saveasteading Posted July 31 Posted July 31 I'm just sharing today's annoyance. Perhaps it will help someone else. We will be using engineered timber over a large area and have it in storage because it was a bargain. We recently got a reference to a contractor to lay it. The price was ok so we said go. Now they are saying that we need to prove that the screed is dry enough. It is, and will be beyond dry come September when it is to be done. Even when we use the ludicrously conservative 1mm/ day we have double that time since it was laid, and the wind has been whistling through at 25 to 30 C. Having told them that, they now say (without reference) that it must be 19C all the time and actually 0.5mm/ day is correct. Even that means that it is dry. So they are either charlatans, or ignorant. From long experience I know floorers always try this because they want to sell an upgrade of sealing and even over-screeding, and/or lose any liability in case of any future problem. so 1. we explain why it is dry. Very civilly quoting the material used and the time it's been down. 2. we then emphasise that their sudden doubling of the time required isn't relevant. 3. Now they say that if they turn up and test the screed in September and it isn't to their dryness satisfaction then they will refuse to do it and charge £500 aborted visit. I'm thinking this is perhaps all they do... turn up, charge £500 and go away. It would appear that they are used to getting this extra pay, and are somewhat annoyed that we are daring to answer back. Obv I don't trust them at all and would like to tell them to go cheat elsewhere. But maybe they are just ignorant. They only do one thing, so they should not be ignorant and thus I suspect the other option. If you cheat in one way, you are cheats generally, so who knows if they are any good. That they were recommended by a well known supplier bothers me. Maybe it's all too easy for them. In the past I've presumably convinced the floorers that there is no issue and just to get on with it. I may have signed papers to that effect. But this is on a different level. It's about 250m2 of flooring , so a nice job for someone.
saveasteading Posted July 31 Author Posted July 31 5 minutes ago, JohnMo said: They should be using a floor moisture tester. I clicked 'send' too early and have now said much more. I don't trust them to use a meter properly.
saveasteading Posted August 4 Author Posted August 4 So we found a moisture meter and set it up. currently saying 53%. I just know it can't be any drier than it is now, but it will be interesting to observe any changes with time or temperature. AI says 50% max for flooring on anhydrite. Other sites give very different numbers. But I came across this erudite site. Perhaps in the toilets. I'd take their site even more seriously if the page headline didn't use the word Moiture. Rhymes with voiture?
saveasteading Posted August 4 Author Posted August 4 2 hours ago, Mr Punter said: What is the contractor's maximum allowable moisture? I'm going to look for the screed manufacturer's info on this. I noticed that they had about 8 products and they will all have different absorption properties. We are currently measuring the air humidity in the enclosed space of the testing box. That must be an approximation. A probe will be another approximation as the free moisture content must be linked to the amount of impermeable aggregate in it. The only real test is to take a core and heat it and measure the water evaporated off it. That isn't going to happen. The floor will be engineered timber, and the manufacturer has nothing to say on the matter. The contractor changes his requirements when challenged, as in the initial post. Wants to seal the screed or charge an abort cost, so I have no trust in them. I will be there on the day and the poor chap may have a hard time if he plays at being technical. What I don't want is them walking off because the scam hasn't worked.
BadgerBodger Posted Tuesday at 19:54 Posted Tuesday at 19:54 It’s a swizz, I’m sure of it. The thing is from my experience, nearly every floor layer plays the same game. I’ve done whole secondary schools with a slab poured 12 months prior, many metal rib with only 150mm max thickness, they put the probes in, it says moisture too high (especially for resilient floor coverings like linoleum) and they say DPM or no guarantee. 90% the time, it’s ok. 10% the adhesive fails and it’s a very expensive job to make good. ultimately, they don’t want the risk. I get it’s we pay because we don’t want the risk either. it’s not always the case but often. you can always tell them you will take the risk? Imho, less of an issue when the floor can breathe like timber
saveasteading Posted Thursday at 10:11 Author Posted Thursday at 10:11 36 minutes ago, SteamyTea said: fit the floor yourself Who me? Yes and I'm quite good at it. But deadlines, the 4 hours a day stamina, and the family veto are the issues. It's a point though that perhaps we ask elsewhere. I expect the same from any floorer except that 'abort and charge' threat.
scottishjohn Posted 9 hours ago Posted 9 hours ago (edited) when my men did all my floors - they insisted on moisture meters fitted to downward facing cup -- left them in place and came back to check them from memory the number they were looking for was 3.5% they said they could do it at higher moisture rate but glue was twice the price --so i waited then they came back and ground all the floors_ sucked all the dust off them to get a perfect flat finish -then checked it again for moisture content only then did they start to lay it and they laid it AFTER the skirting boards were fitted -- cut it all in perfectly real professionals job was prefect and that is not a term i use lightly only downside with using this company is that they are so good you need to book them 4-6 months in advance but well worth it still looks great nearly 2 years on Edited 9 hours ago by scottishjohn
scottishjohn Posted 7 hours ago Posted 7 hours ago 1 hour ago, scottishjohn said: when my men did all my floors - they insisted on moisture meters fitted to downward facing cup -- left them in place and came back to check them from memory the number they were looking for was 3.5% they said they could do it at higher moisture rate but glue was twice the price --so i waited then they came back and ground all the floors_ sucked all the dust off them to get a perfect flat finish -then checked it again for moisture content only then did they start to lay it and they laid it AFTER the skirting boards were fitted -- cut it all in perfectly real professionals job was prefect and that is not a term i use lightly only downside with using this company is that they are so good you need to book them 4-6 months in advance but well worth it still looks great nearly 2 years on a we piccie of the hall-all made up from individual bits -- now that craftsman ship 1
SteamyTea Posted 2 hours ago Posted 2 hours ago 4 hours ago, saveasteading said: Today 26.7°C seems quite a high temperature, is the concrete still curing? I have some very similar T/RH units, not one pair of them read the same.
saveasteading Posted 1 hour ago Author Posted 1 hour ago 56 minutes ago, SteamyTea said: 26.7°C seems quite a high temperature, That's about the temperature today as it was over the weekend in daytime. If it was still curing I'd have to take back everything I've said about how dry it is. It is 40 to 50mm thick and has been there for months, on top of PIR. It is not a high end machine, but it is showing a number and trend. I haven't even read the instructions, so maybe it should be removed and replaced for every reading.... that was the case for the poshest one i've seen which was like a mahogany and glass carriage clock with a brass gauge inside it.
SteamyTea Posted 57 minutes ago Posted 57 minutes ago You can calibrate the RH with some salty water.
