Hello, I have some reasonably large sheds whose fibre cement roof has definitely reached end of life. I am a big corrugated iron fan, so that's be my default replacement option. Someone has suggested to me why not oversheet rather than go through the pain of (likely Type C asbestos) sheet removal and disposal. Leaving it in place would also help with the condensation challenge. my budget is also insufficient for eg insulated metal panels
Research on oversheeting brings up a specialist GRP product with the same Big 6 profile so it sits snugly over. Or with say box profile sheets there are multiple recommendations to first batten out the roof and then lay the metal sheets on the battens. I guess it makes sense - provide a flat plane for the sheets to be screwed into. But it does leave eaves gaps to be dealt with
My dumb questions are
- what does the battening achieve that simply laying the box profile sheets onto the fibre cement sheets and drill and screw through both to the wooden purlins below? I have to do that for the battens anyway
- I don't have the budget for any insulation, that can come later, but any benefit from a vapour barrier sandwich between the existing roof and the new sheeting?
Regards
Glenn
Yikes......
Sounds like a recipe for a forever roof.Not in a good way unfortunately.
What you have at the moment can be tackled systematically and safely.
If you layer up new roof on old asbestos noone will want to come within a mile of it .
If you take appropriate precautions you can remove the Asbestos yourself and get it disposed correctly. If you're able to take the time and care it'll save a lot vs a contractor.
The Big6 profile metal sheets “should” lay over the top, but won’t! The original sheets are unlikely to be dead straight and the fixings stick up etc. as above, remove the existing and replace. Over batten and sheet is pretty straight forward but the old sheets are likely to crack in multiple locations and you will regret not doing it right once.
Regarding insulating insulated sheets aren't tremendously expensive.
Even a minimal 25mm or so of Insulation would be worth it.
If you really can't afford it or just want to stop condensation drips I would layer a run of chicken mesh over the purlines to support roofing felt and then use standard sheeting.
There's a roof very almost level done on a stable here and it has never dipped.
This work would fall under the Building Reg requirements (assuming England) to upgrade the roof insulation. Generally max Uval of 0.18 W/m2K (IIRC) above conditioned space or max 0.35 W/m2K above non-conditioned space. Building Control needs to be involved.
In a shed?
15 minutes ago, Nickfromwales said:
Might be really nice sheds ;)
I guess.
So we are talking (from https://www.planningportal.co.uk/permission/common-projects/outbuildings/is-building-regulations-approval-needed-for-an-outbuilding):
Quote
If the floor area of the building is between 15 square metres and 30 square metres, you will not normally be required to apply for building regulations approval providing that the building contains NO sleeping accommodation and is either at least one metre from any boundary or it is constructed substantially of non-combustible materials.
So @Glenn when you say large, how large?
27 minutes ago, -rick- said:
In a shed?
Yup. But check with your Building Control Body as it it responsible for enforcement
I've done loads of things commercially.
It kept factories going.
There is still going to be an end of life cost in demolition, but that might be 30 years because you've fixed the roof.
We always fitted a steel over-rail system first because direct oversheeting won't fit and the existing fixings will clash.
Then you can use any metal profile you want.
BUT it's not easy. Don't fall through the roof, and don't make dust.
Thank you again for all the replies, really good information and a lot to balance. It's about 180m2 of shed(s) in one 'block' as a single building. Ex-agricultural. condition best described as characterful, under the benign neglect of the previous farmer owner. I won't worry BC for a re-roof - while insulating the roof is all very well, much of the space remains well ventilated shall we say to accommodate swallows and other birds' comings and goings. Sole aim is for a watertight roof.
So it's your decision. With any over-roof the big 6 will dry and become benign so will last until the building is removed or needs altering.
Now or later the asbestos will need removing.
If you can afford it I'd strip it and tip it now.
It doesn't need specialists but does need control.
Then your new cladding fixes to the purlins and so is easy.  The costs balance a bit because of the easier cladding and you've got rid of the asbestos. The specialist skip is about £2,000.
You can also think of adding flashings and efficient gutters to improve the quality.
I've done just this on 150m2 outbuilding. We used 40mm composite cladding for a tiny bit of insulation and to stop condensation.
