Alan Ambrose Posted April 6 Posted April 6 OK another tech question... We have a 50mm services void. I was planning to run horizontal cable trays, mostly high-up (2.5m above the floor) and split into mains & ELV / data (either using one split tray or two separate trays). Then a few vertical drops to light switches etc, also in trays if I can. And then fill any remaining void with, say, mineral wool. Question is - how do I avoid the mains crossing the data or is that OK? Something like this: Mains ------------------------!------------------------------- Data ------------------------!---------------!---------------- ! ! ! ! Mains Socket Network Port
garrymartin Posted April 6 Posted April 6 Perfectly fine. Crossing has fewer issues than running in parallel, and even that is not a big deal given the number of cables and voltages we are talking about in residential construction. 1
ProDave Posted April 6 Posted April 6 BUT electric cables must tin in safe zones. So to ensure this the electric cable tray must be within 100mm of the ceiling all the way across the room. The data cable tray can be at any height you want. 1
Alan Ambrose Posted April 7 Author Posted April 7 >>> the electric cable tray must be within 100mm of the ceiling Ah, I was assuming some common sense on this - we’re vaulted pretty much everywhere with a slopey ceiling from about 3.5m at the eaves. I was planning on putting the trays above the doors at about 2.4m.
Alan Ambrose Posted April 7 Author Posted April 7 p.s. I was thinking re safety standards / British standards / building control etc rather than interference problems. I see a typical summary e.g. here: https://www.cablemonkey.co.uk/cmdocs/ElectricalDistance.pdf But it has so many cases, it’s really hard to follow.
ProDave Posted April 7 Posted April 7 1 hour ago, Alan Ambrose said: >>> the electric cable tray must be within 100mm of the ceiling Ah, I was assuming some common sense on this - we’re vaulted pretty much everywhere with a slopey ceiling from about 3.5m at the eaves. I was planning on putting the trays above the doors at about 2.4m. Electric cables in a wall must run in a safe zone. Broadly speaking a safe zone is horizontally or vertically from an electrical accessory, e.g. a socket, or within 100mm of the corner of a room or ceiling. If you want to run electric cables around a room then do so at socket height, and ensure each wall has at least one socket to create that safe zone, and that is where all your mains cables can correctly run around a room.
Alan Ambrose Posted April 11 Author Posted April 11 @ProDave So, I just need to put a dummy 'point, accessory or switchgear' to establish a zone / cable tray anywhere I like? 😄 I'm sure I need some temperature/humidity sensors up at 2.4m 😉
Nickfromwales Posted April 11 Posted April 11 Why cable tray? Lots of expense and faff. All round patent band is fine for bunching and laying, and clips are less time consuming than hundreds of cable ties. Seems a massive ball-ache and cost for very little practical return? You’ll need spacers behind the trays to get cable ties in / out, so further projection outwards too. Rows of 38x 25 and 38x 16mm trunking would be quick and simple, using the self adhesive to lay these out and then a few mechanical fixings to corners and joints where you’ll be pulling on them. 1
Alan Ambrose Posted Monday at 15:26 Author Posted Monday at 15:26 Why? To give a fighting chance of running a new cable or replacing an old one. The current model when we hide the cables and assume they will be OK for the life of the building seems to me a bit flawed 😉.
-rick- Posted Monday at 16:16 Posted Monday at 16:16 42 minutes ago, Alan Ambrose said: Why? To give a fighting chance of running a new cable or replacing an old one. The current model when we hide the cables and assume they will be OK for the life of the building seems to me a bit flawed 😉. Im not sure how a cable tray helps you run additional cables later. The ties for the cables and all the perferations will present more snag challenges for pulling cables behind plasterboard than bare trunking or similar. I too want to be able to add additional cables later (especially low voltage/data/hdmi/etc) and am curious what other people think is the best way to go but personally don't think cable trays would help. My best guess at the minute for how to do this is to form two parallel cable paths horizontally along the wall behind the sockets with the metal back boxes mounted in front. Depth is a bit of an issue though. 50mm cavity + plasterboard on top is ok. Less seems to get tricky. Main reason for me to want this ability if I get a chance to build I want to get the basics in and done and then come back and be able to fit 'smart' stuff in a suitable way without ripping up the walls. I don't really want to have to plan where every device cable goes (and what type is needed) before being able to crack on with the rest of the property.
Alan Ambrose Posted Monday at 16:22 Author Posted Monday at 16:22 >>> I don't really want to have to plan where every device cable goes ... for the next 50 years...yeah, exactly. I figure I have a good chance of using a fish tape or electricians rods to run a new cable assuming the runs are fairly straight and there's access at any corners. Maybe it helps that our room layout is fairly simple & rectangular.
Nickfromwales Posted Monday at 16:32 Posted Monday at 16:32 Thinking you’re going to be able to add cables , retrospectively, is a little optimistic; myself, I think it’s practically unachievable. You’d be into breaking in / out of plasterwork, going up / down walls filled with (supposed to be filled with) acoustic insulation, and other services. It’s just way to hard to plan what’ll need to go in, and from where, and to where its “then” needed, to be a realistic approach. You’d need a complete redundant conduit network left in abeyance, throughout the dwelling, to ever attempt to mitigate this sensibly.
andyscotland Posted Monday at 19:02 Posted Monday at 19:02 On 11/04/2026 at 12:39, Alan Ambrose said: @ProDave So, I just need to put a dummy 'point, accessory or switchgear' to establish a zone / cable tray anywhere I like? 😄 I'm sure I need some temperature/humidity sensors up at 2.4m 😉 I'd argue that to create a safe zone it should really be an actual mains accessory or junction/cable box. If it's just a battery powered unit or a blank plate, there's a risk someone pops the lid, sees there's no cables going out of it, and assumes the walls beside/above/below are fine to drill. 2 hours ago, Alan Ambrose said: >>> I don't really want to have to plan where every device cable goes ... for the next 50 years...yeah, exactly. I figure I have a good chance of using a fish tape or electricians rods to run a new cable assuming the runs are fairly straight and there's access at any corners. Maybe it helps that our room layout is fairly simple & rectangular. I think it'll be very hard to fish along a cable tray, and even if you could as others have said you can't then fix the cable to it at intervals so it will not be properly supported meaning a) mechanical stress and b) could droop below the safe zone. Conduit or enclosed trunking would be best for fishing, but obviously you'd have to cut a new hole in the bottom if you want a new vertical drop out of it so that would mean opening up that bit of the wall at least. I'd agree with @ProDave the best option is to run all the cables at socket height with at least one socket on each wall. Like @-rick- says, if you run a 50mm batten horizontally on every wall aligned with the base of your sockets, with a gap above it, you have formed a natural "cable tray" / trunking out of your wall construction without any extra materials. You should be able to fish new cables horizontally along that batten, drop vertically down to it from above, etc, with minimal disruption. So long as you only use max 35mm backboxes there will be plenty of space to pass cables behind them, you could just about get behind a 47mm backbox (as 12mm of that will be in the plasterboard). If you want a second zone for data cables then run another batten above or below (depending on whether you think you're more likely to need to add vertical runs for mains or data).
-rick- Posted Tuesday at 10:37 Posted Tuesday at 10:37 (edited) A crude diagram of how I would plan my formed tray as @andyscotland describes. If you have wall sconces, provisions for motorised blinds, etc, you could run either horizontal (blue) or vertical (green) zones around them (obv need to place a socket/switch somewhere in line to produce a safe zone). The other thing I currently plan to do is to place way more metal backboxes than I plan to expose (always pairing a double with a single for data/etc). Use shallow ones so that you can put plasterboard on top of them. Then use a router to cut out access on the ones you need. Americans seem to use this technique a lot (without the unused spares) and it looks like it makes putting up plasterboard a lot quicker. Plan would be to then add metal backbox extenders onto the exposed ones to make them into deep boxes. The unused ones remain buried ready to be exposed if needed in future. This does require some careful thought, I'd want to be able to remove the backboxes to access cables behind and also want to be able to easily find buried ones (so maybe need to make a filler of some kind with some cheap magnets attached so that you can pass a template over the wall and it registers the exact location from the finished surface). Edited Tuesday at 10:39 by -rick-
-rick- Posted Tuesday at 10:54 Posted Tuesday at 10:54 Just to add, I think this would work fairly well on walls with a service cavity (ie, external walls). Doesn't work so well on internal walls (as Nick suggested). Still not really come up with a flexible solution I'm happy with there.
mjc55 Posted Tuesday at 18:56 Posted Tuesday at 18:56 8 hours ago, -rick- said: A crude diagram of how I would plan my formed tray as @andyscotland describes. If you have wall sconces, provisions for motorised blinds, etc, you could run either horizontal (blue) or vertical (green) zones around them (obv need to place a socket/switch somewhere in line to produce a safe zone). The other thing I currently plan to do is to place way more metal backboxes than I plan to expose (always pairing a double with a single for data/etc). Use shallow ones so that you can put plasterboard on top of them. Then use a router to cut out access on the ones you need. Americans seem to use this technique a lot (without the unused spares) and it looks like it makes putting up plasterboard a lot quicker. Plan would be to then add metal backbox extenders onto the exposed ones to make them into deep boxes. The unused ones remain buried ready to be exposed if needed in future. This does require some careful thought, I'd want to be able to remove the backboxes to access cables behind and also want to be able to easily find buried ones (so maybe need to make a filler of some kind with some cheap magnets attached so that you can pass a template over the wall and it registers the exact location from the finished surface). Cable running over the top of the door(??) is not in a safe zone (unless that is within 150mm of ceiling)
-rick- Posted Tuesday at 18:58 Posted Tuesday at 18:58 1 minute ago, mjc55 said: Cable running over the top of the door(??) is not in a safe zone (unless that is within 150mm of ceiling) Right, but I didn't draw where the ceiling was 1
Nickfromwales Posted Tuesday at 20:21 Posted Tuesday at 20:21 This is getting out of hand lol. There’s is zero chance of pulling all these hypothetical cables, from and to those hypothetical locations, without a padsaw, a hammer, a hole cutter, and shares in Toupret (cos you’ll need a lot of filler). Conduit is the only semi-feasible option, to every box, to a central location. Barmy. Sorry. 1
Alan Ambrose Posted 21 hours ago Author Posted 21 hours ago Yeah, I'm not convinced. I've spent not too much of my life (5 man days maybe) putting cables in routes that didn't exist before - but enough to know that it's an absolute major PITA. Europe does the duct thing often in concrete. And I've run quite a bit of stuff in conduit in my Larsen-truss style roof (actually made with Posi Joists but you get the picture). Some of those cables we will be able to replace if we need to - some of the longer runs probably won't. Too much friction. I think that either 50mm trays on their side or the equivalent with 50mm battens in our 50mm service cavity should work fine - as @-rick- suggests. If there's strategic access where the 'trays' do 90 degree corners, so much the better. As @ProDave points out - put some kind of socket / switch / sensor point (PIR or temperature/humidity maybe) at the positions you want and you can force 'safe zone' lines anywhere you like. At least you should be able to do 95% of the run without resorting to cutting plasterboard. For internal walls, maybe there's a 50mm zone in the middle of the wall somehow - that might make a good acoustic break too. Our geometry is very simple and rectangular so maybe that makes it a much easier prospect for us. 1
-rick- Posted 21 hours ago Posted 21 hours ago If you think ahead and make it possible to remove the back boxes after installation (cables routed through the back rather than side holes, plasterboard cut out big enough, screws positioned with this in mind) then each socket gives access to the cableway. Might be a pain to remove and put back but less of a pain than making/patching holes. Corners are a big concern so likely need to plan for sockets on both walls fairly close to corners. Having well thought out routes between each room and a centralish location with conduit/accessible tray is another element to make this feasible.
Mr Punter Posted 20 hours ago Posted 20 hours ago I have rewired places years ago where the vertical drops were in conduit. It made it much simpler than chasing in. For horizontal it was under floor.
