joe90 Posted March 15, 2018 Posted March 15, 2018 I am just getting round to installing my ASHP and involving my local plumber ( who will sign off the UVC). He has his own ASHP and when I mentioned flexi tails told me his was installed with solid pipework and he has no noise or other issues , what is the feeling on this subject?
ProDave Posted March 15, 2018 Posted March 15, 2018 I think it depends how the pipe run gets into the house. In my case, the pipes will travel a metre or so along the wall, into the garage, up inside the garage into the plant room above. I suspect that is a long enough pipe run with enough bends that I won't get any transmitted noise. If on the other hand they came straight in to a habitable room I would use flexi's.
jack Posted March 15, 2018 Posted March 15, 2018 I know @JSHarris had issues with noise transference when he used (from memory) short/tight flexis with his installation.
PeterW Posted March 15, 2018 Posted March 15, 2018 The vibration of any refrigeration unit causes slight issues with any pipe work unless it’s flexible. I don’t think I’ve seen a single MI that doesn’t say use flexis, even if it’s only an isolation from the unit to the fixed element of a few hundred mm. BES do large bore flexis up to 1500mm for less than £20 which makes install a doddle so I can’t see why you would use anything else ..?? 2
Jeremy Harris Posted March 15, 2018 Posted March 15, 2018 1 hour ago, jack said: I know @JSHarris had issues with noise transference when he used (from memory) short/tight flexis with his installation. Yes, I did! I stupidly ignored the manufacturers installation instructions, as it was neater to fit 300mm full bore flexis. There was massive amount of noise transmission into the house, so I swapped them out for two 900mm full bore flexis arranged in a U shaped loop, as per the manufacturers instructions, and this completely removed the transmitted noise. I can't now tell when the ASHP is on unless I either go outside or look at the control panel. 1
joe90 Posted March 15, 2018 Author Posted March 15, 2018 (edited) Thanks guys, comprehensive reply’s as always, flexis it is then. ( and they are easier to fit ?) is is this what I need? https://www.bes.co.uk/braided-stainless-steel-flexible-hose-3-4-x-1500mm-8131 Edited March 15, 2018 by joe90
joe90 Posted March 19, 2018 Author Posted March 19, 2018 On 15/03/2018 at 20:13, joe90 said: Thanks guys, comprehensive reply’s as always, flexis it is then. ( and they are easier to fit ?) is is this what I need? https://www.bes.co.uk/braided-stainless-steel-flexible-hose-3-4-x-1500mm-8131 Are these the right ones to order?
Jeremy Harris Posted March 19, 2018 Posted March 19, 2018 They look OK, perhaps a bit longer than needed, but they will do the job alright. I insulated mine with the thickest Armaflex insulation I could find, then wrapped that with the flexible reflective stuff, just to prevent damage to it really.
Nickfromwales Posted March 19, 2018 Posted March 19, 2018 Any unit that has motors or fans should have flexis fitted to combat the "transmission of vibration" to rigid or fixed pipework. Deffo go for the flexis.
joe90 Posted March 22, 2018 Author Posted March 22, 2018 I am struggling to find a supplier of the correct hoses for my Kingspan ASHP. the thread measures O/D 1 1/4 “ or 32mm. From my reading on tinternet this is a 1” BSP thread!. Also the original Kingspan manual shows their hoses as having a 90’ end ( like a washing machine hose). Also I would like them insulated if possible. Any heads up on suppliers would be welcome.
dpmiller Posted March 22, 2018 Posted March 22, 2018 Ask Kingsspan? Do you have all the other necessary install bits? If not this pricey option might not me such bad value- https://www.ebay.co.uk/itm/KINGSPAN-AEROMAX-12KW-AIR-SOURCE-HEAT-PUMP-INSTALLATION-PACK-KHP0030-ONLINE-778/162942848059?hash=item25f0268c3b:g:3ZEAAOSw~e5ZPr8X Bud I think someone opined that 22mm was plenty for loadsa kWs so maybe just reduce that 1 1/4" down to suit a more standard part.
joe90 Posted March 22, 2018 Author Posted March 22, 2018 Thanks, yes I saw that but don’t need half the kit and I was not sure if the 12kw model used the same kit!!
Jeremy Harris Posted March 22, 2018 Posted March 22, 2018 I just fitted an angled adapter to mine to allow me to use more readily available flexible hoses. As long as the bore is 19mm or so it should be fine.
