Jakekibb Posted 20 hours ago Posted 20 hours ago As title suggests, I’m after advice re polished concrete floors, the cost/practicalities and alternatives. project is a barn conversion, we’ve already got a 200mm structural slab which is 220m2 and have allowed for 150mm further flooring but this must include UFH, insulation etc. We would like something resembling polished concrete (mid shine) but are fully open to any other suggestions that don’t cost £100 m2 plus. My contractor is very practical but has limits. any help and advice would be appreciated
JohnMo Posted 15 hours ago Posted 15 hours ago 4 hours ago, Jakekibb said: have allowed for 150mm further flooring but this must include UFH, insulation etc. 150mm allowed for insulation and screed? 4 hours ago, Jakekibb said: 200mm structural slab Insulation below and around the structural slab? Where are you in the project - just planning or kart way through build?
saveasteading Posted 15 hours ago Posted 15 hours ago 4 hours ago, Jakekibb said: already got a 200mm structural slab which is 220m2 So a very heavy warehouse for forklifts and racking? You can do almost anything over that. Your internal walls and even steel columns could go straight on your floor with SE input. Above that I would have minimum 150 pir then a screed with ufh. As prev discussed I don't see the attraction of a polished slab in a house, perhaps because I've built hundreds and see them as functional. I'll find a photo to emphasise this.
-rick- Posted 15 hours ago Posted 15 hours ago 17 minutes ago, saveasteading said: As prev discussed I don't see the attraction of a polished slab in a house, perhaps because I've built hundreds and see them as functional. I'll find a photo to emphasise this. Concrete can work with the right design. Does need careful thought though and I certainly don't think it's worth a premium price.
-rick- Posted 14 hours ago Posted 14 hours ago 5 hours ago, Jakekibb said: We would like something resembling polished concrete (mid shine) but are fully open to any other suggestions that don’t cost £100 m2 plus. @IanR did a poured resin floor that might be an alternative: Microcement exists but isn't cheap. The only other suggestion that comes to mind is exploring commercial concrete contractors rather than 'polished concrete' specialists. I've no real-world experience, just researching for a future build but if you haven't already looked, have a look at https://concria.com/dry-shake-floor/ and their polishing system. Would only work on a large floor area without obstructions, but if thats what you have then might be a lot cheaper than conventional polished concrete.
saveasteading Posted 14 hours ago Posted 14 hours ago I've posted a real floor after 15 + years as a separate post. Dryshake I've used once. It makes the surface harder and can add colour, but it still crazes. If a domestic client wanted a concrete look I'd recommend large porcelain with that effect ( very realistic, as concrete tiles really could be made crack free). £50/m2. Resin does not, of course, look like concrete. If budget is of interest, you don't need concrete over concrete at all.
Bonner Posted 6 hours ago Posted 6 hours ago Porcelain tiles? I considered polished concrete but couldn’t stomach the cost for something I thought less durable.
IanR Posted 6 hours ago Posted 6 hours ago 7 hours ago, -rick- said: @IanR did a poured resin floor that might be an alternative: I can recommend the poured resin option. I also considered all the alternative options. Mines a two colour resin, in the style of a polished concrete finish and most people that visit ask if it is a polished concrete, even though it wasn't the intention to be an exact copy. Lot's of colour options and the different lacquer coats allow for matt, sheen or gloss finishes. I've been pleasantly surprised at how durable it is. It still cleans up (mostly) like new after 9 years and ours has a hard life. They can be re-top coated as well should it ever start to show the wear and tear or you want a different colour/finish.
saveasteading Posted 4 hours ago Posted 4 hours ago 2 hours ago, IanR said: poured resin On top of what? Can you recall the price level?
IanR Posted 3 hours ago Posted 3 hours ago 24 minutes ago, saveasteading said: On top of what? Can you recall the price level? Directly on to the Insulated Raft. At the time it was £75/m^2. If you follow the link to my post that -rick- posted, it's got the full info in there.
