SteamyTea
    198
  1. I am getting 7.5 Mb But I am running it though the TOR networks
  2. I have had the same problems with most sites today, even my Google news feed has been slow.
  3. The ONS has some numbers on heating types. Here is a quick analysis for England. Type of central heating in household (13 categories) Number No central heating 367119 Mains gas only 18298730 Tank or bottled gas only 260108 Electric only 2113123 Oil only 865944 Wood only 35720 Solid fuel only 49469 Renewable energy only 98729 District or communal heat networks only 220893 Other central heating only 225399 Two or more types of central heating (not including renewable energy) 2113324 Two or more types of central heating (including renewable energy) 134659
  4. Really. There are many on here who can write to them and tell them what the units are. Will look something like this: Kw/h/kj(lb.oC)
  5. Weather Compensation Keep It Simple Stupid
  6. They produce CO2 as well. Now ammonia based combustion only produces NOX, much more healthy.
  7. What surprises me is that I mentioned this many years ago and the general consensus on here is that it would not happen.
  8. Welcome Are you hoping to reproduce the original building, or just use the original footprint. Generally, as a rule, clear the plot of all plants and growth, this should not affect and CIL (Community Infrastructure Levy) if it is applicable in the area. If you stumble upon something rare or protected, it can old your build up for months, if not years, and cost a fortune. It may be worth checking that there are no TPO (tree protection order), they can really mess up your design. You will probably not be able to use the original foundation as it would not meet current regulations.
  9. Not really sure what you mean by 'window boards' (assuming you mean internal window sills), but it does not matter much. When using an adhesive, the surfaces you are sticking together is the important part. Generally they need to be compatible with the adhesive used. This may sound a bit obvious, but there are some quirks. The traditional 'silicone sealant' does not stick that well to rough surfaces, and does shrink away over time. Polyurethane adhesives work in a different way and like to grip mechanically, so need a solid substrate i.e. not flacking off. Oils, paints and other treatments can cause problems, all really depends on the chemistry. So how to get around this. Quite simple, knock up some samples and try them. My 'go to' adhesive is low expanding polyurethane. It expands a bit to get a better contact surface area, sets fully in a reasonable time and can be painted over.
  10. They may be using a lot of DHW. Or leaving windows open because they like fresh air. Ask them what their bills are when they have gas fitted.
  11. I seem to remember they are called catenary cables. https://www.engineeringtoolbox.com/amp/cable-loads-d_1816.html
  12. Welcome. When I bought my first place, the first room I worked on cost a fortune, mainly from buying tools and other kit. The next room cost a lot less, third even less. Called a convergent series in mathematics. An infinite number of mathematicians (thinking of you @Garald) went into a bar. The first one bought a pint if beer, the second one half a pint, third one a quarter pint, the fourth one an eighth of a pint. The barman pulled two pints and said 'you lot need to learn your limits'. Just get on and do things in an intuitive manner, learn from mistakes, and lost fingernails, but if you get really stuck, ask and get 20 right answers.
  13. @minty Are you any good at playing with wires and computers. For a few quid you can make a multiple sensor temperature and RH data logger. They come in handy all the time. Thinking about the damp more, it is worth remembering that it takes quite a lot of energy to evaporate liquid water. Liquid water takes 4.18 kJ/kg.K, to get from liquid to vapour (phase change) takes 2256 kJ/kg. That is 540 times more energy. So sometimes drying a place out is much harder than you think.
  14. @ToughButterCup I listened to the rest of the series (well fell asleep to them). The one about sprays and nozzles was really lovely interesting.
  15. Well I did when first broadcast back in '07. Hearing the word silane brought back happy memories of when we cast 10,000 bottles of beer into acrylic. Manu years ago, @Construction Channel did so tests with different tapes onto timber. I suggest at the time that he found the one that stuck to the timber best and then the one that stuck to the material he wanted to attack the see how well he could stick them together with double sided tape. He didn't try it. Bit like no one wants to use the proper solvent to clean thier PU foam nozzles. You can lead a horse to water, but you can't make it drink.
  16. It is a bit difficult to track internal relative humidity (RHI) and the contribution from the outside air relative humidity (RHO) sometimes. I suspect you have a leak somewhere, finding it may prove to be hard as liquid water can travel quite a distance from the entry point. Is there any sign, inside or outside that water is leaking out i.e. a damp carpet, a stain in the bathroom, an odd dripping noise (water meters really help here), staining on the outside cladding. Worth having a very good look around the windows, especially if they are replacement ones. The vapour control layer (VLC) may have been damaged. I seem to remember that a person expires 2 litres a day, not a lot in a big building but quite a bit in a small one.
  17. I don't either (in a well designed new build). I suspect it goes back to when we started getting natural gas in the late 1960's and early 1970's. Houses then were pretty badly build and as the gas board was fitting thousands of central heating systems (we managed to fit gas system so I cannot understand why we cannot fit heat pumps at the same rate), a "one design suits most" approach was taken. This assumed that all rooms leaked energy at a fairly high rate and the worse that needed doing was fitting a larger radiator.
  18. You can't get away from the world electrifying either. As a general note, the heat losses for the same building will be the same regardless of the thermal source. You size your heating system to your building, not the other way around.
  19. “all science is either physics or stamp collecting.” Ernest Rutherford
  20. ? When it comes to condensation, the absolute humidity (the grams of water in a kg of air) can become important.
  21. I don't know about now, but a few years back (25 years ago when I worked in the USA and Australia), It was considered good enough and got me extra credit points on my visa (I actually don't need a USA visa as I have an indefinite one (an side benefit of being a refugee at one stage).
  22. That is for AC, impedance is sometimes called AC Resistance. Don't make much difference to the calculations for a simple resistance heater really. You are right though that to get maximum power, resistances need to match. I don't know how well better charge controllers, or cheap sine wave inverters do this. My main concert with low voltage DC is the switching current, may cause reliability issues quite quickly. I think the trick is to not be greedy. A couple of 330 W modules in series, via a regulator (for want of a better term) into a 400 or 500 W element will still give a useful saving, and if it did 'stick on' the cylinder overpressure/over temperature mechanisms cal safety devises should be able to cope with it safely.
