Not sure if there is a standard detail for this but if there is it will require you to block the end of the joist and take the main load underneath the bottom flange.
Edited by MikeSharp01
  • Like 2
That sketch is missing a bit of info, I’m thinking that the junction of the two timbers is sitting on top of a wall plate fixed down to your wall, so as has been said the jji joist will need end blocking to stiffen it up and take the load, I would then treat it as a solid timber, so your rafter will need a birdsmouth over the wallplate and then you can use heavy gauge construction screws to secure them both together or coach bolt through the web stiffeners and through the solid rafter, we used to use a funny washer with spikes on it to stop rotating forces
you will also have a nailable hold down plate on the side of the i joist.
Has this not been covered by the roof designer ?
my roof design has all the truss clips  and joist hangers marked on it.
Who are you getting your ijoists off, I’m  just getting quotes and there a bit pricey compared to solid timber.
Edited by Russell griffiths
12 minutes ago, Russell griffiths said:
That sketch is missing a bit of info, I’m thinking that the junction of the two timbers is sitting on top of a wall plate fixed down to your wall, so as has been said the jji joist will need end blocking to stiffen it up and take the load, I would then treat it as a solid timber, so your rafter will need a birdsmouth over the wallplate and then you can use heavy gauge construction screws to secure them both together or coach bolt through the web stiffeners and through the solid rafter, we used to use a funny washer with pokes on it to stop rotating forces
whats the attraction of them if they are more expensive?
For me it’s the fact they are straight and true in the longer lengths, they also stay straight once fixed
i have been looking at 225x48 in 4.8 m lengths and although they look very nice the thought of twisting and getting ceiling cracks is something I want to avoid
you mean you do not have to fit "dwangs"  as they call them up here ,or noggins as they say in england
Edited by scottishjohn
That’s racist :/
We call them noggins too boyo. ;)
I would have thought if you are not too stingy with the noggins and board the floor at same time then there is little chance of them getting out of shape
1 hour ago, Nickfromwales said:
Anything in here?
Nada, will bung them an email tomorrow.
Yep that's what I'm imagining. I would also think the top flange would need supporting to prevent any rotation
The wall plate is lower. The rafter sits on the wall plate in a traditional way.
The SE has said select joists from a standard span table. They are not part of the roof structure just ceiling joists. But the span is 6750 so solid timber isnt really an option.
Most joists will have a stud wall or two to bear on but as these aren't structural I don't want to rely on them (might change layout one day). Also its only an attic with low loading. It doesn't need to be future proofed for a loft conversion; ridge height is too low, oh and the bats have priority!
Just exploring options really and thought Id see if JJI was a possibility
That’s a lovely shape and could be triangulated simply by a truss manufacturer to make it into a single span truss. You would only then need wall plate detail.
Very true but Mr Ecologist has specified 'open loft space' cant be crowding the bat roost with trusses. Even an attic truss wouldn't satisfy. Lord have mercy!
I did a roof like that years ago, but with solid timber
so I think I would treat the I joists like solid timber
install blocking to both sides of the i joist then install those funny washers with the spikes on between the solid timber and i joist and bolt together
cant remember what the washers are called, but they are meant to stop rotating between the timber.
I cannot see the difference between an antic truss and what you have drawn up.
