vfrdave Posted November 26, 2018 Posted November 26, 2018 My house is recently plastered and I have noticed that we have some mould appearing largely on areas that are plasterboard behind and some tdoor frames. I have tried to keep the place ventilated as much as possible to allow for drying. What should I do with this or how should I treat before painting.
scottishjohn Posted November 26, 2018 Posted November 26, 2018 (edited) new house or renovation? you gotta dry it out before anything --check plaster with moisture meter dehumidifiers?--turn on the heating ? Edited November 26, 2018 by scottishjohn
ProDave Posted November 26, 2018 Posted November 26, 2018 Dehumidifier and mvhr on if you have it. We were painting 2 days after the plasterer left it dried so quick.
vfrdave Posted November 26, 2018 Author Posted November 26, 2018 It is a new house. There is no provision for heating as yet and only temp electrics. Mvhr is has not been 2nd fixed as yet.
PeterW Posted November 26, 2018 Posted November 26, 2018 Industrial dehumidifier will sort it - need to get the humidity down asap as the mould spores in the plaster will cause issues. A dehumidifer should have its own small heat source in it - we use sheets of 25mm insulation over doorways to stop the heat loss into other areas and run them a room at a time.
vfrdave Posted November 26, 2018 Author Posted November 26, 2018 How do I get rid of the mould that is already appearing?
PeterW Posted November 26, 2018 Posted November 26, 2018 Mild bleach solution in a spray bottle. How long has the plaster been up for ..?
vfrdave Posted November 26, 2018 Author Posted November 26, 2018 (edited) 1 minute ago, PeterW said: Mild bleach solution in a spray bottle. How long has the plaster been up for ..? Probably been up about 8 weeks or so. Edited November 26, 2018 by vfrdave
PeterW Posted November 26, 2018 Posted November 26, 2018 Should be dry - I would get a couple of industrial dehumifiers for a week and get the place properly dried out then bleach solution before any paint.
Mr Punter Posted November 27, 2018 Posted November 27, 2018 Agreed with the above. We had a flood from the 1st floor in a completed unit and went for doors and windows closed and industrial dehumidifiers and radiant heaters on full blast for a couple of weeks. It limited the damage and there has been no mould growth, just redecoration.
Declan52 Posted November 27, 2018 Posted November 27, 2018 It's just one of them things that happens this time of year. It's been miserable this last few weeks with it being cold and wet so your walls are drying out but have no air flow or heat too evaporate the moisture away. A Dehumidifier will aid this process along. As above a mild bleach and some elbow grease will take it off no problem.
