Tuesday at 17:332 days Just working out how much rigid insulation I’ll be needing for the roof/walls of my little Outer Hebrides project. Looks like it will be in the region of 59 sheets (2.400 x 1.200mm). Is there a rule of thumb or way to estimate how much 100mm silver aluminium tape I will need to get?
Tuesday at 19:192 days Could I suggest either that you don't use foil tape at all - use air-tightness tape - or that you buy one roll of foil tape from a number of different suppliers? I have had very mixed experience with the adhesive on foil tape. Much of what I have bought in the past I would not bet on for 10 years, let alone 60 (assumption for life of air-tightness tape).Re the length of tape I tend to draw it out if I don't just seriously over-buy, but I think if you allow 4.8m (1.2 + 1.2 +2.4) per board and then measure the whole perimeter of the room(s) and add it all up and then add 10% you should be about right.
Tuesday at 19:512 days As above from redbeard, foil tape is, generally useless. Some of mine fell off overnight. I did buy some "cold weather" foil tape. That was quite good.Airtightness tape is much better, though im sure as its become more widespread, theres crap versions of that too. The stuff i used as bonkers sticky!
Tuesday at 23:302 days I've used mountains of foil tape in the floor and ceilings and found it totally fine. Was left up on the ceiling for a year before I boarded and it was still stuck solid. As for estimating how much, I just bought a load of it and when I needed more just went and got it, no method in my madness.Just any old stuff from Screwfix worked for me, some has backing paper some doesn't. When you get in the zone and your technique down it just flies on.
Wednesday at 07:542 days Logically, if the boards are a bit dusty from trimming, or storage then adhesion can be an issue with foil tape, and if you try to use for bridging an angle, or gap it is easily punctured. I also used this Tyvek tape, bought a box of the stuff - brillant stuff, sticky and tough!
Wednesday at 08:122 days I used aluminium foil tape on my aluminium coated VCL and it stuck really well (cannot get it off easily well), have sections still exposed and 5 year later all good. However used exactly the same tape on PIR boards in the garage and it was very hit and miss if it actually stuck.. would say 90% was fine the other 10% I had to clean the contact areas.
Wednesday at 08:272 days I found that the stuff from SF was very poor. Not very sticky, very thin and fragile aluminium, but didn't come cleanly off the paper either. Perhaps they use varying sources then brand themselves.Otoh tyvek is super sticky.... and yet easier to use.. I got it at TP where they also had some unbranded... they assured me it was the same, and it did seem to be.The dearer stuff was better value.If you have any left you will use it elsewhere.Quantity? In the perfect world you use 3.6m per board on large areas. Being diy you should have minimal waste on boards, by using offcuts, but more tape.5% waste on board, 15% on tape?
Wednesday at 09:181 day I bought some of this the other week very similar to the stuff I bought 5 or so years ago. Nice and sticky and thick enough to be robust when installed.https://amzn.eu/d/04YOmIBN
Wednesday at 09:201 day my technique wash hang the foil on your belt. You cant cut it clean and then get it off the backing paper, you need to rip it. So id pull it out to length, fold it over on itself and then tear it. That leaves a rough/slightly exposed edge and you can simply peel the packing paper off. Its still a big job due to the square footage but i found it fairly satisfying.
Wednesday at 11:111 day I used screwfix foil tape and it was terrible, very thin and not very sticky. Then i tried SuperFoil which I found in Selco, more expensive but very robust and sticky.You get what you pay for and would use superfoil again.It’s hard to estimate a quantity as I found I used more in certain areas.
Wednesday at 12:351 day I bought loads, by the box full, ended way cheaper overall. Ended up with about 8 rolls left, now have none. It's also great for overwrapping insulation on pipes and will keep rodents off.
Wednesday at 12:461 day 9 minutes ago, JohnMo said:I bought loads, by the box full, ended way cheaper overall. Ended up with about 8 rolls left, now have none. It's also great for overwrapping insulation on pipes and will keep rodents off.Is that why pipe lagging has foil outter and foul tape? Does that thin piece of foil mean a rodent won't try to chew?
Wednesday at 12:581 day 1 minute ago, Oz07 said:Is that why pipe lagging has foil outter and foul tape? Does that thin piece of foil mean a rodent won't try to chew?Think mostly for external use and allows insulation to stay dry and not be UV damaged. But also rodents don't like chewing through aluminium that much, they will buy a simple first line of defense. Also use bait stations, which are the best method.
Wednesday at 15:141 day Author 7 hours ago, crispy_wafer said:Logically, if the boards are a bit dusty from trimming, or storage then adhesion can be an issue with foil tape, and if you try to use for bridging an angle, or gap it is easily punctured.I also used this Tyvek tape, bought a box of the stuff - brillant stuff, sticky and tough!Every day’s a school day, which is why this is such a useful forum :) So is this the Airtightness tape that’s been mentioned? Would this get the nod over decent sticky foil tape, assuming a decent/conistant brand is found?
Wednesday at 15:191 day Author 19 hours ago, Redbeard said:Could I suggest either that you don't use foil tape at all - use air-tightness tape - or that you buy one roll of foil tape from a number of different suppliers? I have had very mixed experience with the adhesive on foil tape. Much of what I have bought in the past I would not bet on for 10 years, let alone 60 (assumption for life of air-tightness tape).Re the length of tape I tend to draw it out if I don't just seriously over-buy, but I think if you allow 4.8m (1.2 + 1.2 +2.4) per board and then measure the whole perimeter of the room(s) and add it all up and then add 10% you should be about right.Yeah, I was wondering if Perimeter x number of boards + X% on top was the way to do it? At least it's a decent starting point, although with the roof, there will be more lengths of 2.400 to add into the mix, I guess, as each board will get cut down to size? Edited Wednesday at 15:391 day by Chris HB
Wednesday at 15:411 day Author Is 100mm width excessive, or am I better off looking at 75mm? Ultratape Rhino Aluminium Foil Tape seems to get decent feedback?Using Redbeard's suggested rule of thumb, 59 x 4.8 plus 10% gets me around 300m of foil or airtightness tape; does that sound about right? Edited Wednesday at 15:421 day by Chris HB
Wednesday at 16:081 day 19 minutes ago, Chris HB said:Is 100mm width excessive,No, but I found 75mm was fine for what I used it for.21 minutes ago, Chris HB said:59 x 4.8Does that account for all butt joints and small off cuts you may have to add to certain sections to fill the area. +10% - is 311m - I would buy 7 maybe 8 rolls.
Wednesday at 16:181 day Author 9 minutes ago, JohnMo said:No, but I found 75mm was fine for what I used it for.Does that account for all butt joints and small off cuts you may have to add to certain sections to fill the area. +10% - is 311m - I would buy 7 maybe 8 rolls.8 x 50m rolls, do you mean?
Wednesday at 19:261 day For anyone who doesn't know. It doesn't need to be aluminium. The aluminium surfaces do not aid insulation, but simply hold the insides in and look good.Reflective surfaces only add insulation if facing an air space to bounce radiating heat back into.Manufacturers used to imply that it does ,but now simply choose to not mention this, especially the one you will have been bombarded with as a super new idea.The tape is to close joints, keep it all from moving, and to stop any grout getting down there. shiny looks good.It helps a bit in keeping cutting dust down.Thus the unfaced boards that are available from 'seconds' even though they are not, are an option.Tyvek tape can be a bit permanent! so be right before applying it.I think I must have wasted 30% of the shiny tape from SF.4 hours ago, Chris HB said:Perimeter x number of boardsNot perimeter, as the tape joins 2 boards. So half perimeter (3.6m) x number of whole boards+15% I'd say. 10% if the rooms are big.Likewise boards. You should not have much waste.... remember you have to pay to get rid of waste so you are paying twice.
22 hours ago22 hr I bought a few boxes of tyvek off eBay (any of there tape white, metallic or black) paid about £10 a roll. I still have some around and use for all sorts as won't come off.
21 hours ago21 hr Very similar to the tape I used on our house and I was very impressed.Better than the tyvek I reckon for durability.Airtightness Tapes3100 Black Airtight TapeOur 3100 single sided tape is a 75 micron PE film, then coated with a 200 gsm of clear modified acrylic adhesive system with scrim for dimensional stability. The PE film is UV resistant for 12 months. Edited 21 hours ago21 hr by Iceverge
13 hours ago13 hr Author 23 hours ago, saveasteading said:For anyone who doesn't know. It doesn't need to be aluminium. The aluminium surfaces do not aid insulation, but simply hold the insides in and look good.Reflective surfaces only add insulation if facing an air space to bounce radiating heat back into.Manufacturers used to imply that it does ,but now simply choose to not mention this, especially the one you will have been bombarded with as a super new idea.The tape is to close joints, keep it all from moving, and to stop any grout getting down there. shiny looks good.It helps a bit in keeping cutting dust down.Thus the unfaced boards that are available from 'seconds' even though they are not, are an option.Tyvek tape can be a bit permanent! so be right before applying it.I think I must have wasted 30% of the shiny tape from SF.Not perimeter, as the tape joins 2 boards. So half perimeter (3.6m) x number of whole boards+15% I'd say. 10% if the rooms are big.Likewise boards. You should not have much waste.... remember you have to pay to get rid of waste so you are paying twice.So Airtightness Tapes are worth paying the bit extra for then? That opens up a whole new range of choices to try and make sense of, then!
12 hours ago12 hr 40 minutes ago, Chris HB said:So Airtightness Tapes are worth paying the bit extra for then?I do believe so. If you are going to get through a lot look around both in UK and on mainland Europe. I think some on here have used merchants there.I have mainly used Pro Clima, and some Pavatex, though there are cheaper options, as far as I know.As I mentioned before, I have had foil tape that sticks well, but I have also had stuff which sticks very poorly.
1 minute ago1 min 12 hours ago, Redbeard said:also had stuff which sticks very poorly.I suspect that own brand retailers shop around and change suppliers so the quality may change over time and even between batches.Example from a different market: Which magazine would not rate some products (ketchup?) From Aldi or Lidl because samples from different UK regions were not the same product, though labelled the same.
