Better type of expanding foam
Russell griffiths
Morning all
I’m building in icf block, so main material is eps panels, I have a few gaps joins that I need to fill
i have been using a standard gun grade low expansion foam supplied by the block manufacturers but I’m not happy with it, the surface of the foam is not very UV stable and becomes a bit dusty and brittle, I also don’t like the air bubbles in the foam.
so is there a better product, I would be happy with no expansion just to be able to push into the gaps out of a gun or mix and push in with a spreading knife.
What ya reckon peeps.
is this to stop leakage on concrete  pour day ,or to replace missing insulation layer.
you could always apply a bit of render to fill the gaps?
 It is one of my possible reasons for  not going down poly ICF route ,once i get to that stage -
-you can,t really keep doing it in bits and leaving it for months  without UV causing surface degradation  like you could with velox or durisol
I dumped a durisol block in water totally submerged it for a day --then lifted it out and it took about a day to dry out again.        that could of course could be a worry if durisol got totally soaked then it froze?
expansion of ice I suppose could damage the block possibly ?
always compromises
Edited by scottishjohn
2 hours ago, Russell griffiths said:
Morning all
Bubbles is due to speed of expansion - if you use a gun, turn it down so you get a very slow bead with the trigger pulled tight and you’ll find it gives more foam to gas so the foam is more solid.
  • Thanks 2
A Durisol block is 86% air.
I have had 'raw' Durisol exposed to all weathers for far longer than expected.  Frozen while soaked too. I still have a stack of spares outside, uncovered for just over two  years
Nada. Nichts. Nothing. Rien.
Boringly inert.
Boringly inert.
thats good to hear
