worldwidewebs Posted July 27, 2016 Posted July 27, 2016 We have an SVP running through a stud wall - I believe the SVP is 100mm and the stud wall is 127mm internally. What's the best approach for implementing appropriate acoustic insulation?
Barney12 Posted July 27, 2016 Posted July 27, 2016 I think I'd just be ramming the space with rock wool/ glass fibre as you not really got much to play with. Or you might get away with a rock wool tube wrap: https://www.pipelagging.com/product/588/Rockwool-Rocklap-Foil-Faced-Pipe-Insulation-Lagging-1-metre-Lengths
PeterW Posted July 27, 2016 Posted July 27, 2016 Sound insulation needs low density insulation rather than solid insulation that transmits sound. Pack it around the pipe but not too much as otherwise you will transfer the pipe sounds to the wall ..!
warby Posted July 27, 2016 Posted July 27, 2016 15 minutes ago, PeterW said: Sound insulation needs low density insulation rather than solid insulation that transmits sound. Pack it around the pipe but not too much as otherwise you will transfer the pipe sounds to the wall ..! Somewhat surprised, I thought the higher the density of the insulation the more effective the soundproofing. Is this wrong?
worldwidewebs Posted July 27, 2016 Author Posted July 27, 2016 If you had more space to play with, what would you use as insulation? My architect is like bloody molasses and I want to get the MBC drawings signed off asap so I'm doing his job for him and trying to determine whether I would be better having a wider stud wall or whether the standard depth is ok
daiking Posted July 27, 2016 Posted July 27, 2016 Is there anything you can add to with the wall surface locally? Sound bloc PB? Double layering?
worldwidewebs Posted July 27, 2016 Author Posted July 27, 2016 Yes, I could use acoustic plasterboard. Is this better than putting something around the pipe?
daiking Posted July 27, 2016 Posted July 27, 2016 (edited) 13 minutes ago, worldwidewebs said: Yes, I could use acoustic plasterboard. Is this better than putting something around the pipe? I don't know! I was thinking both. But theres 2 parts to the wall and you were only think about the gap. Double layers and sound bloc get used on ceilings so it must have some use. what about sound deadening materials such as used in cars? Applied to the pipe? Edited July 27, 2016 by daiking
Nickfromwales Posted July 27, 2016 Posted July 27, 2016 Sound deadening mat is the way forward. I tried completely surrounding a soil pipe with expanding foam in a hotel, but it was next to useless. Acoustic wool ( dense rock wool ) in conjunction with something like recycled rubber floor matting ( sound deadening layers for floors ) will reap rewards. The rubber to deal with the lower frequency, the wool for the higher, and then 2 layers of sound control ( acoustic ( blue )) plasterboard will be a good solution IMO. That'll leave the stud work at the same depth, but allow for the two layers of PB, both sides if it's a dividing wall. 1
PeterW Posted July 28, 2016 Posted July 28, 2016 12 hours ago, warby said: Somewhat surprised, I thought the higher the density of the insulation the more effective the soundproofing. Is this wrong? The key is separation - dense insulation is fine but if you pack it between the pipe and the wall then the wall panel acts like a big speaker panel. Probably didn't make that bit clear ..! I would have thought your SVP was 110mm too - are you going to get it into the wall at all ..?? Boxing in may be your only option which means you can pick a decent insulation and sound control strategy.
worldwidewebs Posted July 28, 2016 Author Posted July 28, 2016 3 minutes ago, PeterW said: I would have thought your SVP was 110mm too - are you going to get it into the wall at all ..?? Boxing in may be your only option which means you can pick a decent insulation and sound control strategy. I just asked the designer at MBC how big the pipe was and whether there was space for both it and the sound insulation and that was the information he gave me. He could well be wrong and you be right! I think in terms of space, I need to make the wall thicker. Then it's a case of which method is most cost effective but I think the acoustic plaster board might as well be the first decision. 1
Mikey_1980 Posted July 28, 2016 Posted July 28, 2016 If you make it wider, and there is a door in that wall make it so you can buy off the shelf door liners to fit the width, it will make you your life easier.
Bitpipe Posted July 28, 2016 Posted July 28, 2016 We have made a feature of quite a few boxed in soil pipes - faux fire place, alcoves etc. Personally I'd try and get a bit more space around the pipe if possible in the design.
duncgee Posted July 28, 2016 Posted July 28, 2016 Thinking outside the box, ha ha. Why not put the SVP outside the house?
worldwidewebs Posted July 28, 2016 Author Posted July 28, 2016 2 hours ago, duncgee said: Thinking outside the box, ha ha. Why not put the SVP outside the house? Nooooooooooooooooooooooooo....
PeterW Posted July 28, 2016 Posted July 28, 2016 3 hours ago, duncgee said: Thinking outside the box, ha ha. Why not put the SVP outside the house? I may have that exact issue - having to put it outside as inside would require hacking through a reinforced slab and a wall .....
TheMitchells Posted July 28, 2016 Posted July 28, 2016 Its something we are thinking of too for our renovation - moving a bathroom upstairs but where does the soil pipe go? Down through the floor into the corner of the lounge and then outside or take it outside and run it down the front wall but that would not look nice. If we can minimise the sound using the advice here, maybe down throughg the lounge would be okay. Let me know how you get on, worldwideweb.
daiking Posted July 28, 2016 Posted July 28, 2016 Mine comes down through the downstairs WC so noise is not really a concern. And no worse than any other peculiar sounds you get in the house. I was more concerned with thermal insulation as the stack is open to (cold) air.
Bitpipe Posted July 28, 2016 Posted July 28, 2016 I have a friend who completed an extension about 12 months ago. They have about 3 feet of a horizontal soil pipe in their living room, connecting the existing upstairs loo to the new soil pipe. They keep meaning to box it in but don't notice it anymore - I've suggested that they replace it with a clear plastic section as a conversation piece... 3
Nickfromwales Posted July 28, 2016 Posted July 28, 2016 2 hours ago, TheMitchells said: Its something we are thinking of too for our renovation - moving a bathroom upstairs but where does the soil pipe go? Down through the floor into the corner of the lounge and then outside or take it outside and run it down the front wall but that would not look nice. If we can minimise the sound using the advice here, maybe down throughg the lounge would be okay. Let me know how you get on, worldwideweb. I wouldn't sacrifice any internal space, or inconvenience with noise / sound tbh. Putting the stack outside and making it as neat and as inconspicuous as possible would be my recommendation. Once it's been there for a week, you'll not even notice it. Having the stack run through the living room isn't something I'd want. 1
Bitpipe Posted July 28, 2016 Posted July 28, 2016 19 minutes ago, Nickfromwales said: Even I'm stuck for words Wow, that's a first. Where do I claim my £5?
Nickfromwales Posted July 28, 2016 Posted July 28, 2016 I'll credit your technical support helpline account
ToughButterCup Posted July 29, 2016 Posted July 29, 2016 7 hours ago, Nickfromwales said: Even I'm stuck for words Sorry, that doesn't compute somehow.....
worldwidewebs Posted July 29, 2016 Author Posted July 29, 2016 8 hours ago, Bitpipe said: I have a friend who completed an extension about 12 months ago. They have about 3 feet of a horizontal soil pipe in their living room, connecting the existing upstairs loo to the new soil pipe. They keep meaning to box it in but don't notice it anymore - I've suggested that they replace it with a clear plastic section as a conversation piece...
