Ian put the phone in airplane mode  and get them boards stuck down.  Was going to say your over thinking this bit but you know!!!
Some body mentioned putting it in a bucket with warm water so try that if your worried.
1 hour ago, recoveringacademic said:
..... it says not to be used at < 10 centigrade.
Ambient or the glue itself?  Is this a summer-time only glue?
Just in case, I've left our tubes cooking gently on the window cill....
Here's the Product Details sheet which implies ambient temperature
it means air temperature of < 10 centigrade.
The issue is that it will take longer to dry at low temperatures. It's water based so the risk with the weather we've been getting this week is the sudden drop in temperature after sunset. Water based products don't perform well as it gets close to freezing.
Edited by Ian
Having been using this exact product today I can add some absolutely essential information when using this product
if you are not wearing gloves and you get a fair bit on your fingers, do not then decide to put your gloves on
it does make it a fair bit awkward to remove your gloves later in the day. ??????
  • Haha 2
