Dudda Posted December 20, 2018 Posted December 20, 2018 One of Google's Project X moonshots, Malta, uses an idea similar to SunAmps to store heat energy which can be then used to generate power. It takes excess PV or wind energy and converts to heat storage. This stored heat energy is then converted back to electricity when required. As Google is behind this and it has a lot of funding it could really help develop the heat battery storage market. I know they're concentrating on large scale at high and low temperatures but the research and development will help with smaller domestic scale uses. https://venturebeat.com/2018/12/19/alphabets-x-lab-spins-out-molten-salt-energy-storage-project-malta-as-an-independent-company/ https://x.company/projects/malta/ 1
scottishjohn Posted December 20, 2018 Posted December 20, 2018 I saw a different way which looked far more appealing .uses old mine shafts basically a crane which lifts huge barrels up from bottom of shaft and then puts them on a ledge -this is powered by excess power for wind turbine .etc when they need the power it hooks on the barrel and then drops it back to bottom of shaft ,but this time its generating electric from weight of barrel lowering down . Imagine a big mine shaft full of barrels and cranes --simple way to store energy with without new technology
Onoff Posted December 20, 2018 Posted December 20, 2018 Mine shaft...isn't that @recoveringacademic's pet name for...
PeterW Posted December 20, 2018 Posted December 20, 2018 40 minutes ago, scottishjohn said: I saw a different way which looked far more appealing .uses old mine shafts basically a crane which lifts huge barrels up from bottom of shaft and then puts them on a ledge -this is powered by excess power for wind turbine .etc when they need the power it hooks on the barrel and then drops it back to bottom of shaft ,but this time its generating electric from weight of barrel lowering down . Imagine a big mine shaft full of barrels and cranes --simple way to store energy with without new technology Energy Vault have got that in a pre production form now. Uses remote cranes and concrete blocks. https://qz.com/1355672/stacking-concrete-blocks-is-a-surprisingly-efficient-way-to-store-energy/
Onoff Posted December 20, 2018 Posted December 20, 2018 Aren't the Spanish already storing heat in molten salt heated by focused solar? Continues to produce at night too albeit at a lower level.
ToughButterCup Posted December 21, 2018 Posted December 21, 2018 10 hours ago, Onoff said: Mine shaft...isn't that @recoveringacademic's pet name for... Naaahhh, that's Mein Kampf ya twit.
Mackers Posted December 21, 2018 Posted December 21, 2018 On 20/12/2018 at 19:33, scottishjohn said: I saw a different way which looked far more appealing .uses old mine shafts basically a crane which lifts huge barrels up from bottom of shaft and then puts them on a ledge -this is powered by excess power for wind turbine .etc when they need the power it hooks on the barrel and then drops it back to bottom of shaft ,but this time its generating electric from weight of barrel lowering down . Imagine a big mine shaft full of barrels and cranes --simple way to store energy with without new technology https://www.gravitricity.com Was it the above?
scottishjohn Posted December 21, 2018 Posted December 21, 2018 (edited) 58 minutes ago, Mackers said: https://www.gravitricity.com Was it the above? yep and i saw the other type which was barrels lifted by cranes. been spending far too much time trolling web for building and energy ideas that may be practical Edited December 21, 2018 by scottishjohn
Mackers Posted December 24, 2018 Posted December 24, 2018 There is another about pumping water to lift a weight, similar to Gravitricity but using water. Flow batteries seem good too but I need to do more research. They should use materials that are abundant, I see Vanadium costs are now through the roof.
Temp Posted December 26, 2018 Posted December 26, 2018 Problem is gravity is quite a weak force so you need to raise quite a lot of mass to store lots of energy. This lot are proposing to use loaded trains on sloping tracks... https://www.aresnorthamerica.com/grid-scale-energy-storage
scottishjohn Posted December 26, 2018 Posted December 26, 2018 but there is a lot of gravity around to make use of, anywhere in the world. same goes for tidal power --trouble is the "money men " want returns quickly which is why the wind farms with government subsides was so popular and pushed through by the bent pocket lining political machines of most countries, that will change when money from governments stop same goes for EV cars instead of hydrogen engines or lpg conversions for all diesel vehicles in cities -all buses _taxis have space under vehicle for tanks . they know how much energy required for a day --could have had clean air in cites 30 years ago we have been able to convert std engines both diesel +petrol to lpg for last 40 years - south African diamond mines have been running lpg cat D8 for 4o+ years -only solution then to get the power and not kill all the workers with exhaust fumes so its not technology that is missing --just some way for the banks +investors to make huge amounts money out of it . nuclear power is dead ,cos of cost of recycling + clean up now if someone can make a BIG gun and shoot barrels of waste into the sun economically .LOL
