18 hours ago, Great_scot_selfbuild said:
The thermal property of tilebacker boards is nowhere near comparable with aerotherm though.
It's not but you can plaster straight onto it. If you are planning to clad this in plasterboard you could use 20mm XPS and have a thinner overall build up.
20 hours ago, Great_scot_selfbuild said:
Is this aerogel or spacetherm? From the suppliers I’ve approached, aerogel is like a stiff board/sheet (these pictures look like a loose fabric). It appears that the term ’aerogel’ is used across a variety of products, but not all with the same thermal value.
What I bought were Spacetherm A1 pads (I'd call them sheets, but they are pads on the invoice). I had a lot of trouble getting consistent advice on what is what. Proctor are fairly helpful, but they still take for granted that products they work with everyday will make sense to DIY'ers like us!
It came in an "8x4" sheet, rolled up. It's reasonably flexible, but they encourage the use of separate pieces on my steel column rather than wrapping it round the corner and I think that was good advice. It would follow a curve for sure, but you wouldn't want to wrap it around 2 sides of an object.
FYI, I paid £515 plus VAT for 2 full sheets. The carriage was £40+VAT (included in that £515).
I'd post you a small offcut if you want to see it before you fork out?
I think the fibre matrix is made from polyester.
So think of it as a very dusty blanket that has been gathering dirt at your grandmother's for the last 60 years.
Then think about what is sticking to it, and why it does not bend tight to make a good hospital corner.
Sleep well in this heat everyone
On 08/07/2026 at 18:51, Nickfromwales said:
Just use XPS tile backer boards
Been reading without comment as I don't know aerogel.
But my inclination is  to keep it simple and ensure a good, solid and permanent connection.
What area of steel are we talking about, relative to the wall area? i.e. is it the biggest deal to get maximum insulation?
And what depth is available?
There are several makes, too and its available at my local BM (and yours) , Topps and at Wickes, so about £30/m2 and no transport cost.
Depending on detail and access, I'd probably stuff the void of the steel to stop that cavity being cold, and also reducing overall heat loss.
On 08/07/2026 at 14:55, Great_scot_selfbuild said:
I am planning to fit a layer of 10mm aerogel to the outside of a steel column. Any recommendations on glue / other methods? (Please state if you’ve managed to do this before - my experience of contact adhesive is that it can behave very differently based on the material type and I’m not sure how well aerogel will take to it.
Ok a bit of food for thought.
You have a steel column, likely supporting a structural load. Let's say as a minimum you need some fire protection? Say 30 minutes.
Now you can achieve that in two common ways.
1/ Box it in with say Gyproc Fireline board. Which probably gives you a detailing problem, which is why you are probably wanting to use Aerogel as it saves space.
2/ Paint the steel with intumescent paint. But for intumescent paint to work it needs to have space to expand into... you see the dilemma? As a rough rule of thumb the intumescent paint thickness needs to expand some 50 times to work properly. It needs space to do this. So you can't stick Areogell to the steel per say and you need manufacturer approval to stick it to intumescent paint.
Now often BC etc don't pick up on this. But if something goes wrong, there is a fire, the steel fails and the building falls on say the Fire Brigade.. then the buck has to stop somewhere.. as an SE I'll be on the radar, Architect's also, and you if you have taken it upon yourself to become a designer then you are facing a huge liability.
Now the above is a worst case.. but if you get a smart BC officer that knows about this stuff then they might be minded to fail your design unless you can prove otherwise.
There are cases where the steel is well protected by masonry and very heavy and thick and thus possibly as at Paulie
On 08/07/2026 at 16:25, Super_Paulie said:
i used a spray contact adhesive on my internal upright, stuck no problem.
I think in Paulie's case the steels are so heavy they don't need fire protection. The load we use when designing steels for fire protection get reduced as they are called an accidental case. In lay terms we don't design most steels for the building being fully loaded up and a fire starting at the same time.
I would go back and look at what your steels are doing, the loads and so on. Also have a chat with your SE  to check if what you are proposing might invalidate their design for example.
I appreciate you may not like this news.. but it's up to you and your risk.
