davidh72 Posted May 13, 2025 Posted May 13, 2025 https://www.theheatxchange.co.uk/vaillant-plug-coding-vai0020266328 And talked to an installer who says it seems to work fine.
JamesPa Posted May 14, 2025 Posted May 14, 2025 17 hours ago, LiamJones said: Just ordered the £5 VAI0020266328 plug. Thanks to those on this thread 🥵 I can confirm it worked on mine. There are a few obscure settings, most notably one about power company lock out, that need to be adjusted in the installer menu to get it working whether you have the part with the official part number or the one you refer to above. Openenergymonitor has a thread about this
JohnMo Posted May 14, 2025 Posted May 14, 2025 2 hours ago, JamesPa said: I can confirm it worked on mine. There are a few obscure settings, most notably one about power company lock out, that need to be adjusted in the installer menu to get it working whether you have the part with the official part number or the one you refer to above. Openenergymonitor has a thread about this Why do people bother with heat pumps that do not cool out the box? That is the only reason I bought mine.
JamesPa Posted May 14, 2025 Posted May 14, 2025 (edited) 11 minutes ago, JohnMo said: Why do people bother with heat pumps that do not cool out the box? That is the only reason I bought mine. In my case because the Vaillant was one of a very few that was a good fit to the many constraints, because I mostly have radiators with only one fancoil (I now wish I'd specified a couple more fancoils) so cooling was a anyway secondary consideration (sofaik it doesn't work with standard radiators because all the cold water just collects at the bottom so even if you add a fan there is insufficient surface area to make much difference), because I knew that it was capable of cooling and that the coding plug was available in Germany for about gbp40, and finally because I can alternatively keep my house cool even in summer by the low tech approach of closing the curtains. I wouldn't have purchased one that was incapable of cooling unless there was no alternative. Edited May 14, 2025 by JamesPa 1
Duncan62 Posted June 10, 2025 Posted June 10, 2025 (edited) https://www.theheatpumpwarehouse.co.uk/shop/heat-pumps/air-source-heat-pumps/samsung-heat-pumps/samsung-ehs-gen-7-r290-heat-pump-5kw/ Will this Samsung Gen7 cool out of the box? Edited June 10, 2025 by Duncan62
yngndrw Posted June 10, 2025 Posted June 10, 2025 40 minutes ago, Duncan62 said: https://www.theheatpumpwarehouse.co.uk/shop/heat-pumps/air-source-heat-pumps/samsung-heat-pumps/samsung-ehs-gen-7-r290-heat-pump-5kw/ Will this Samsung Gen7 cool out of the box? It appears so as the manuals and datasheet reference cooling. It also shows the required reversing valve in the refrigeration schematic. The installation manual also documents how to wire up an extra valve to shut off an underfloor heating circuit during the cooling mode. I couldn't say for sure if it just works out of the box or if it needs something extra; certainly Vaillant is quite quiet about the need for the "special" module. I can however confirm that the hardware is there for it. 1 1
