Stove
Thedreamer
As we are building on a croft with an area of woodlands, the stove was a consideration at the initial design stage and we wanted it to be at the very heart of the house. As well as being the focal point of the living room, it was also considered from a practical point of view as to how the heat would be distributed throughout the house, as often I have heard that a stove can overheat well insulated rooms, resulting in a waste of money and just really something to look at.
The work leading up to the stove installation began right back at the foundation stage, with excavation, concrete foundation, blockwork, back filled and compacted, insulated and then a concrete slab added on top.
Dense concrete blockwork was put up during the summer with the aim of holding some of the heat when the stove is lit.
The stove itself is a multi fuel Charnwood C4, built in England out of iron. We choose one with a log stand underneath to provide a bit more height as this is one of their smaller models.
We decided that a lime render would suit the fireplace and this will lighten as it dries out.
The mantle piece has some history attached to it.
It was originally part of a massive beam in the local school, which was knocked down in the early 90’s.
My wife’s uncle salvaged the beam and it was stored on our local township road next to our sheep pens. It was used as a spot to sit down when being out on the croft. A couple of years ago we cut the beam into manageable chunks and took it inside our wood shelter to dry out before it was cut and planed this week.
The wood is at least 150 years old, was outside for around 30 years, but now it’s been tided up, it feels stronger than the timber we used to construct the house with. I love old timber!
The hearth is also a highland product, not as local as the mantel piece but 40mm Caithness slab, very heavy (but I was at work when it went in). My wife carried out the measurements and this was spot on when fitted.
Outside we have used anchor ties to hold the flue in place, some houses seem to fit flues without these but with our Hebridean weather this is a must. I went with the black soil pipe vent earlier on this year so it would match the flue when this went in. Sometimes flues can be ridiculously long and a bit of an eye sore as they need to be above the ridge, but having the stove close to the centre has allow this to be quite modest.
Also, respect to our stove fitter, this seems to be a trade that covers not only the stove installation but masonry, carpentry and roof work.
The stove has now been commissioned and certification provided.
There is a bit of work to tidy up with plasterboard above the mantle piece and we have decided now that the flue is up, that boxing in with plasterboard is probably best to protect the kids and also to protect the flue from them!
Next up, the kitchen and flooring is due to arrive next week.
Thanks for reading.
  • Like 4
20 Comments
Recommended Comments
jamieled
Posted
Looks really nice, well worth the early planning. That timber is lovely, it's often easy to write off something that just needs a bit of TLC.
  • Like 1
ProDave
Posted
If it is anything like ours, when the stove is lit, the flue in the room above is barely warm to the touch and presents no hazard and no need to box it in.
mm289
Posted
Very nice build, I love the two tone between the larch and render - is the idea that the larch will go grey/silver as it ages?
When we were renovating our farmhouse I went to farm auctions to buy old bits of timber. Most of the lintels and beams we had to replace were all made from these salvaged bits picked up for a few quid. Go to a salvage yard and they wanted £100's?
Cheers,
MM
  • Like 1
Thedreamer
Posted
Cheers,
MM
Thanks, yes the plan is to allow the larch to sliver and then consider a treatment.
Tennentslager
Posted
What @ProDave said...fire it up for three hours and see how hot the twin flue feels.
My thermometer (on the bottom uninsulated flue) gets hottest (300*+) with dried kindling and a cool 200* with coal
Thedreamer
Posted
The upstairs middle section was originally going to be cupboard (flue to be exposed in the cupboard), toilet and wardrobe, but the triple velux view is to good so be wasted as a walkway so now we got to reconfigure the space.
If it was just us I would leave it exposed, but with young children and this spot upstairs is going to be their living room , therefore we need the flue to be protected and consider practicality rather than aesthetics. I have visions of bits of lego going into the floor grill, finger prints on the flue and all sorts of potential accidents.
In our loft we had to box in a chimney and at the time it was like we gonna lose so much space, but we worked around it and it actually been great in dividing up the space, bit different here but we plan to put some furniture next to the boxing in and then keep the space flexible for future needs.
ProDave
Posted
Go on, light the stove and measure the flue temperature.
Our flue goes up through my daughters bedroom, exposed.  With the stove burning it is pleasantly warm at floor level but not by any means "hot" and at ceiling level it is barely warm at all.
The manufacturers state it must remain 50mm from any combustible material. I think that is the manufacturers being over cautions, after all you could have a 20KW monster stove on the bottom burning full tilt 24/7.  With out little 4.5KW stove the flue really does not get hot and it does not bother me having it exposed in a child's bedroom.
Do the same rules apply for a WBS flue as a gas flue, i.e. all joints must be accessible for inspection?
Thedreamer
Posted (edited)
I'm not really fused about the flue temperature, I agree it would not be hot.
Boxing the flue is more about protecting the flue from my kids.
Edited by Thedreamer
joe90
Posted
I always fancied an un insulated upstairs cast iron pipe with a Guard around it as a bedroom radiator.
SteamyTea
Posted
If you get too much of a temperature drop up the flue, the smoke don't come out fast enough.
But at least you keep your mess private, rather than giving a little bit to everyone else.
PeterW
Posted
Don’t forget if you box it in, you have to leave access to all the joints in the flue for periodic inspection.
Thedreamer
Posted
Yes considering this.
Thedreamer
Posted
I don't understand what you mean? Mess???
SteamyTea
Posted
Wood burners emit many different pollutants.
Thedreamer
Posted
I live in a remote area and manage an area of sustainable woodlands. The trees we fell and burn would over decades remove pollutants from the atmosphere. The wood is stored and seasoned and will be burnt in an a-grade efficient stove.
We plant new trees throughout the year to replace the ones felled.
I agree that the use of wood burner in residential areas is a bad for the environment and the local population. But this is unique situation where the tree we grow and sustain have benefits to everybody and when the trees are cut often to encourage new growth, the timber produce is just a by-product.
Can you name an alternative heating system for our house, that works on a fuel that actually benefits the environment during it's production, is sustainable, completely natural, simple, require no infrastructure, attractive when being produced and is free (apart from some sweat when cutting ?)?
  • Like 1
SteamyTea
Posted
A wood gasification burner maybe.
Or a windturbine.
Or invest in a solar farm as offset.
jamieled
Posted
I was under the impression that the minimum distance to combustibles was mainly to deal with the risk of a chimney fire, at which point the flue would be a lot warmer.
Thedreamer
Posted
Or a windturbine.
A wood gasification burner, sounds complicated, expensive and I think we would struggle to get one that deals with the output required for the house.
Wind turbine - What would you prefer to look at in a national scenic area, some trees blowing in the wind or a turbine? Maintenance issues. Not an option here.
Solar - A few houses have panels here but they look a bit of an eyesore and not in keeping with the area. Expensive to install, better in sunny climates and not everybody cup of tea if considering resale.
You could export electricity to the grid for wind and solar for a financial incentive, use electricity in your home, but it's all dependent on the weather. Battery storage is a consideration, but nasty chemicals on disposal and the whole system becomes complicated.
A split seasoned log is like a natural battery of energy, it can be stored, managed and used when required. It regrows and can clean the environment and provide a home to natural wildlife for decades.
ProDave
Posted
That would make sense.  It is certainly not in our case to stop the flue setting fire to the timber of the house under normal running.  And just to be clear I have complied with the >50mm to combustible material for the whole length of the flue.
Tennentslager
Posted
Maybe a carefully designed cement board boxing in job?
in my hut the twin wall goes via a ceiling for four feet before exiting the roof. The roof space is dead and fully sealed so no storage or access. I made a cement board lined ‘tunnel’ that surrounds the twin wall. Was worried about any risk of fire what with kids and an all timber structure.
Cement board is cheap and easily available so might be worth experimenting with?
