25 minutes ago, scottishjohn said:
wouldn,t it be good if our politcians followed the burgers of calais and spontaneously combusted
I recommend all, especially critics,  to consider standing for their local parish or borough.
Then report back on whether it was easy, well rewarded, selfish: or hard work, not or barely rewarded, or public spirited.
Or  to stop criticising all councillors, politicians and  public servants.
I recommend all, especially critics,  to consider standing for their local parish or borough. We need you.
  • Like 3
A further thought on this.  We often see comments (I am not referring to BH) that 'they are all the same' or 'all on the brown envelopes'.
I suspect that people saying that are projecting what they would be doing, onto others.
They might usefully attend a council meeting, of which most are public, and see if they fancy giving up several evenings a month to keep the wheels moving.
Yes there are people who abuse their position, but most are well intentioned, even if we might not agree with them,  and give up a lot of time.
There are often vacancies on Parish Councils which gives useful experience before having to stand for election at the next 4 year cycle.
having tried to gat a simple thing like  the requirement to book a spot   at the recycling center done away with   -- you cannot just turn up
better than that you cannot even take half used tins of paint
 yet you can take car batteries -- cos they will get paid for them
and they wonder fly tipping is a problem
 and being told by more than one D&G  counciller that they tried and were blocked by the council    on the grounds that it helps things run  better  and would not discuss it any further -
-i do not see anything that my local town council could do on any subject  -so on point in joining
 it is so simple -- you turn up dump your stuff and leave -- if you pick wrong time you might have to queue--
 how is making everyone ring or email D&G council  to book a slot going to make things better -- just making another job and more paperwork
 so you have to plan when you want to go and not just decide to have clear out and go dump it  and they are only open certain days and never before 12.00-16.00
this to me shows the nature of the "civil service " very accurately -- making more jobs and making more useless data
 if the skip is full then they just get it emptied and as they are huge  that will never get filled in a day
do i believe they will monitor the fill rate of the different skips any better --NO
 they do not even ask what you are bringing  or how much of it
 just another spread sheet to maybe look at usage and decide if they can shut it
I already have a 20 mile  journey to there as it is --
and that info they can get by seeing how often they need to empty the skips
 so do I think being on a local town council will have any impact on the areas  D&G council control-- NO
Lots of "my ex next door neighbour's sister once dated an oil rig worker in the 90's and she said there was loads of oil under Glastonbury tor"
I'm going to use the projection done by the oil industry on the basis that
A) they know more about the potential for pip and gas extraction around the UK than anyone on this forum
B) they have no vested interest in minimising potential - which is a common retort to using the NSTA figures "ah but Ed Milliband told them to lie, there is actually loads of oil left".
these is the oil and gas industry low and high projections
The low one is approximately (but not exactly) the NSTA "current course".
 Screenshot_2026-08-16-19-03-08-730_com.android.chrome.thumb.png.8e4411a70aa19ea6ef66505d1a19bfd6.png
So by 2035 we will produce at best, half the oil and gas we do now (ie 25% of current consumption).
On current trends maybe 13% of current demand.
So all the arguing is arguing over the rate of decline - steep or steeper.
There is no "up" scenario. There is no going back to the late 90's when we had a surplus and became a (small) exporter
The only way the UK can become less dependent on imported oil and gas is for the UK to become less dependent on oil and gas
Loads in Dorset.
Wytch Farm is the largest onshore oil field in Europe.
110,000 barrels a day in 1997, 50,000 B/D in 2002.
It is estimated that there is 479.6 million barrels left.  There is also 4.73 million tonnes of natural gas liquids and 1.42 billion cubic metres (50×109 cu ft) of natural gas.
So why is this not being exploited then?  it is already a production site with the infrastructure there, locals are used to it.
7 minutes ago, SteamyTea said:
Loads in Dorset.
"Loads" is doing a lot of work there....
The largest onshore oil has 480 million barrels of oil..... sounds alot until you realise the UK consumes about 1.4 million barrels a day.
So all that oil wouldn't last us until this time next year.
And 1,420 million cubic meters of gas sounds alot until you factor the UK uses around 142 million cubic meters *a day* in the summer
So all that gas wouldn't even last us to the end of this month.
Again we are simply discussing the difference between a two declines, one slightly shallower that the other.
probably same reason as the solway firth  and morecambe bay --national fuel security
 is beelebub so naive to think that his data is accurate and that the government can,t put a twist on it
at least give them credit for being devious if it suits the national interest
You mention "they" a lot.
It sounds as if  the community needs "you"  and others with practical ideas to get things changed.
Where do you get your alternative truths from?
Explain to naïve old me exactly how my data is inaccurate. Provide sources (ex-brother-in-laws don't count) showing the larger reserves.
Explain how the government can make the oil industry under project production but can't stop them lobbying for more licences?
Explain how the government can influence Norway to not only under project future production (they are also predicting decline albeit at a lower rate) but also to reduce current production to show that decline.
Is it via the same mechanism the suppress the car that runs on water?
good point
however if renewables were really viable  without subsidy and could make more long term money  than oil +gas --  the oil companies would be shifting much quicker
into them in much bigger way
 BP have even sold off there renewable arm
the bottom line  now is all oil companies  and shareholders are interested in
1 hour ago, scottishjohn said:
good point
They are also selling their North Sea operation.....
Renewables are making money. People are happy to build them on the promise of selling the electricity at about 9p/kWh for the next 20 years.
In contrast people want over 10p for a gas plant (and that's excluding any carbon costs, it's closer to 16p with carbon costs)
Nuclear builders want similar sums too.
For context the octopus agile average export rate (which is just above the wholesale rate) is currently 17p and got as low as 13p this week.
You are absolutely right about oil companies worrying about the bottom line but are drawing the wrong conclusion.
They can make more money over the next few quarters by using existing infrastructure to sell oil and gas at ever increasing prices than they can investing money in long term assets that drive the profit of your existing assets down.
And the management only care about the next 4 quarters. Anything beyond that is a problem for future them.
Kodak invented the digital camera but decided it was more profitable to focus on selling film than to invest in a camera that didn't need film. And it worked.  For a while.
If you cancelled all long term incentives currently offered, you would most likely find future production builds still being mostly renewable. Especially if land based wind turbines start being permitted again. The offshore stuff is expensive, but building renewables on land is cheaper than anything else (and can be done at much different scales too, encouraging a wider mix of businesses).
They did that years ago before the cost of renewables nose dived. They were too early and got burned unfortunately. I would be curious where they would be now had they persisted.
Unfortunately, western country recent history is littered with companies trying to make 'green' products, deciding they couldn't do it at the right price and giving up and then China coming along saying 'that was a good idea, here's how you do it and make money' (and hint, it's not about labour costs, the solar panel/battery companies are very low staffed, it's all machines).
38 minutes ago, Beelbeebub said:
You are absolutely right about oil companies worrying about the bottom line but are drawing the wrong conclusion...
...Kodak invented the digital camera but decided it was more profitable to focus on selling film than to invest in a camera that didn't need film. And it worked.  For a while.
+1. Some companies just can't adapt to change. See also:
- British Airways sold their low-cost airline (Go) because they couldn't make it pay. Low-cost airlines now have around 50% of the European market
- IBM sold their PC arm to Lenovo for the same reason - but PCs definitely haven't gone away
Simple truth BP, Shell etc have huge overheads and cannot make aging assets pay, so once production starts to dip they sell. Been like that for decades in the North sea. So no suprise BP are selling.
Indeed.
The point being the logical trap of "BP is not investing on X, therefore X cannot be a good investment".
