PeteTheSwede Posted April 2, 2019 Share Posted April 2, 2019 Hi all I'm trying to decide on the best location for the unvented hot water tank, 300l capacity. I would rather it was in the loft out of the way, but the plumber wants it in the Utility on the ground floor. There is also a compromise location possibility in the ensuite on the first floor. Other than obvious access issues, are there particular issues with having the tank in the loft in terms of water pressure or anything else? For context, we will be having wet UFH downstairs, and radiators off manifolds upstairs. One shower downstairs, and a family bathroom (with shower over bath), and ensuite (shower) upstairs. Fed off a normal gas boiler. Thanks for any advice Peter Link to comment Share on other sites More sharing options...
ProDave Posted April 2, 2019 Share Posted April 2, 2019 The 2 things to consider are making the hot water pipework from the cylinder to the taps as short as possible. So try and get the tank central to all points of use. And you will need a D2 vent pipe to discharge water in the event of a fault, that usually goes to a drain outside (though can via a waterless trap go to an internal stack pipe) That may make for example a ground floor location close the the centre of the house impossible. Link to comment Share on other sites More sharing options...
Russell griffiths Posted April 2, 2019 Share Posted April 2, 2019 How about it’s weight, are the timbers up there designed for the extra load. Link to comment Share on other sites More sharing options...
scottishjohn Posted April 2, 2019 Share Posted April 2, 2019 (edited) I used 3/4"ply on top of chipboard in the cupboard where 300 litre tank was fitted to spread the load better maybe a problem in new build --all beams seem very skinny Edited April 2, 2019 by scottishjohn Link to comment Share on other sites More sharing options...
PeteTheSwede Posted April 6, 2019 Author Share Posted April 6, 2019 Thanks all. All options would be fairly close to an outside wall, so that probably is ok. I suspect weight issues could be managed. The plumber told me he wants to use a distribution pump on a timer to ensure quick access to hot water. Is that a good idea? This appears to be irrespective of where the tank is located. Do you think the risk of leakage is significant enough to warrant having the tank on the ground floor just for that reason? Thanks Pete Link to comment Share on other sites More sharing options...
PeterW Posted April 6, 2019 Share Posted April 6, 2019 6 minutes ago, PeteTheSwede said: The plumber told me he wants to use a distribution pump on a timer to ensure quick access to hot water. Is that a good idea? This appears to be irrespective of where the tank is located. Don’t use a timer - use a PIR in the bathrooms and run the feeds to the kitchen / utility in 10mm as they don’t need the flow. Link to comment Share on other sites More sharing options...
Bitpipe Posted April 6, 2019 Share Posted April 6, 2019 20 minutes ago, PeterW said: Don’t use a timer - use a PIR in the bathrooms and run the feeds to the kitchen / utility in 10mm as they don’t need the flow. This is what we did - spark also made the pump run on bathroom light switch - same circuit activates MVHR boost... Just make sure pipes are all well lagged to minimise heat loss on the return circuit. Link to comment Share on other sites More sharing options...
