BotusBuild Posted February 14 Posted February 14 1 minute ago, JohnMo said: Have been in his man shed? The only room finished in his 10 year build? 1
MikeSharp01 Posted February 14 Posted February 14 1 hour ago, JohnMo said: Home automation = hours/days arsing about, to save seconds or maybe even nothing in reality. You cannot realy believe that because you already have a lot of automaton in your house it's just not all joined up with a unified majordomo. So it's all about where you are in the automaton onion layers, where you automate everything on the outside and you just have digital thermometer on the inside. Between them are just layers but if you peel down the layers it still looks like any other onion. So home automation is about layers, if you have anything automatic you must have home automtion. QED 1
Pocster Posted February 14 Author Posted February 14 4 minutes ago, MikeSharp01 said: You cannot realy believe that because you already have a lot of automaton in your house it's just not all joined up with a unified majordomo. So it's all about where you are in the automaton onion layers, where you automate everything on the outside and you just have digital thermometer on the inside. Between them are just layers but if you peel down the layers it still looks like any other onion. So home automation is about layers, if you have anything automatic you must have home automtion. QED Thermostat is automation car lights come on when dark it’s everywhere - just don’t think of it . Time to take it up from HA doing a lot ( and working surprisingly well ) . Local LLM gold standard 💪
Onoff Posted February 14 Posted February 14 28 minutes ago, BotusBuild said: What's in my head every time I read a computer related thread from @Pocster on BH 😀 I spy a huge box of tissues on the right... 😉 1 1
Pocster Posted February 14 Author Posted February 14 (edited) 24 minutes ago, MikeSharp01 said: You cannot realy believe that because you already have a lot of automaton in your house it's just not all joined up with a unified majordomo. So it's all about where you are in the automaton onion layers, where you automate everything on the outside and you just have digital thermometer on the inside. Between them are just layers but if you peel down the layers it still looks like any other onion. So home automation is about layers, if you have anything automatic you must have home automtion. QED I read recently that openAI said 99% use ChatGPT as a toy . Without spending a fortune on say Claude tokens chat gives the best of both worlds for me ; creativity and technical. It stuns me that after the internet and now LLM that people just don’t leverage the capabilities they have access to . Still as you say depends what layer you are at on the onion … Edited February 14 by Pocster
-rick- Posted February 14 Posted February 14 2 hours ago, Pocster said: Gonna need more RAM , gonna need more GPU … Bad timing. Gonna need to attract VC funding or find a mortgage for your project 1
Pocster Posted February 14 Author Posted February 14 16 minutes ago, Onoff said: I spy a huge box of tissues on the right... 😉 Kitchen roll for big boys
JohnMo Posted February 14 Posted February 14 17 minutes ago, MikeSharp01 said: You cannot realy believe that because you already have a lot of automaton in your house I do have a legacy UFH manifold controller with room sensors. It's connected to heat pump, a simple standalone timer to immersion, and standalone PIR sensors to various outside lights. The other automation I have is related to battery, but that is via the GivEnergy portal to control charge times. Home assistant is used but as simple monitoring tool, it has 2 automations, one to collect solar forecast, the other to tell me if PV generated is behind forecast, so I can check to make sure nothing has tripped off or panels aren't dirty. Nothing that actually matters if they don't work.
Pocster Posted February 14 Author Posted February 14 1 minute ago, -rick- said: Bad timing. Gonna need to attract VC funding or find a mortgage for your project SWMBO away . If another ‘ box ‘ appeared in IT cupboard she would not notice 😉
Nickfromwales Posted February 14 Posted February 14 46 minutes ago, SteamyTea said: I used to work for the RNIB. Not for long though, even they could see through you
SteamyTea Posted February 14 Posted February 14 15 minutes ago, Nickfromwales said: Not for long though, even they could see through you Got felt up a lot.
