June 15Jun 15 I see that even the janky £200 Rotherburger pump doesn't get great reviews. And the Bailey bungs and manometer I wouldn't give to a 5-year old. What do peeps really use and recommend? My pressing need is for testing some solvent welded 50mm MuPVC. It won't have any real pressure in it, of course, so just for leaks.
June 15Jun 15 1 minute ago, Alan Ambrose said: I see that even the janky £200 Rotherburger pump doesn't get great reviews. And the Bailey bungs and manometer I wouldn't give to a 5-year old. What do peeps really use and recommend? My pressing need is for testing some solvent welded 50mm MuPVC. It won't have any real pressure in it, of course, so just for leaks. Block the outlet(s) and fill it all with water.
June 15Jun 15 Author Yeah, used that for some 110mm drainage, but strikes me it won't really detect v. slow weeps? Does leak detection dye have any use? Also kit, for say pressure testing UFH or Hep20 pipe?
June 15Jun 15 3 minutes ago, Alan Ambrose said: Yeah, used that for some 110mm drainage, but strikes me it won't really detect v. slow weeps? Does leak detection dye have any use? Also kit, for say pressure testing UFH or Hep20 pipe? It’s a hand pump and manometer usually. MB’s not Bars as it’s not supposed to see that kind of pressure. Weeps would self-seal anyways.
June 15Jun 15 Just now, Nickfromwales said: Weeps would self-seal anyway The magical powers of skin, fat and mould.
June 15Jun 15 BC usually want to witness a pressure test with air. I doubt they would accept "it's all full of water gov" I just bought a cheap kit from Screwfix 26 years ago and it has done 2 self builds.
June 15Jun 15 7 hours ago, ProDave said: BC usually want to witness a pressure test with air. I doubt they would accept "it's all full of water gov" I just bought a cheap kit from Screwfix 26 years ago and it has done 2 self builds. Was told by last 2 BCO’s to “fill it full of water” Then you time it and take pics of your phone for stop / start times.
June 15Jun 15 1 hour ago, Nickfromwales said: Then you time it and take pics of your phone for stop / start times Just make sure the jug is out of shot
June 15Jun 15 2 hours ago, SteamyTea said: Just make sure the jug is out of shot Why would you want water leaking into your, or anybody else's, house?
June 15Jun 15 10 hours ago, ProDave said: BC usually want to witness a pressure test with air. I doubt they would accept "it's all full of water gov" I just bought a cheap kit from Screwfix 26 years ago and it has done 2 self builds. In 1990 maybe! BC CGAF these days. They want signatures off the principal designer and contractor these days along with gas and electrical certs, so they take the money, give it a v quick look and FO. If any problems they pass the buck to the relevant person who signed taking responsibility. It's a mess.
June 15Jun 15 1 hour ago, MikeSharp01 said: Why would you want water leaking into your, or anybody else's, house? Depends how good your plumbing is…….
June 16Jun 16 Author >>> Was told by last 2 BCO’s to “fill it full of water” Then you time it and take pics of your phone for stop / start times. We did today and everything was good:) I still wouldn’t mind a decent testing kit for UFH etc.
June 16Jun 16 47 minutes ago, Alan Ambrose said: >>> Was told by last 2 BCO’s to “fill it full of water” Then you time it and take pics of your phone for stop / start times. We did today and everything was good:) I still wouldn’t mind a decent testing kit for UFH etc. Happy days. The UFH test kit is simple; connect it to the cold mains and let it rip.
June 22Jun 22 Inflatable horobin air test kit or similar worked for me after trying bailey wind up stoppers and others alike which air leaks slowly.
June 22Jun 22 On 15/06/2026 at 09:43, Alan Ambrose said: What do peeps really use and recommend? Vaseline and lots of it to seal the bungs and threads! Anne Summers volumes don't cut the mustard, go for the 500ml tubs. For adequate water testing..the pipes need to be filled to give a 1.5m head from memory.
