Alwayslearning22 Posted 10 hours ago Posted 10 hours ago (edited) I tried removing my toilet seat to clean it and I dropped the nut inside the hole. It’s one of these close to the wall toilet. What are my options do I need to remove toilet to fix the seat Edited 10 hours ago by Alwayslearning22
ProDave Posted 4 hours ago Posted 4 hours ago Post a picture of the other nut. It will be possible to buy another one (probably sold as a pair)
AliG Posted 3 hours ago Posted 3 hours ago My mum did this and I found this was what was needed. This is for a Porcelanosa wall hung toilet. I would think it works for others, but you can probably look up a different make. https://www.bathroomspareparts.co.uk/porcelanosa-large-zip-toggles-100125027n499816968-179334-p.asp I assume that you still have the bolt otherwise you need this. https://www.bathroomspareparts.co.uk/porcelanosa-mood-toilet-seat-fixing-kit-100125026n499816970-179330-p.asp?utm_source=google&utm_campaign=&utm_medium=cpc&utm_content=&utm_term=&device=c&utm_prodid=ebaths2179330&gad_source=1&gad_campaignid=22543615678&gbraid=0AAAAADreFuGWtF-V_WS2BsGksAOavlQv6&gclid=Cj0KCQjws83OBhD4ARIsACblj1-zxAkTQbL6K8xWSnCoftyZHxQFRWot1YcoyoW_WkbDYtAjwZRKctQaAmNBEALw_wcB For future reference, you probably can just remove the seat by tilting it up at a 75 degree angle then pulling it straight up, don't unscrew anything like my mum!
Nickfromwales Posted 1 hour ago Posted 1 hour ago 8 hours ago, Alwayslearning22 said: I tried removing my toilet seat to clean it and I dropped the nut inside the hole. It’s one of these close to the wall toilet. What are my options do I need to remove toilet to fix the seat Most of these are quick release as above. If you can identify the size of nut / thread then usually these are stainless steel (so a magnet won’t work) so don’t replace with mild steel.
Alwayslearning22 Posted 1 hour ago Author Posted 1 hour ago 2 hours ago, ProDave said: Post a picture of the other nut. It will be possible to buy another one (probably sold as a pair)
ProDave Posted 1 hour ago Posted 1 hour ago https://www.toolstation.com/universal-top-fix-seat-bung-kit/p46310
Alwayslearning22 Posted 29 minutes ago Author Posted 29 minutes ago 1 hour ago, Nickfromwales said: Most of these are quick release as above. If you can identify the size of nut / thread then usually these are stainless steel (so a magnet won’t work) so don’t replace with mild steel. Do you mean just replace the nut? Is it a standard type of nut that works with that plastic
Alwayslearning22 Posted 28 minutes ago Author Posted 28 minutes ago 1 hour ago, ProDave said: https://www.toolstation.com/universal-top-fix-seat-bung-kit/p46310 Thanks Dave I’ll order one. Will that tighten well or am I going to have a sliding toilet seat
