Hi
Need some advise
My Architect has specified 70mm thk. Kingspan Kooltherm K103 which has a U-Value of 0.17.  I was think about using 150mm with a U-value of 0.1 but is it worth the extra money.  It is about double the price for the 150 mm
I am having under floor heating down stairs
thanks
70mm is bare minimum and just meets regs. You can get 100 as seconds, do it 200mm thick and you’re laughing. It’s definitely worth doing.
Insulation costs just once but pays back each and every year.
I would say yes, upgrade it, for three reasons. Energy and so ££ saving. A more constant (and so comfortable) internal environment. Improved sound proofing.
Value airtightness too.
You evidently know about things if you are quoting U-values. If you haven't done so, consider thermal modelling of your building, even just a little. PHPP or Jeremy's spreadsheet. It can be revealing.
Edited by Dreadnaught
Also consider the cost and ball-ache of fixing it later. We will probably have to fix the current just-passing-regs walls in the future.
FWIW SAP says the difference in central England is about 4.4kWh per m2 per year
Mine was also 70 mil
Spected by the architect Which I found strange As he was so precise on the type of block and u values
We put 150 kingspan down Main reason behind was that it is one of those things that you can never change at a later date
ie £20-50 ish pa for a 100 sqm floor area, depending on your heating.
F
