1 minute ago, Triassic said:
I’m trying to build my house using the minimum number of tools. I used an old wood saw to cut the pipe and a Stanley knife to chamfer the pipe (hold it at 90 degrees to the pipe and pull the knife towards you).
Where's the finesse man? :)
I'd think a stanley blade is too thin. The back edge of it, or the back of an old jigsaw/hacksaw blade maybe? You're using it as a scraper after all.
Looking at mine , I think Stanley blades are not needed
it doesn’t cut and give off an apple peel type sliver
it sort of scrapes it off
i think a piece of stainless 2-3 mm thick sticking through the side so the pipe is a tight fit against the cutter
i think Stanley blades will be to brittle
3 minutes ago, Russell griffiths said:
Tbh I think the starrett cutter would be stronger with two blades mounted inside.
I did wonder about adapting my cavity master...
Sound! A triangular "wedge" of st/st sheet dropped into a slot hacksawed at an angle in the ply I think.
Edited by Onoff
Well it works!
IMG_20180827_155138800
IMG_20180827_155148432
Piece of random 1.5mm thick st/st sheet cut to a nom. 28x9mm "blade":
IMG_20180827_151836427
Corresponding slot cut at an angle in the ply:
IMG_20180827_151857591
Blade sticking out, (needed to cut a corresponding slot in the rib of the soil coupler):
IMG_20180827_152005053
However...
In use, as there's no clearance holes/slots for the swarf this melts / solidifies, then jams the thing up to the point it BENT the blade. I had to knock off this solidified lump:
IMG_20180827_154806312
IMG_20180827_155055171
IMG_20180827_155050614
I think too that the non cleared swarf is what scuffs the first few inches of the pipe.
Another issue is that when it jammed the nyloc that was a tight fit in the ply (last pic) whizzed around and rounded off the ply where it had been pressed in.
Video later, the phones dead
Would I use it? Maybe if I had a load to do but for a one off probably the grinder as usual!
Another one for the abandoned project pile! :)
Edited by Onoff
Could you cut that socket  down so that it is only 10-15mm longer than what the blade sticks out. Any swarf will fall out then won't mark the rest of the pipe.
Good shout. The brown soil fitting is I note a bit brittle but then it's been lying outside for a couple of years.
  • 4 months later...
@Russell griffiths
Very neat bit of kit.  I am going to need one at some point this year so thought I would take a look for one.  I don't think I am in the making one myself camp as we will need to use it alot.  What on earth is it called officially?  Do you know the ebay store?  Cheers.
