Rafter to ledger board connection.
Hello
I want to fix my rafters to a ledger board. I’ve made a small bird mouth cut to seat the rafter onto ledger. This has the full 47mm bearing. Trouble is I’m looking at code complaint way to fix these without nailing or screwing too close to the limits. This is the diameter of the fixings within the distances of the end grain, edges, birds mouth angle etc. due to the rafter sitting high on the ledger I haven’t got an option to skew nail through the plumb (heel) cut. If I go in through the sides and down into the ledger  I’ll be too close to the birdmouth angle. I was thinking either pre-drill and go in with a long screw from the top. 5mm directly down so it lands 25mm in the centre of the seat and into the ledger. Or use some kind of twisted restraint bar along the side of the rafter and twist to then hit the ledger.
The downward thrust is taken care of by the wood to wood seat. It’s just uplift and connection. I’m assuming horizontal twist - although I can noggin in between to stop this twist and slide.
Anyone with any firm knowledge on this situation please help.
(Also - please don’t reply if you’re just going to say plumb cut with a hanger, etc) it needs the bird mouth for BCO.)
Many thanks. Picture below.
There’s a mini hanger called either a TRIPLE GRIP or MULTI GRIP it’s a small metal plate with a cut in it that can be used in many ways, but by bending it with a hammer you can get 3 fixing points out of it, hence why I call them triple grips.
they are about £1.50 each.
fix with twist nails.
It is also stabilising the walls, linking them and stiffening the whole structure.
Not being a timber frame expert I was surprised to find out that twist nails were the expected fixing and widely available. Our joiners knew this and were happy.
They are clearly fast and easy to fix.
That's for experienced joiners... a mouthful of nails, tap tap wham.  I'd be very slow.
But if you haven't room to swing the hammer then screws are fine but do get either a spec from a designer  or approval from bco.  The twist is to prevent pull-out so you'll need a coarse threaded screw. Then you can use a drill and a 90° attachment if necessary.
Screws need to be a lesser tensile iirc.
I didn't know that. Do you know why?
so they aren't brittle in shear. Nails are comparatively ductile
That's a good point. We see it in denailing... nails bend but screws often snap.
So I withdraw my 'use screws' suggestion unless there is no other option, and then use big ones and lots. That doesn't sound like a formal spec does it?
I was told, if using screws, use partially threaded screws with solid stem at the top.
That’s not enough, as hardened screws shear very easily as they have near zero ‘give’, and the demand on them is considered dynamic due to wind / snow / heat / cold etc.
