saveasteading Posted 9 hours ago Posted 9 hours ago We've been assuming 2 x heat pumps because there will be two distinct zones. It's too big for one unit on single phase. But it is all one family building and we have 3 phase power available, already into the premises. I'm aware of the principles of 3 phase efficiency on motors, so presumably this will be preferable. Maybe also not require additional internal distribution pumps. But are there any downsides? The only one I foresee is family arguments over dividing the bill. Any technical issues?
-rick- Posted 9 hours ago Posted 9 hours ago Doesn't really matter too much on modern heatpumps as they are all inverter driven. ie, they convert the incoming power to DC and then generate custom 3 phase (both voltage and frequency) to drive the motor. A traditional heat pump that didn't have the inverter would gain a little efficiency (and reliability from less components) from 3 phase supply but irrelevant today. Generally, 3 phase heat pumps don't start until about 15kw. Is your heat loss really that high? Anything you can do to lower it? 2
SimonD Posted 8 hours ago Posted 8 hours ago 19 minutes ago, -rick- said: Generally, 3 phase heat pumps don't start until about 15kw. Is your heat loss really that high? Anything you can do to lower it? The Panasonic M series Aquarea is available in a 9kW 3ph unit. It is very nice indeed and super quite, even if it is physically quite large. 1
saveasteading Posted 8 hours ago Author Posted 8 hours ago 34 minutes ago, -rick- said: Anything you can do to lower it? Teach people to shut doors, and not wash dishes under a hot tap.
-rick- Posted 8 hours ago Posted 8 hours ago (edited) 9 minutes ago, saveasteading said: Teach people to shut doors, and not wash dishes under a hot tap. I was thinking more along the lines of add more insulation, reduce air leakage, etc. Assumed this question was in relation to the building you are in the process of converting from a cow shed. In which case there should be lots you can do to improve things if your loss is that high. (Though I'm not sure how you'd be meeting building regs on a new construction with a high heat loss). If it's an older building, then likely lots of easy things you can do to bring the loss down. And as usual on this forum, it's worth checking where you have got the heat loss calcs from? The heatpump installers have a terrible record of vastly overestimating it which can then lead to wrongly sized systems and poor operation. Though as a regular I assume you know all this already? Edited 8 hours ago by -rick-
SimonD Posted 8 hours ago Posted 8 hours ago 1 minute ago, -rick- said: And as usual on this forum, it's worth checking where you have got the heat loss calcs from? The heatpump have a terrible record of vastly overestimating it which can then lead to wrongly sized systems and poor operation. Though as a regular I assume you know all this already? Good point. Given his background, experience and attention to detail, I just assumed @saveasteading would have it all covered off.
saveasteading Posted 8 hours ago Author Posted 8 hours ago 10 minutes ago, -rick- said: lots you can do to improve Don't worry on that score. It's effectively a new building. The floor insulation was delivered yesterday. 4 lorry loads for 300mm th. No , my over-whimsical comment is that behaviour change is all we could do. Or add MVHR which we have decided not to after due consideration of cost/benefit. I'd have to move chairs to check but I think we were looking at 7 +5 kW and now 1 x 11kW. There seem to be lots.
JohnMo Posted 7 hours ago Posted 7 hours ago You building must be massive to need that size heat pump, as effectively a new build? 5-600m²? 2
saveasteading Posted 7 hours ago Author Posted 7 hours ago 16 minutes ago, JohnMo said: 5-600m² yup. There will be a fair bit of heat wasted to the high vaulted spaces, and some biggish glazing. but otherwise it's normal. If the heat pump/s end up turning off more than expected then we can live with that. We are fortunate in having a known, proven big-time plumber who is advising foc first, then we are prob working cost plus. and I think we will buy the materials... again a favour and based on trust... Not that they will be cheap, but it is far too big for a smaller outfit anyway. The reason I am asking you, dear BH posters, is the overview, beyond the simple sums. eg noise and airflow. how lumpy a cable to get through the house. and the unknown unknowns.
SteamyTea Posted 5 hours ago Posted 5 hours ago 2 hours ago, saveasteading said: I'd have to move chairs to check but I think we were looking at 7 +5 kW and now 1 x 11kW. There seem to be lots Why not one HP and some supplementary resistance heating for the coldest times?
Nickfromwales Posted 5 hours ago Posted 5 hours ago 2 hours ago, saveasteading said: Teach people to shut doors, and not wash dishes under a hot tap. #victoriandad lol. 2
Nickfromwales Posted 5 hours ago Posted 5 hours ago 1 hour ago, saveasteading said: There will be a fair bit of heat wasted to the high vaulted spaces, and some biggish glazing. but otherwise it's normal. 2 hours ago, saveasteading said: Or add MVHR which we have decided not to after due consideration of cost/benefit.
Wil Posted 5 hours ago Posted 5 hours ago I’ve got 2 3ph ASHPs. Cables not particularly chunky as they’re running at less than 20A as the power is split across the phases. That was my main driver to keep the loads spread on my connection and avoid a huge peak consumption on a single phase which would exceed my 60A fuses. Yes they’re big. They’re 15m away from the house behind an outbuilding so noise isn’t an issue. Pipe runs were annoying but are what they are. 300m2 and seem to run at about 5kW heat loss at 3degrees outside temp. House is a bit of a frankensteins monster of new bit, well insulated and old bit not so much. 2
