Between rafter insulation: tips, gottchas, if I were you I'd
ToughButterCup
Nice warm weekend ahead. Perfect for fitting insulation between rafters. We need to infill with 200mm of Balytherm.
Before I do so, anyone got any tips?
So far I have been told to
  • cut the sheets with a sharpened trowel or scraper (to avoid dust)
  • be sure to 'tie on' while waltzing around on the rafters
  • put a couple of temporary battens under the rafters and push the insulation down to them from outside (above)
  • foam round the edges of each rafter space, not each sheet (two lots of 100mm)
Then there's a BBQ on Monday evening, by when I hope the job will be finished. Everyone welcome.
Breaking my new 'never-at-weekends' rule, but his weather is too good to miss. too rare.
32 minutes ago, Triassic said:
What a horrible job,
Its the absolute pits man, i will be so glad when i am done with this stuff..... if i could have foreseen how horrid using this stuff was before i got commited i would have definatly gone another way. I always wear a propper PPE but its still hell.
