Considering scaffold tubes for a ground mount.... thoughts?
I want to add a new ground mount array of just 5 panels located on a spare bit of yard that has a concrete base.
I'm considering making the frame from scaffolding poles as I have a good source of very cheap/free poles and they could be secured using key clamps screwed down into the concrete.
Is there a better option that I'm missing?
Unistrut.   Mechano for big boys... 🙂
Scaffold poles are harder to cut, not as easy to fit together, and you will still need a way of mounting the panels.
However, if the tubes and labour are free...
We used key clamp. No concrete, just whacked some 1m poles into the ground, leaving enough to fasten on to.  But if you've got a concrete base, just use the base/wall mount flanges.
To fasten the panels on, we created a couple of horizontals to give the angle we wanted and key clamp fasteners with  a flange with 2 holes. The panel fasteners were standard solar fasteners - you might need longer bolts but it was pretty easy to find parts and put it all together.
Those look great - ours were the standard aluminum ones, so we needed something with a hole in it on the key clamp poles.
When it comes to actually installing the panels, we made a couple of plywood jigs to support the panel in place. So a couple of pieces wider than the pole with a notch in and long enough for the top edge of the panel to rest on it. That way, you can lift the panel on, let it rest on the plywood while you fasten the brackets.
Cost: The tubes are indeed free!
Ease of cutting: I've just purchased a 'vintage'* Record pipe cutter for almost no money which means I don't need to use the demon angle grinder 👍
Connecting poles: There's a pretty huge selection of scaffolding tube connectors for about £1.50 each
Mounting panels: see my link above - although £8/clamp is pretty spicy!
AI suggests I make the frame from the scaffolding tubes and then fit unistrut to the frame to mount the panels - so what Unistrut do I need for 5 panels?
* How can a tool be 'vintage' when you can still buy new ones! 🤨
Edited by TedM
I like those scaffold/panel clamps - not seen them before but I've been out of the game a while.  Bloody expensive though!
Before MCS was introduced to extort money out of the system suppliers and legacy installers, we used unistrut for everything.
My vote would be for galvanised unistrut as it will last longer than mankind.  Having said that, if you don't mind a bit of surface rust after a few years then BZP will be fine.
We used to get ours from CEF (2 x 21 x 41 mm).  I'd use aluminium T-clamps and mount them to the strut with with short-sprung unistrut channel nuts.  (the springs are a luxury but it makes locating the bolts easier).
Be aware of the clamping zones for your panels - clamping outside the zones can induce stress and create microfractures in the cells.
In extreme cases it can cause 'rapid, unplanned dissassembly' in strong winds...
