I want to add a new ground mount array of just 5 panels located on a spare bit of yard that has a concrete base.
I'm considering making the frame from scaffolding poles as I have a good source of very cheap/free poles and they could be secured using key clamps screwed down into the concrete.
Is there a better option that I'm missing?
Unistrut.   Mechano for big boys... 🙂
Scaffold poles are harder to cut, not as easy to fit together, and you will still need a way of mounting the panels.
However, if the tubes and labour are free...
We used key clamp. No concrete, just whacked some 1m poles into the ground, leaving enough to fasten on to.  But if you've got a concrete base, just use the base/wall mount flanges.
To fasten the panels on, we created a couple of horizontals to give the angle we wanted and key clamp fasteners with  a flange with 2 holes. The panel fasteners were standard solar fasteners - you might need longer bolts but it was pretty easy to find parts and put it all together.
Those look great - ours were the standard aluminum ones, so we needed something with a hole in it on the key clamp poles.
When it comes to actually installing the panels, we made a couple of plywood jigs to support the panel in place. So a couple of pieces wider than the pole with a notch in and long enough for the top edge of the panel to rest on it. That way, you can lift the panel on, let it rest on the plywood while you fasten the brackets.
Cost: The tubes are indeed free!
Ease of cutting: I've just purchased a 'vintage'* Record pipe cutter for almost no money which means I don't need to use the demon angle grinder 👍
Connecting poles: There's a pretty huge selection of scaffolding tube connectors for about £1.50 each
Mounting panels: see my link above - although £8/clamp is pretty spicy!
AI suggests I make the frame from the scaffolding tubes and then fit unistrut to the frame to mount the panels - so what Unistrut do I need for 5 panels?
* How can a tool be 'vintage' when you can still buy new ones! 🤨
Edited by TedM
I like those scaffold/panel clamps - not seen them before but I've been out of the game a while.  Bloody expensive though!
Before MCS was introduced to extort money out of the system suppliers and legacy installers, we used unistrut for everything.
My vote would be for galvanised unistrut as it will last longer than mankind.  Having said that, if you don't mind a bit of surface rust after a few years then BZP will be fine.
We used to get ours from CEF (2 x 21 x 41 mm).  I'd use aluminium T-clamps and mount them to the strut with with short-sprung unistrut channel nuts.  (the springs are a luxury but it makes locating the bolts easier).
Be aware of the clamping zones for your panels - clamping outside the zones can induce stress and create microfractures in the cells.
In extreme cases it can cause 'rapid, unplanned dissassembly' in strong winds...
We used 45 square unistrut for ours. Hot dip galvanised. Ring around, as price vary hugely. Ended up paying less that half the cost of my first call to local electrical wholesalers and had 6m long lengths delivered free.
Stupid questions probably but how much gap do I need between panels?
I'm going for 5 panels at 1134mm wide each.
Can I get away with 2 x 3m unistrut for each horizontal run?
(scaffolding poles being delivered today)
Assuming 5x1 row then no!   5 x 1134 = 5.67m without considering the clamps (assuming approx 25mm width for each clamp that would add an additional 150mm)
Best get 2 lengths at 6m.
You need to make sure that you add enough support to the unistrut rails with the scaffold poles - a proposal sketch would be useful.
If you have large overhangs with unsuported unistrut then use 41 x 41mm unistrut instead of 21 x 41 mm.
I'm actually swinging back towards all scaffold pole construction using those ebay clamps (price comes down when you buy 12) as it will handle overhangs better and the poles are free.
I'll see about doing a sketch.
Edited by TedM
Something along these lines.
Front will be around 500mm high and the back will be around 2000mm high (whatever to give 45-50 deg angle).  There will be two diagonals on the rear uprights for bracing.
I've just come across suppliers of tube and plate and fixings at very good prices. metals4U sort of names. Google it.
Better than going through ebay I'd think.
eg I wanted a pair of steel plates cut  to length  4.6m long. They arrived in 2 days for about £15 delivery  ( obv not by Evri).
So your poles could all be precut to length by them and you know the fixings will be compatible.
Please post pics on completion.
I need to do this when the field dries out a bit and is rather less of a swamp.
Sadly i dont have a free suply of poles, though i do have a fair bit of unistrut.
Whatever you do, its damn expensive!
I have literally no idea why I drew the ground mount like that..... so many uprights!! 🤦‍♂️
This is how it's actually going to look with just 6 uprights - 2m between each set should be fine, but I can always ask my mate who owns a large scaffolding co (hence the free poles 😉)
In true Blue Peter fashion - here's one we did earlier...
Ours was all done with standard key clamp bits and some solar panel clamps.  Can't remember who we used for the poles and clamps but we did work out how many of each length of pole we needed, so they were delivered ready to start construction.
The poles in the earth are 1m long, whacked in by our builder for a flat pack of beer...
EDIT - should have added that we set the panels at 45 degrees to maximise winter output rather than the 35 degrees that PVGIS suggested. The actual annual total for 45 degrees was only just under the PVGIS 'optimum' but output was shifted away from the summer towards the winter.
Edited by Bramco
That looks good 👍
A little update on mine..... my mate is sending a team over next week to build it for me!!
I'm obviously not trustworthy 😬
Here's a roofing batten version. Old hollow concrete blocks set in the ground keep it all on the floor and have done for 3 winters so seem OK. Under £100 for batten, panel clamps and stainless screws.......already had the blocks, DPM and fencing wire for diagonal bracing
You could always look at a design that allows the array to tilt at different angels for summer / winter.
We did this for a customer many years ago and it made quite a difference to his outputs - he kept daily records, and after 2 years had worked out the optimal time of year to adjust the angles which was a 30 minute job with spanners twice a year.
I can't remeber the details of the frame we used but I can see it could work well with scaffold tubes as it would be easy to create a pivote around the poles.
Trouble is the ideal angle really changes on a daily basis, even an hourly basis if you wanted to be really fussy. I just have around half my panels at 45 degs and the others vertical. Also have 2 set horizontal and they generate nothing mid winter.
Complication added, really depends on export limits if it worth changing angles (and if you actually get paid). We are limited to G98 exports, so even in February we get plenty of clipping in the middle of the day if the battery is already fully charged. So no benefits for me, having the complexity. Simple fit and forget
Fair enough 🙂
Our customer was an Econutter who was eeking out every last watt.  Eventually, even he only adjusted his array twice a year.  End of October and end of April from memory.
In the first year he changed it daily; his panels faced slightly east of East of South, if he laid them back in the late afternoon he captured a few more rays before the sun set.
Like I said, 'Econutter'.  You can afford to play if you are retired I guess!
These days an automated single axis tracker would be easy to set up, though
I'm going to try and copy that if you don't mind!
Looks like it should give good access to the back of the panels - there's a wall at the back of mine but I want to get in a keep under the panels fairly clear.
Quote
I'm not looking to export anything!
There's an Immersun that heats a 250L Megaflo after which spare power will go into the electric unfloor heating in the kitchen which takes 2kW when it's heating.
I also have electric underfloor in the bathroom plus a few electric heaters around the house all of which are controlled by Shelly relays.  I have a number of Shelly Actions set that will switch various devices on and off depending upon how much power is being exported - such as this one:
I've also got another E/W facing array that gets the original FIT payment (for every kWh it generates) I'm not bothered about exporting anything really.
[The new array is completely separate to the existing one]
Edited by TedM
I'm still undecided as to how to clamp the panels 😩
Either use the eBay clamps and just fit them directly to scaffold tube, or save a little money and somehow fit mounting rail to the scaffold tubes and use 'real' clamps to hold the panels.
Realistically there's probably no difference in price by the time I've bought something to fit the mounting rail to the scaffold tubes.
