Hello there, I have just joined buildhub so I hope I am using this forum correctly. My partner and I are at the very beginning of our 1st house self build and we went with the local council building control as they were considerably cheaper than private and we are building on a shoe string. After the very brief first site visit, we have found him almost impossible to contact. He won't answer the phone and doesn't respond to emails. We have done all our ground clearance and are ready to get the foundations done before autumn kicks in, but can't move forward until we can iron out the issues he raised. Can I ask what peoples experiences are with council run building control vs Private and can people let me know what a reasonable time limit is, to get a response for general questions and then more in depth issues. Trying to understand what is the norm so we may work with realistic expectations in how we plan and run this build. Thanks, Adele
Hello @Adele Tractor and welcome.
Private or Local Authority, building control are overrun with work and do not have time to talk to you.  You need to work out how to comply and they will check the plans and visit key stages.  They will probably only visit site 3 or 4 times.
Why don't you post what you are unsure about on here and see what replies you get?  There are lots of members with considerable skill and experience.
Thanks for your reply. I do appreciate they are really busy, and not looking for them to come up with the solutions. We are having issues with the B5 compliance, we had contacted the fire service who said they needed to talk to the building control officer. Our officer said to forward the information over to him which we did immediately. This was 2 weeks ago and he is not replying to any of our attempts to contact him, even though he has mentioned the issue to our structural engineer while disusing a different issue. Its cost us money and time. We are now unsure of how to proceed.
You can often make contact with the fire service and I have found them quite helpful.  Did the fire service speak to BC?  Were they happy with your proposals?  Did the fire service bring this up as an issue at planning stage?  They will often relax some guidelines for a single dwelling.
As above, what council are you under…they should be a department and more than a single person, although you have a named contact, others there should also be able to come out and advise. May also be worth copying in the entire department email address along with your named contact, could help move things along… and the other thing, they could just be on annual leave
@Adele Tractor we had to get fire officer assessment but they refused to speak to us directly and would only deal with requests from a Building Control Officer / approved inspector. Quite frustrating but we got there in the end. We’re with private (Stroma). No personal experience of our local council BC - good luck.
 If the bco isn't asking perhaps letc it run.
An example: in our case the fire service asked for a 10m3 water tank. But bco ignored that. So don't overthink.
I agreed btw as, although there is no mains,  an appliance could drive adjacent ( and we have 3m3 drinking water).  I don't know if the bco gave it that much thought.
But bco did ask about fire doors and alarms. Best ask them.
I have found when dealing with Council building control as someone previously mentioned they are a team and seem to have an ‘on duty’ officer.  So often you’ll get whoever is available that day to visit the site, not assigned a particular officer for that particular project, as backward as it sounds. Although usually as officer is assigned to a specific area I guess for just ease of transport. On my last project I have 3 different officers at the various stages of works. Previous project I had 2 separate officers (tho only 2 visits).  My current project is the first time I’m using a private BCO as it’s in a different local authority area (Cornwall) and they had a bad reputation. So now just have the one guy to handle the whole project.  I would possibly try and use the main contact details/email for the department rather than trying to contact a particular person. Using your project reference/case number and then get a response via the general enquiry line. Usually it will get picked up by an admin body who can direct it to someone to action even if it isn’t the person you originally dealt with. They should have all the notes available.
I've known that to be a problem when they have individual preferences and opinions, greater or lesser knowledge, or showing off how tough or clever they are.
Maybe it's less risky  re stage inspections.
In your case do you have a formal proposal for them to consider, or wanting advice? You said above that you have sent them information.  Can you tell us more?
Edited by saveasteading
On that particular project it wasn't too much of an issue as it was just alterations. We moved a kitchen to another room and removed a wall.  So an officer just needed eyes on a new drain and sight of a concrete lintel, following officer just needed to see the job completed. Not much room to input their personal opinions! But I can imagine on a whole house build where many multiply regulations need to be met then it can open to different officers wanting different things.
Firstly.. Thankyou to everyone that took the time out to respond and apologies for taking so long to say thanks, I Hadn't checked or seen that we had so many responses. I am starting to remember that the admin is one of the reasons I stopped social media. So the update is positive, I think we finally figured out how building control works. We had thought part of their role was in an advisory capacity and no-one, including them would tell us specifically what their role and responsibilities were, who they were accountable too, how the game plays out and what the game rules were, so when they just wouldn't respond to our emails or anyone in the company would answer the phone, and then would make extraordinary demands of us with no other additional information or guidance, we felt like we were being taken on a merry dance. We have since figured out that they are as a general rule NOT working in an advisory capacity, because if you build something they advised on and passed, and something went wrong, they are then liable, which makes perfect sense why they would be reticent to pass on their knowledge. The B5 requirement was a headache because the impression we got was that we HAD to install this HUGE turning area that would dominate our land and involve taking out a lot of trees to produce. This has now been satisfied with a sprinkler system installed in the house, of which a certificate from the company installing is enough and it was this extreme request that was solved with a simple solution that broke the camels back and we figured out the way this particular inspector seems to work. He will throw at us the worst case scenario, we find the simplest solution to solve it and as long as it is reasonable and under someone elses name, he is happy. I know it may sound daft and we are slow learners, but the parameters with which it all operates just isn't written down anywhere and my brain needs to fully understand the system we have to work within, before it can function. Anyhoos...We got there, we submitted our actions and we got the go ahead from building control at the end of last week so WE'RE OFF. Thankyou everyone and I am sure we will be back with more further down the line.
  • Like 4
Have you considered a mist system instead? I’m in the middle of a clients build, and suggested “automatic fire suppression” was considered, even though it wasn’t mandated.
A mist system is far less impactful, doesn’t need a huge water mains pipe, and causes WAY less property damage than a sprinkler system does.
Price is either comparable or way cheaper, depending on a crazy amount of extra kit being required for sprinklers.
1 hour ago, Nickfromwales said:
far less impactful
Apart from reduced water quantity I assume it fills the room better and is limited to the problem room.
