yes, and looking at the above images, seems the DHW is taken from the top of the horizontal cylinder. I just modelled the thermal losses, not the usage.
  6. I said something similar a while back about using an old freezer. Then Jeremy Harris, who was a clever bloke, pointed out that a large freezer probably only draws about 700W. So 2.1 kW if CoP is 3. Would still heat my DHW just about.
  7. Good, it is too easy to mark one's own homework. I think that the biggest issue is where the hot water leaves the cylinder, normally at the top, initially the hottest point, horizontal cylinder it comes from the mid point, so the median temperature, though it may be the mean temperature.
  8. I made my own from clear styrene sheet and a bit of moulded timber. Less than £10 a pane. They made a huge difference to the sound coming in.
  9. CCS is like hydrogen, it is not worth doing.
  10. We have had, since 1997, a Tory government, a New Labour Government, a Coalition Government, Tory Government and a couple of loonies in charge, not to mention Brown and Cameron. We vote them in, so I don't think the real problem is political will, more that the general public is politically naive and we get what we voted for.
  11. Because we are not building many houses, so the cost to the tax payer is pretty low.
  12. One is connected to a large, well regulated network, and the other just cuts power. Don't think they can be compared to us really. Now if that EU super grid gets built, they may let us connect to it at a price.
  13. The way to check is to run the numbers and see if it makes sense. https://www.engineeringtoolbox.com/amp/heat-recovery-efficiency-d_201.html
  14. That is what the data should show, as I said, I have never looked at that side if it.
  15. No. https://en.m.wikipedia.org/wiki/List_of_countries_by_uranium_production Kazakhstan, Namibia and Canada produce about 70% of it. Forget that one, no system has survived long once out at sea, or bolted to the rocks. Tidal stream is the most promising, but it minces up small whales and cuddly dolphins. Gridwatch shows how much travels in and out of Scotland, never taken much notice if it, but may be interesting to see how close Scotland us to being 100% independent.
  16. How about the upfront price to build, the MWh price of delivered energy, the relatively small lack of power modulation, with the associated slow ramp up and down. Then there is the security of supply of the fuel, there has not been a mine open in Cornwall since the 1998, and I don't think there is much uranium ore there, that comes from South Terras, near St. Stephens, and they are all a bit angry over that way, probably because the mine closed in 1930. Then we have to agree where we are going to bury the waste. It will be in Cumbria, they just want a lot of cash to do it. There is also the skill set needed to build and run a modern reactor, skills the UK does not have at the moment as there are only 3 EPR PWR in Europe, and I don't think any are working right yet. Then there is the planning system to negotiate, at lest ten years of horse trading. And solar and wind are cheaper, even after adding storage. We can build a GW of offshore wind in 18 months, not the 20+ years a new reactor takes to not be build.
  17. Almost. There needs to be some standardisation of the control systems that the general public will understand i.e. room temperature setting and maybe a fast heat and an eco heat, which may be a case of switching weather compensation on and off. Then the general public have to learn that these systems have to be left switched on all the time, not mucking about with timers, that will have to be built in (via GPS maybe).
  18. That is a reasonable plan for an individual. But it's a lousy plan for a nation. If we all use off peak electricity, it's no longer off peak In reply to that, if we all used about 2 kWh of electricity to heat our hit water, then that is about 135 GWh/day. During the summer the nighttime generation is around 20 GW. Winter that goes up to about 30GW. That would use up all our current night capacity between 4.5 hours and 7 hours. I am not sure how much wind is generally curtailed at night, all the solar is in the winter. Nuclear stays pretty stable. So capacity wise it is not a problem, just the timing window. That could be varied, it does not have to be a fixed window i.e. 00:30 to 07:30, nor does it need to be totally reactive to grid demand. Personally I hope that the price skewing of different generation methods reduces in the not too distant future, then we can get back to better planning of both the infrastructure and the demand management. I will say that our demand management has made for a very reliable grid, only have to look at the frequency time series to see that we are doing a good job of it.
  19. How much hot water do you use? Have you measured it?
  20. I seem to remember all you wood burner people claiming it is the warm glow from the fire that keeps you warm.
  21. Generally, you have two different flow temperatures, one for UFH and the other for radiators. Chances are your UFH is running too warm, and with probably only building reg minimum insulation under it, you are keeping the worms cosy. Then you have the flow temperature for the DHW, usually at the higher end of a heat pumps delivery, around 55⁰C. Do you know any of these flow tempers?
  22. Was that the case in Taunton, Or the Penzance case.
  23. I don't that that is true, nor has it every been. There is a lot of confusion and misinformation about heat pumps. It mainly boils down to the general public having fallen asleep during science lessons. Temperature, power and energy are not the same thing. The main points to remember about any heating and hot water system is that it needs to be designed and operated correctly.
  24. I modelled it not long ago because someone asked the same question. I think there was not much in it, and if I remember correctly, vertical had higher losses. Posted August 10 (edited) I have never seen it modelled, so hard to tell. Take a cylinder with a 0.5m diameter ad a 1.2m height. Assuming a U-Value of 0.2 W.m-2.K-1 Volume will be 235 lt. Surface Area will be 2.28 m2 Base of cylinder temperature, once settled, 36°C, top of cylinder temperature 60°C. Ambient Temperature 10°C. If one assume a temperature gradient of 20K.m-1 (about what mine is), then the power losses, when vertical, will be the sum of the top end, plus the area of the diameter (hoop), then the sum of the hoops, and finally the sum of the last band and the base area. Using a course 0.1m down the cylinder, the power losses are 18W, or if the cylinder is unused for a day, 0.44 kWh. Now lets turn the cylinder horizontally. Working out the surface area is not quite so easy here as for every 0.1m loss in height, the end area and the hoop area do not scale in a linear fashion, so I sketched it up in CAD, sliced it, triangulated it, then worked out the dimensions. Accumulative errors was between 1 and 8%, so shall use 4% as the error. The cylinder power losses are now 20W, 0.49 kWh.day-1. A difference of 0.05 kWh. The above is on a static model, but there will be some turbulence. With a mean temperature of 48°C for the vertical temperature, the mean density of the water is 988.7 kg.m-3, at the top of tank temperature, the density is 5.53 kg less, 4.48 kg more at the bottom. A total of 10 kg.m-3 difference The horizontal cylinder only has a 12°C temperature difference (because I used the same temperature gradient of 20K.m-1), so the density difference is only 5.6kg.m-3. Now without getting into Reynold Numbers and tangential surface areas, a simple way to model it would be to look at the difference in stored energy and the difference in mass as energy is the ability to do work, which can be reduced to moving a mass a distance. The vertical cylinder will have 233 kg of water in it, the horizontal one 232.4 kg, so 0.6 kg less. To move 1 kg of water, 1 metre, will take 1 joules of energy. So to move 232.4 kg 1.2 metres will take 279.6 J in the vertical cylinder. There is only 0.5 metres of height in the horizontal cylinder, so 116.2 J, so the turbulence losses will be in thee order of 42% less. So I would not worry about the cylinder orientation. I am going outside to sand some wood now the glue has set.
  25. What makes you think there is a performance difference because of orientation?
