MattButt Posted September 16, 2018 Share Posted September 16, 2018 Hi all, A bit about our project - we have planning permission for a large-ish double storey side extension for our house in Hertfordshire. There is a single storey infill extension (block and brick) that I built in 2014, attached to and converted one of two detached double garages that were already there. I’m at the stage now where I’m researching different build types for the extension and am really drawn to the ICF and SIPs style of build, particularly Durisol. The problem I’m having is finding a structural engineer that isn’t going to charge me an absolutely fortune (£8000 the first quote!!) for an existing foundation review and design of a raft foundation so if anyone can recommend a good structural engineer with experience of ICF in particular I’d be eternally grateful!! I really get the impression that the professional services see that you’re a self-builder and add a zero onto their quote!! I’ve attached the existing and proposed elevations and the ground plan that shows the existing foundation make up. The existing flooring on the plan that shows the Family Area is block and beam, the kitchen and garage are a concrete slab on strip foundations and the utility area is proposed ie. hasn’t been built yet!!Any advice would be really appreciated!! Link to comment Share on other sites More sharing options...
Russell griffiths Posted September 16, 2018 Share Posted September 16, 2018 J Turner and associates speak to Anthony hes on holiday until the end of September, he was recommended by nudura who I am using, very pragmatic in his approach some over design so much to cover their arses, instead of understanding the system they are working with. Google them, if you struggle I can find his number later. Russ. Link to comment Share on other sites More sharing options...
ToughButterCup Posted September 16, 2018 Share Posted September 16, 2018 I don't believe we have met. Welcome! My build is Durisol. My SE is Hilliard Tanner, based here. One sentence in Hilliard's proposal for our foundation plan saved us more than double his fee. I can recommend his work on the basis of three years working with him. Durisol will also recommend you an SE : his expertise is in how to deal with Durisol issues - how to manage large lintels, corner details and so on. He worked for us FoC for some simple bits of work. Finally the local Durisol Rep will also know who to ask. PM me for details if you like. Link to comment Share on other sites More sharing options...
MattButt Posted September 16, 2018 Author Share Posted September 16, 2018 Hi @Russell griffiths and @recoveringacademic. Thank you so much for your advice, I really appreciate it. I’ll let you know how I get on and it is ok to PM you it would really help as it looks like you’ve both got amazing build stories! MB. Link to comment Share on other sites More sharing options...
Alexphd1 Posted September 16, 2018 Share Posted September 16, 2018 +1 for hillard, we used a local aberdeen engineer 1st who was as much use a chocolate fire gaurd! Our build is a insulated raft and nudara icf walls. Link to comment Share on other sites More sharing options...
ToughButterCup Posted September 17, 2018 Share Posted September 17, 2018 10 hours ago, MattButt said: [...] and it is ok to PM you [...] Of course. I'll give you my phone number and we can talk it through. Ian Link to comment Share on other sites More sharing options...
scottishjohn Posted November 12, 2018 Share Posted November 12, 2018 maybe i,m being a bit cavailer --but me, I would start with insulation below it and make it twice the thickness you think-you can always dig down to your exsisting found and see how thick that is --then make yours thicker --bit more concrete is cheap enough at this stage --you get alot of concrete for 8K- -scotland rule is founds are twice as wide as wall on normal ground ,wider if its soggy ,you can always drill and "rebar " it to exsisting found as well at that stage , brick tie brackets or full length angle plate on exsisting walls to secure your sips to them as well -job done, just my thoughts Link to comment Share on other sites More sharing options...
