-rick- Posted yesterday at 13:44 Posted yesterday at 13:44 4 minutes ago, jimseng said: The interesting thing about much of the discussions about fires and Lithium batteries is that they never seem to refer to LiFePo4 batteries. Completely anecdotal but I've seen more reports of fires from loose connections on 48V wiring to batteries than I have of LifePo4 batteries burning.
jimseng Posted yesterday at 13:45 Author Posted yesterday at 13:45 2 minutes ago, saveasteading said: Or that fire extinguisher as above, but somehow automatically. Someone could sell these. The Fogstar batteries I have just bought have this built in.
SteamyTea Posted yesterday at 13:48 Posted yesterday at 13:48 1 minute ago, saveasteading said: So a water spray at an early stage could reduce the temperature enough That is what I was questioning. I don't know the answer.
jimseng Posted yesterday at 13:49 Author Posted yesterday at 13:49 1 minute ago, -rick- said: Completely anecdotal but I've seen more reports of fires from loose connections on 48V wiring to batteries than I have of LifePo4 batteries burning. The key words there are "anecdotal" and "loose connections". Putting 32kw of energy in a small box carries a risk that if you allow it to escape quickly and uncontrolled it is probably going to say "boom". That is the same for Lead acid batteries, which also give off very nasty gas when they go wrong.
SteamyTea Posted yesterday at 13:51 Posted yesterday at 13:51 A bit about exothermic and endothermic reactions here. https://chem.libretexts.org/Bookshelves/Physical_and_Theoretical_Chemistry_Textbook_Maps/Supplemental_Modules_(Physical_and_Theoretical_Chemistry)/Chemical_Bonding/Fundamentals_of_Chemical_Bonding/Bond_Energies
Russdl Posted yesterday at 14:05 Posted yesterday at 14:05 Looks like the F-500 EA is the one to go for. Whatever that is.
saveasteading Posted yesterday at 15:02 Posted yesterday at 15:02 Heath Robinson could do this. Fire burns through string supporting extinguisher, which topples forward onto its lever which opens it and the fire goes out., It would be better if every supplier included a self-extinguishing system, and insurance cover for house and contents.
ProDave Posted yesterday at 15:36 Posted yesterday at 15:36 2 hours ago, Russdl said: No, they make their own. Short of submerging them they can’t be extinguished and if you remove them from the water before they’ve cooled down sufficiently they’ll be off again. I have seen a video of a submerged EV still burning underwater. So that won't extinguish the blaze buy might keep it cool enough to limit the spread until it has burned all it's fuel.
jimseng Posted yesterday at 15:46 Author Posted yesterday at 15:46 At the risk of repeating myself, that video is of non LiFePo4 batteries! It looks scary but that sort of thermal runaway is specifically what LiFePo4 batteries were designed to avoid. I guess that's why they are starting to put them in EVs now. There are many but this is quite a fun video: 2
Dillsue Posted yesterday at 16:00 Posted yesterday at 16:00 11 minutes ago, jimseng said: At the risk of repeating myself, that video is of non LiFePo4 batteries! It looks scary but that sort of thermal runaway is specifically what LiFePo4 batteries were designed to avoid. I guess that's why they are starting to put them in EVs now. There are many but this is quite a fun video: Reminds me of peeing around with fireworks as a kid and getting chased by ripraps, helicopters and aeroplanes!
kandgmitchell Posted 6 hours ago Posted 6 hours ago The opening post was about being told by a BCO that 120 minutes fire resistance was needed for battery storage. Since the purpose of the regulations is to secure the health, safety and welfare of persons using the building (extended somewhat by mission creep to Parts L, S, R etc.) then being required by using statutory powers to go beyond the usual 30 minutes FR for two storey dwellings would seem excessive without the authority to do so. The occupants should have evacuated and fire fighters would not have to be inside. However, that is not to say that the OP shouldn't consider upgrading the fire resistance for their own property protection but that is entirely up to them, not the whim of the BCO who may personally think it's a good idea (and I'm not necessarily arguing that it isn't). 1
saveasteading Posted 5 hours ago Posted 5 hours ago The bco can't be an expert on everything, especially with changing technology. The regulations require safety, so I think it is fair that he asks for a formal proposal with references and risk assessment.
mjc55 Posted 5 hours ago Posted 5 hours ago Sigenergy batteries (which we are considering) do have inbuilt fire suppression. I do not know how common this is.
Nickfromwales Posted 22 minutes ago Posted 22 minutes ago 120 mins is barking mad tbf. If this is inside a domestic residence and the battery(ies) go up in flames, after 15-30 mins anyone near it would be gasping their last ever gulps of air. Early detection and a robust plan to GTFO is all you’ll have for a choice. Attempting to tackle it would require halon or CO2, but in an enclosed plant room that’ll kill you too. If these go up in flames, grab the cat and get out quick. The automatic fire suppression demos are all lovely, but unless it’s a bloody huge reservoir then these just won’t have the legs to keep a terminally ill battery from showing you exactly what it’s capable of.
saveasteading Posted 12 minutes ago Posted 12 minutes ago 7 minutes ago, Nickfromwales said: after 15-30 mins anyone near it would be gasping their last And that's all that really bothers the fire service. But for an extra layer of plasterboard and some rockwool, isn't it worth stopping or slowing the spread?
