As title suggests, I’m after advice re polished concrete floors, the cost/practicalities and alternatives.
project is a barn conversion, we’ve already got a 200mm structural slab which is 220m2 and have allowed for 150mm further flooring but this must include UFH, insulation etc.
We would like something resembling polished concrete (mid shine) but are fully open to any other suggestions that don’t cost £100 m2 plus.
My contractor is very practical but has limits.
any help and advice would be appreciated
150mm allowed for insulation and screed?
Insulation below and around the structural slab?
Where are you in the project - just planning or kart way through build?
So a very heavy warehouse for forklifts and racking? You can do almost anything over that.
Your internal walls and even steel columns could go straight on your floor with SE input.
Above that I would have minimum 150 pir then a screed with ufh.
As prev discussed I don't see the attraction of a polished slab in a house, perhaps because I've built hundreds and see them as functional. I'll find a photo to emphasise this.
Concrete can work with the right design. Does need careful thought though and I certainly don't think it's worth a premium price.
@IanR did a poured resin floor that might be an alternative:
Microcement exists but isn't cheap. The only other suggestion that comes to mind is exploring commercial concrete contractors rather than 'polished concrete' specialists. I've no real-world experience, just researching for a future build but if you haven't already looked, have a look at https://concria.com/dry-shake-floor/ and their polishing system. Would only work on a large floor area without obstructions, but if thats what you have then might be a lot cheaper than conventional polished concrete.
I've posted a real floor after 15 + years as a separate post.
Dryshake I've used once. It makes the surface harder and can add colour, but it still crazes.
If a domestic client wanted a concrete look I'd recommend large porcelain with that effect ( very realistic,  as concrete tiles really could be made crack free). £50/m2.
Resin does not, of course, look like concrete.
If budget is of interest, you don't need concrete over concrete at all.
Porcelain tiles? I considered polished concrete but couldn’t stomach the cost for something I thought less durable.
I can recommend the poured resin option. I also considered all the alternative options. Mines a two colour resin, in the style of a polished concrete finish and most people that visit ask if it is a polished concrete, even though it wasn't the intention to be an exact copy. Lot's of colour options and the different lacquer coats allow for matt, sheen or gloss finishes. I've been pleasantly surprised at how durable it is. It still cleans up (mostly) like new after 9 years and ours has a hard life. They can be re-top coated as well should it ever start to show the wear and tear or you want a different colour/finish.
24 minutes ago, saveasteading said:
On top of what?
Can you recall the price level?
Directly on to the Insulated Raft. At the time it was £75/m^2.
If you follow the link to my post that -rick- posted, it's got the full info in there.
Yes for all, nothing below the structural slab hence the need to insulate on top.
We are about to break ground in March so full planning approved -
I’ve made contact with Ian thanks for this.
This has put me right off! Thanks for this…
Thanks, I’ve DM you for more details.
150mm for insulation and any screed above just isn't enough, you should be doing 150mm if PIR insulation at least with UFH, ideally 200mm. Then screed above that, would look at the minimum 50mm.
Increase the floor build up by 50mm to 200mm - 150mm insulation, 50mm liquid screed. Then either live with 50mm lower ground floor ceilings, or raise everything up by 50mm, which nobody will ever notice.
Thanks both, I actually think my contractor has already said 200 so that all makes sense. - I assume it is 150mm insulation and then 50mm screed but I’ll check.
