  • entries
    42
  • comments
    207
  • views
    111221
Overheating
Well, finally after years of iterations of drawings in the pre-planning and planning phases we're off to the races! Before I post the final plans I was talking to the Architect today about the potential for overheating shown by the PHPP calculations. I'm going for a Passive House and my concern was rising global temperatures (during the build and more likely afterwards!). The PHPP package allows for 10% of days where the internal temps can rise over 25 degress celcius. That's a lot of days! Not so comfy! The Architect initially aimed for 5%.
We delved into it a bit further and I challenged them to improve on this. I did discuss the 3M film which cuts down on long wavelength IR, i.e. drops your Windows G value right down and no more overheating, but, you don't get solar gain in the cooler months either! Bit of a tradeoff. The G values they are using for me currently are 0.6. Other U values are as follows (based on timber framed construction): Floor = 0.12, Roof = 0.1, Walls = 0.125, Doors = 0.96, Windows = 0.84 (These are just placeholders but fairly typical and not hard to meet)
I get an A2 rating from the DEAP package which is my preliminary BER. To meet Part L I need one, yes "1" solar PV panel, go figure! Add 5 more panels and I go up to an A1 BER rating, the highest. This assumes a standard Heat Pump and MHRV etc.
I'll investigate Passive House Plus / Premium at a later time as that encompasses energy consumption & renewable generation. I should fit 8 panels on the roof comfortably, I'm hoping for more in the back garden at some point.
Anyway, what was I on about - overheating! 5% was a bit high given that when I asked them to switch the climate data from Dublin to London it shot up to 13%. Scorcher! By 2050 I wouldn't be surprised if that was the result for this house without a physical move! I want to build for more than today and one generation. The 5% figure is based on having internal blinds on both the rooflights and south facing windows,  and opening the windows in the evening to cool down the house if I understood correctly. And that's if you're home during the day otherwise if you forget to pull the blinds you'll be roasted coming home. The MHRV can help a bit but just can't deal with the heat load on a really hot day. I needed to find out what were my options and get that % right down....
I'd read here about the successful use of 3M prestige window film. It drops the G value in half which denotes the level of solar gain the window lets in. The only drawback is while you're cooler in the summer you'll pay for that in winter = less solar gain when you really do want it! It still might be useful for one or two windows and certainly if the temperatures soar over the next decade or two worth introducing then.
External shutters are very common on the continent but rarely used in Ireland. As it's the front of the house this could be a planning battle but is it one worth having? You would have to go back to the planners later if so.....
Brise Soleil if I've spelled it correctly are those overhanging louvres that are angled to block the worst of the summer sun. With these in place and this is the strategy the Architect is aiming at, it reduces overheating periods to 2%. Then if you start opening windows etc it get's it down to 1%. Blackout blinds are available for Velux rooflights but while they can be motorized, they aren't automatic. Even though the roof lights are on the north facing side, the angle of the summer sun will bring in light and associated heat during the peak months.
Internal blinds are of course most likely mandatory but unless they are also automated, they might miss the period of time that would prevent an overheating event.
So, right now we're looking at Louvres and internal window blinds. I did see some nice external blinds but these would have to take the weather and I'm not sure if outward opening windows would be compatible? Inward opening windows I feel would leak over time as the seal is pushed in with wind/rain over the years. But that's a different discussion!
The front of the house faces just off south at 204 degrees. There's a zinc half porch over the front door and glass window beside it. The windows themselves are tall rather than wide so I'm not sure the Louvres will offer as much protection during the shoulder months but that's probably for the best. The PHPP package was used to drive the 2% with the proposed Louvres size so as long as they stay on the house and don't fly off in the wind, they are probably the solution I'll stick with. Unless the planners have their say!
Maybe all I need is electrical windows that darken with a switch....!
9 Comments
Recommended Comments
gravelld
Seems to me the obvious solution if space allows is external shading.
Sounds like you're well on the way already but what about some crazy, "statement" overhangs to the south elevation?
Personally I'm not comfortable with the Ph overheating allowances... Remember it's an average too, not what the overheating is in one specific room...
Bitpipe
We have integrated Roma external shutters on the east (street) facing windows and they are a godsend. All east and south Velux also have external blinds.
Otherwise our passive standard house would really overheat. We also open the velux at the top of our stairs/atrium for some stack ventilation
Should have put blinds on one GF south window in kitchen, we left it out as it faces neighbours gable end but still lets in a lot of heat.
Jude1234
How much were the Roma external shutters?  Some of our bedrooms face east so will get the early morning sun, we are looking at options for blackout.  These rae normal windows not roof windows
Bitpipe
Hard to say as they were fitted to our Gaulhofer windows in the factory and were priced into the quote.
We had to have a detail in the wall to allow for the blind box (effectively a notch cut out of the frame) but when installed, the box was flush to the external wall and we rendered over the top, so when they're recessed (which is not very often tbh) they disappear completely.
We just went for simple electric control, using 240v wall switches. They do a more pricey remote option.
@jack did separate blinds so he may have a better idea of cost.
jack
Actually, although they didn't come preinstalled to the window like yours, they were priced and  supplied together, so I don't have separate prices.
Also, while they're excellent for keeping the heat out, don't rely on them for completely blocking light. Ours let through a surpassing amount of light through their sides and the holes for the tapes.
Gone West
Don't forget that except for glazing facing between SE and SW which sees the sun all year round the other potentially problem glazing in the summer won't see the sun in the winter. Therefore putting a film on those windows won't affect solar gain in the winter. We have a glazed gable which only sees the sun for four months of the year (mid April to mid August) and we have had a film put on it which has reduced overheating massively.
NSS
Windows that darken, and you don't even have to press a button (though you can do that too) B|
Edited by PeterW
mike2016
So, after talking to the Architect and a Passive House expert we've added louvres above the upstairs windows as already mentioned and plan to add one more above the downstairs bedroom. I'll look into planting a deciduous tree in the front garden to block the midday summer sun just as it's getting stronger. I've also asked about an overhanging front roof / extending the zinc porch over the downstairs bedroom window as an option/feature. I got the window sizes and they made both side and front doors glass which is not a runner so that will help when they are removed from those overheating calcs. I might tinker with the G value on the bathroom window (downstairs) but we'll see.
The Architect modeled the house with an ASHP and alurads. I've been assuming underfloor heating but there's little need, about 500w max to keep 20oC when it's -3oC outside. The house is only 108 meters squared. I'm still keen on the SunAmp with underfloor as it gives me the full thermal storage for hot water if I don't use it for heating the house which is nice. I'm not currently planning an ASHP so will see how I go after 12 months without it. It was suggested to have removable louvres so you only put them up in Summer which is a nice idea!
Thanks for all the suggestions and all good comments, great that there's lots of options and I hope this will help others with their range of choices too.
