Russell griffiths Posted Monday at 12:22 Posted Monday at 12:22 Stud wall between a bedroom and an en-suite bathroom. 90mm timber studs. insulate inbetween studs or double plasterboard both sides.  this is a holiday lodge we have so the only noise will be hearing the wife dropping the kids off at school.  I think bang for my buck double boarding is cheaper.Â
JohnMo Posted Monday at 12:38 Posted Monday at 12:38 90mm studs 50mm dense mineral wool I used rock wool Flexi - zero issues and normal 12.5mm plasterboard on each side. 1
Russell griffiths Posted Monday at 12:57 Author Posted Monday at 12:57 17 minutes ago, JohnMo said: 90mm studs 50mm dense mineral wool I used rock wool Flexi - zero issues and normal 12.5mm plasterboard on each side. This is exactly what I have done in the house. im just thinking plasterboard is cheap if I buy a pack, and double boarding is easy if I’m already doing it and the screw gun is out.Â
JohnMo Posted Monday at 13:10 Posted Monday at 13:10 11 minutes ago, Russell griffiths said: This is exactly what I have done in the house. im just thinking plasterboard is cheap if I buy a pack, and double boarding is easy if I’m already doing it and the screw gun is out. With the empty void even with 2x plasterboard each side, its still a drum. Air is a great way to carry noise.
saveasteading Posted Monday at 13:37 Posted Monday at 13:37 Impact noise or airborne? For both, if you can spare a bit more wall width (how much do you have?)  Studs twice, staggered to face each room with plasterboard only on one set of studs, so that you have physical discontinity. That deals with bumps and some loud noise, especially bass.  eg a 100mm sole plate but 75mm studs lining up alternately with only one room or the other.. @ 600mm cc, twice, so actually every 300mm  Then fill the void with any mineral wool, and you can even put some between studs and the 'other' side. It will snake. One sheet pb each side, possibly upgrade to the denser blue faced grade.  for dB figures see the Knauff catalogue.  That will be stunningly good, with the weaknesses being at plates to floor, ceiling and existing walls, so you'll still hear the vacuum bumping at skirtings.  Â
Russell griffiths Posted Monday at 17:18 Author Posted Monday at 17:18 3 hours ago, saveasteading said: Impact noise or airborne? For both, if you can spare a bit more wall width (how much do you have?)  Studs twice, staggered to face each room with plasterboard only on one set of studs, so that you have physical discontinity. That deals with bumps and some loud noise, especially bass.  eg a 100mm sole plate but 75mm studs lining up alternately with only one room or the other.. @ 600mm cc, twice, so actually every 300mm  Then fill the void with any mineral wool, and you can even put some between studs and the 'other' side. It will snake. One sheet pb each side, possibly upgrade to the denser blue faced grade.  for dB figures see the Knauff catalogue.  That will be stunningly good, with the weaknesses being at plates to floor, ceiling and existing walls, so you'll still hear the vacuum bumping at skirtings.   No room for that the whole building is only 6mx6m and it’s only a holiday let so only slept in for 4-5 consecutive nights. just looking at a cheap n cheerful solution. probably easier to just buy a couple of packs of acoustic insulation and chuck it in. trying to save a fiver here and there. 1
saveasteading Posted Monday at 17:37 Posted Monday at 17:37 15 minutes ago, Russell griffiths said: No room for that You suggest 90mm studs. So you could use 90mm as the sole plate etc, then studs of CLS 63mm. 1
Onoff Posted Monday at 17:55 Posted Monday at 17:55 The 16mm soundblock (blue) board I used does what it says on the tin. 1
saveasteading Posted Monday at 18:02 Posted Monday at 18:02 I have been advised (off the record) that none of the wall constructions perform as well in real life as in acoustic tests. This is because the tests are not between real rooms, but through a central area of a panel. ie no flanking sound. Â The difference between grey and blue will be fairly accurate though.
Gus Potter Posted Monday at 21:42 Posted Monday at 21:42 9 hours ago, Russell griffiths said: Stud wall between a bedroom and an en-suite bathroom. From memory the regs for an ensuite are less strict, the door is the obvious weak point.  My normal minimum spec for an ensuite wall is plasterboard each side with a minimum density of 10kg/ sq m (see Gyproc Wall 10) on a minimum of a 70mm deep wall stud. Then 50mm of Rockwool RW45 acoustic insulation. If you can stretch to a deeper stud then all the better.  Depends on you ceiling height as there is a bit of structural design creeping in here as you don't want the wall too slender so the whole wall vibrates as a unit. . You need an air gap between the Rockwool and the plaster board as the air gap filters some bands of the sound frequency. If you pack the wall tight with insulation it has a detrimental effect.  If you want to keep your guests happy then fit a good solid door, a good lock that gives them confidence, a good fan and a nice handle on the door!  The regs between rooms are often different. 1
Iceverge Posted Monday at 22:39 Posted Monday at 22:39 Air paths. every one. Seal them up with acoustic sealant . Be picky around pipes etc.  Noggins between roof and floor joists above and below too and more acoustic sealant .  Then add mass. Simple rule. More is better. Plasterboard is cheap as is OSB per kg. Anything would work mind you. You could fill the wall with gravel or magic beans. Mass is mass .  Mineral wool will help with the reverb. The extra dense stuff is an expensive way to add mass. More plasterboard is cheaper.  Break any noise travelling through the structure itself by breaking the solid path through. Double studs. Resilient bars. Rubber strips on the joists.Â
DownSouth Posted yesterday at 06:28 Posted yesterday at 06:28 7 hours ago, Iceverge said: You could fill the wall with gravel or magic beans. Mass is mass .   Thanks for the image of someone dismantling this many years later and being covered in beans 🤣
JohnMo Posted yesterday at 06:55 Posted yesterday at 06:55 8 hours ago, Iceverge said: You could fill the wall with gravel Holding gravel in place while adding the plasterboard may be tricky. 🙌
Russell griffiths Posted yesterday at 07:38 Author Posted yesterday at 07:38 9 hours ago, Gus Potter said: From memory the regs for an ensuite are less strict, the door is the obvious weak point.  My normal minimum spec for an ensuite wall is plasterboard each side with a minimum density of 10kg/ sq m (see Gyproc Wall 10) on a minimum of a 70mm deep wall stud. Then 50mm of Rockwool RW45 acoustic insulation. If you can stretch to a deeper stud then all the better.  Depends on you ceiling height as there is a bit of structural design creeping in here as you don't want the wall too slender so the whole wall vibrates as a unit. . You need an air gap between the Rockwool and the plaster board as the air gap filters some bands of the sound frequency. If you pack the wall tight with insulation it has a detrimental effect.  If you want to keep your guests happy then fit a good solid door, a good lock that gives them confidence, a good fan and a nice handle on the door!  The regs between rooms are often different. The door is always the weak spot, makes soundproofing the wall seam pointless, especially with a 10mm gap under the door.Â
saveasteading Posted yesterday at 07:50 Posted yesterday at 07:50 19 hours ago, Russell griffiths said: the only noise will be hearing the wife dropping the kids off at school Doesn't read like an ensuite door.
Iceverge Posted 3 hours ago Posted 3 hours ago On 30/06/2026 at 07:55, JohnMo said: Holding gravel in place while adding the plasterboard may be tricky. 🙌  Yet another building job limited my by my fundamental lack of arms.  On 30/06/2026 at 07:28, DownSouth said: Thanks for the image of someone dismantling this many years later and being covered in beans 🤣  A water leak and the bean sprout might make itself known!   In seriousness, one thing I would consider is buying a 110mm hole saw and making osb or Ply "gaskets" to slide on the waste pipes before plasterboard.  Then secure them to the back to the plasterboard with a few screws through from the room side.  You'll get a much more perfect air seal than anything you'll attempt with cutting a hole in a sheet of plasterboard and sliding it over the pipe. 1
