As my building settles and the newly skimmed plaster dries out, the usual hairline cracks are appearing here and there, mostly along beading lines.
Whilst my scaffolding is still up in here, is there anything I should do about these, or should I just live with them a while and revisit once the building has settled some more?
I think it is worth waiting a year, unless there are bits that will be a real pain to get to later on (like your swimming pool ceiling or the tiger enclosure).
Yes best to wait
But when you fill them
You will need to make them bigger
Press a screwdriver or blunt paint scraper to make a V All the way along the crack and will stop them re. cracking
Nearly a year on and I have lots of cracks, mostly at the corner beading but some along the ceiling.  Going to be @ b*****r to get them all invisibly mended.
Sadly there doesn't seem to be any way to prevent cracks developing in the first year or two after a new house has been built, be nice if there was.  We've now owned three new houses since 1992, and all suffered from cracks in the plaster in the first year or two.  Doesn't seem to matter what the construction method is, either.  It was clear that our last house had been (badly) repaired where old cracks in the plaster hadn't been properly filled, and that was block and brick with plastered block internal walls.  I spent ages going around raking out badly filled cracks when we first bought that house, and cursing the Polyfilla maniac who had just gone around smearing the stuff over the top then painting it.  If only they'd done it properly, and vee'd out the crack, filled it, sanded it smooth and then painted it I'd have not have had to spend a couple of days fixing things properly.
Always lots more cracking on TF
Timber stud wall are a real problem Even on block
Mf doesn’t  shrink or move
We also add a deflection head to allow some lateral movement
We have to allow for a 100 mill of lateral movemt on some of the warehouses
If you get I-------- windows your frame will have done all its moving before they have finished the install!
  • Haha 1
Glad to hear it's not just confined to block built houses. Some of these boarders are rough too joining boards in line with window reveals
