  • entries
    10
  • comments
    128
  • views
    40243
The energy meter experiment
I am not sure how well it works yet, but it works in trivial cases i.e. a 40 W lightbulb and my fridge (once I had stopped stray morning light).  I am going to ask my neighbours if I can pop the Photo Diode on their meter as I don't want to stop the one that is already logging mine.
What would be good is if others, who have a lot more knowledge and skills than me (I am really just a chancer than fiddles about till it seems to work) could improve and add to it.
Things that would be nice are a remote sensor to save having to run a small bit of wire into the meter box.  A nicely made sensor cover that holds the magnet in place, and does not let stray light in.  A display, and an enclosure for the complete kit (thinking of you @Onoff and your plastic printing skills).
Remote, but not cloud based access may be interesting, but as will all new toys, after a few days, does not get used often.
Other 'things' could easily be added i.e. temperature, humidity, air pressure, but they are really stand alone items, though inside and outside temperature is useful.
So here it is, my feeble attempt.
What I have used to make my energy meter.
A shop bought energy meter
https://www.ebay.co.uk/itm/354118466147
I used this purely to test the power, 1 pulse per Wh, same as my main meter.  I will, as I bought 3 of them, use them on my 3 ‘night circuits’ once I have finished playing.
Some magnets with holes in the middle
https://www.ebay.co.uk/itm/184928442876
These are to hold the light dependant LED onto the meter.  A suitably sized metal washer was super glued in place.
Some photodiodes to sense the red flashing light on the meter.
https://www.ebay.co.uk/itm/232690475106
This is the real magic, just wired in between a GPIO pin, 22 in my case and ground.  The important thing is to wire it in the ‘wrong way around’.  So the anode, the longer leg on the diode, is wired to ground, and the cathode, the short leg, is wired to pin 22.
A Raspberry Pi ZeroW
https://thepihut.com/products/raspberry-pi-zero-w
Just a bog standard RPi ZeroW
A header
 https://thepihut.com/products/colour-coded-gpio-headers
Are useful, and I think you can buy the RPi ZeroW with them already soldered in place.  You need it to easily fit the RTC on.
A Real Time Clock
https://www.ebay.co.uk/itm/234603677979
While not necessary, I always fit an RTC (real time clock) as I cannot guarantee an internet connection all the time.  You have to muck about with the /boot/config.txt file to include the line
dtoverlay=i2c-rtc,ds3231
and edit the /lib/udev/hwclock-set file to disable the settings with the # symbol
# if [ -e /run/system/system ] ; then
#    exit 0
#fi
A USB to TTL Serial adaptor
 https://www.ebay.co.uk/itm/203604196200
Useful when setting up a ‘headless’ RPi.  Just make sure to change the /boot/config.txt to inclide the line
enable_uart=1
The Code
The code I have used uses Python3 and standard libraries.
After much searching and thinking, I found that GPIOZero library was quite useful (https://gpiozero.readthedocs.io/en/stable/api_input.html) as it has some useful code for a ‘button’, or switch to the rest of us.
I also, included a block of code to create a daily *.csv file that automatically changes the filename every midnight.
All the code does is sense when the light dependant LED senses light, and when that light stops, it timestamps the daily *.csv file, then wait until more light appears again.
Simple, 3 lines of main code.
#!/usr/bin/python3
from gpiozero import Button
import time, datetime
button = Button(22)
def sort_time():
            dt = datetime.datetime.utcnow()
            runday = dt.day
            dt.day == runday
            ts = time.time()
            UTC = datetime.datetime.utcfromtimestamp(ts)
            logfile = '/home/pi/monitoring/data/meter-%s-%s-%s.csv' % (dt.day, dt.month, dt.year)
            tfile = open(logfile, "a")
            tfile.write("%s"%UTC + '\n')
            tfile.close
while True:
            button.when_pressed
            button.when_released = sort_time
What could be simpler.
The output is presented like this.
2022-07-09 13:05:38.577239
2022-07-09 13:05:40.028295
2022-07-09 13:05:40.374854
2022-07-09 13:05:50.753515
2022-07-09 13:05:52.390287
Each timestamp is equal to 1 Wh.
I do all the analysis in a spreadsheet.
39 Comments
Recommended Comments
SteamyTea
Some pictures of my 1wire therm and LED.
Radian
43 minutes ago, MikeSharp01 said:
I am having a real struggle getting the RTC to work reliably
Could you not use the time library with network time protocol instead?
Radian
I know what you mean by LED but it might confuse others... now, if you called it an LRD, that would be more like it 😄
SteamyTea
Yes, had just woken up from an after lunch snooze.
Or would that be dinner.
MikeSharp01
Yes I thought of that but if I2C is not working then other things won't work and I need to have it available as I want the block to be universal - I have a few other I2C devices so I need to try them and see if it's the RTC, the library (which may not have been extensively tested on the ESP8266) or my circuit / associated capacitive issues. I have played with MQTT on it and thought I could use it to provide a time to all the subscribers so I still keep time if the internet is down.
Radian
Around a decade ago I developed a Real Time Clock I2C module for CJE Micro’s to sell in the 'then new' Raspberry Pi market. I can't be arsed to resort to scope low-level issues with I2C these days. Not unless absolutely necessary. Have fun 😄
SteamyTea
I have some older RTCs, DS1307s I think.
Would they be better supported?
MikeSharp01
I have moved on and found an interesting bug. If I run the RTC on a nano it works fine, then I transfer it to the WEMOS, first run is fine but next upload it breaks and I get error 4. So for now I will put the RTC on the back burner and work on getting counts back to the server. See if can remember enough Node Red to get that going with MQTT from the device. Might be fun but no more time today. Chores🤨
SteamyTea
Seem to remember our @Ed Davies having some quirks with RTCs, probably on his website.
Radian
Sounds like you have something pulling the GPIO0, GPIO2 and/or GPIO15 pins to the wrong levels at boot time. These are the boot control bits.
summary here
MikeSharp01
Yes, thanks for the heads up on the boot pins - had the GPIO15 with a pullup for the pulses. That has cured the boot from reset switch but the rtc is still error 4 - bus arbitration fault. (Nothing else on the SDA / SCL pins I can see.)
MikeSharp01
Bugger me, just looked at the tracks above the board taking SDA and SCL from the RTC to the WEMOS lovely and parallel - so thought nice capacitor there, so bent them apart - see pic, works like a dream - dry joint or interference?
MikeSharp01
Now I must finish my trustee report - sometimes life interferes and not capacatively.
SteamyTea
dry joint
I do the driest of dry joints.
