OK another tech question...
We have a 50mm services void. I was planning to run horizontal cable trays, mostly high-up (2.5m above the floor) and split into mains & ELV / data (either using one split tray or two separate trays). Then a few vertical drops to light switches etc, also in trays if I can. And then fill any remaining void with, say, mineral wool.
Question is - how do I avoid the mains crossing the data or is that OK? Something like this:
Mains ------------------------!-------------------------------
Data   ------------------------!---------------!----------------
                                       Mains Socket     Network Port
Perfectly fine. Crossing has fewer issues than running in parallel, and even that is not a big deal given the number of cables and voltages we are talking about in residential construction.
