By using SIP (both walls and roof) will I end up with a short-ish decrement delay on account of the insulation layer being polyurethane ?
I am comparing SIP against TF and am assuming that U values and air tightness (with a good TF supplier and installer) will be comparable for purposes of comfort factor.
Timber frame usually achieves it's air tightness by having an air tight layer on the inside of the frame. In my case that is standard OSB then an air tight membrane with taped joints, other systems use an air tight board with taped joints.  Insulation on a timber frame is whatever you make it, how thick do you want the frame?
Installing the insulation in a timber frame can be a DIY job that reduces the cost down to just the materials.
The simple answer is yes, the decrement delay with the typical low heat capacity foam insulation used in SIPs panels will be pretty short.
As @ProDave has written, though, timber frame can have many different types of insulation, so can be designed to have pretty much any U value and decrement delay you wish.  Airtightness can be designed in, too, to save work in having to do a lot of sealing work afterwards.
I am using SIP for roof and walls.  It is my intention to use the 142mm panels and then add 70mm internally to bring the U Value down to around 0.11.
When I looked at decrement delay it came out at around 11hours.  Shorter than say blown cellulose, but still sufficient to iron out any temperature swings.
You don't need an VCL with SIP but I intend to tape the joins of the internal foil backed insulation to create one - belt and braces.
Interesting, as that's pretty much the decrement delay for a brick and block wall with a 200mm cavity, filled with rockwool.  SIPs, with a PUR core and a single brick skin seems to come out to a lot shorter time when I calculate it.
What's your wall build up, out of interest?
Careful what tape you use.  I was wiring an extension recently and noticed a lot of the silver tape just peeling off with very little adhesion.  I think it is vital to make sure you use a good tape and ensure the surface is clean and in particular free of dust before applying  the tape.
How are you planning to tape the back of a joint once it’s up against the wall ...??
I have just checked and I ran the calculation on ubakus and sure enough I have the phase shift as 12h.
I am no expert and I may be doing something wrong but the wall build up I have is:
Plaster board
Stationary air unventilated
Vapour barrier (the foil face of the pur with joins taped)
80mm of TW55
OSB
112mm of PUR
OSB
Breather membrane
Ventilated gap 50mm
Block work
Render
I assume by phase shift of 12hrs this means the decrement delay?
Edited by LA3222
Typo
I will certainly look to use a 'quality' tape - not an area I wish to try and save a few pennies!
I may be missing something here but surely I can have the foil face outwards so I simply tape the foil joins with foil tape?
That’s what I did.
Make sure you clean any dust from the foil face before using the tape.
Plaster board
80mm of TW55
OSB
112mm of our
OSB
Breather membrane
Ventilated gap 50mm
Block work
Render
I make the decrement delay of that build up, using the standard  method (values of Y and k calculated using EN13786/EN13790) about 6 hours.
Sorry ..! Read it as foil backed plasterboard ....
Toolstation foil tape is very good.
5 hours ago, ADLIan said:
Software I use gives a decrement delay of just over 12 hrs for that construction
Interesting that you say this @ADLIanas that is what the site I went to calculated it as.  I may be doing something wrong though - I'm certainly no expert.
  • 2 weeks later...
Thank you all. I wonder what the discrepancy is between the two calculated decrement delay values for the same build up. If I decide on the SIP route I could perhaps look at augmenting the 200mm SIPs with some external sheathing to lengthen the delay and bolster the U-value also.
