MPH243 Posted 6 hours ago Posted 6 hours ago Get the Dc18rc quick charger, it is half the time to charge. If you are doing something that drains batteries you will be kicking yourself. (Guess how I know). 1
joth Posted 6 hours ago Posted 6 hours ago I just ordered 4x 6000mAh Li-ion batteries from AliExpress -- £5 each! They claim to be genuine Makita, of course they would wouldn't they, but I've had pretty good results from bulky NiCads I previously bought there so thought worth a punt Been really enjoying the pruning chainsaw I bought recently.
Crofter Posted 5 hours ago Author Posted 5 hours ago 48 minutes ago, MPH243 said: Get the Dc18rc quick charger, it is half the time to charge. If you are doing something that drains batteries you will be kicking yourself. (Guess how I know). Yes I've just realised that. Could have made a bit of a mistake there! The 18RC fast charger is about £17 in some places, worth the extra if it saves me buying an extra battery.
Crofter Posted 5 hours ago Author Posted 5 hours ago 42 minutes ago, joth said: I just ordered 4x 6000mAh Li-ion batteries from AliExpress -- £5 each! They claim to be genuine Makita, of course they would wouldn't they, but I've had pretty good results from bulky NiCads I previously bought there so thought worth a punt Been really enjoying the pruning chainsaw I bought recently. I'm very wary of knock off batteries. But I have only owned two. The first was supposed to be 3Ah but it's so light that I don't think it's even 1Ah. It also behaves differently to my other, genuine, batteries: it will grind down slower and slower and eventually stop. The others will start to dip and then cut off abruptly. This means that the genuine ones have some sort of circuitry inside them, presumably a BMS, which prevents deep discharge. The cheap one is likely just a pack of cells. My worry is that, without any sort of BMS, the cheap battery is unsafe and could fail to detect any problems. I never leave it charging unattended. The other knock off battery I have is the one that started smoking after a dead short, as described earlier. I'm an absolute cheapskate but I draw the line at fake batteries now. 1
G and J Posted 4 hours ago Posted 4 hours ago 4 hours ago, Onoff said: I'd like a dual charger but quite spendy compared to the single ones. I wanted a dual charger but as a skinflint I waited till there was an offer on for a single fast charger and I put em both on a board. Simple. And cheap. Just like me. 😉
Crofter Posted 3 hours ago Author Posted 3 hours ago On 09/02/2026 at 00:21, Apache said: There is no need to go for a copy charger. Get a starter kit if you need drill driver, batteries and charger. https://www.powertoolmate.co.uk/power-tools/makita-store/cordless-powertool-kits/makita-dlx2414st-18v-brushless-twin-kit-dhp487-combi-drill-and-dtd157-impact-dri.htm £205, if you price the drill/driver, impact and the batteries separately its £250 before case and charger. That's a very good deal, well spotted. My only slight reservation is that both the driver and drill are a bit on the weedy side. The kit includes more battery than I strictly need. I'll not regret that in the long run, just I wonder if I should be looking for a slightly more beefy impact driver (that ones is 140nM max).
Onoff Posted 3 hours ago Posted 3 hours ago 6 minutes ago, G and J said: I wanted a dual charger but as a skinflint I waited till there was an offer on for a single fast charger and I put em both on a board. Simple. And cheap. Just like me. 😉 I actually thought about doing that and jumping one mains lead into the other.
Crofter Posted 3 hours ago Author Posted 3 hours ago Out of all of these tools, the recip saw is one that will likely see limited use. I'm about to replace some windows, and I thought the recip would be good to slice through the screws. Last time I was doing this I tried using a multi tool, but the blades are insanely expensive and I was averaging about two nails per blade. And I didn't really have the depth of cut required anyway. For very occasional use, maybe I should be considering a Fakita recip? The best price I can get on the real one is £83.
Nickfromwales Posted 3 hours ago Posted 3 hours ago 3 minutes ago, Crofter said: Out of all of these tools, the recip saw is one that will likely see limited use. I'm about to replace some windows, and I thought the recip would be good to slice through the screws. Last time I was doing this I tried using a multi tool, but the blades are insanely expensive and I was averaging about two nails per blade. And I didn't really have the depth of cut required anyway. For very occasional use, maybe I should be considering a Fakita recip? The best price I can get on the real one is £83. Bought both of mine used. Have beat the life out of them since, still going strong and refuse to die. https://www.ebay.co.uk/itm/177846701855?_skw=makita+18v+recip&epid=7003305250&itmmeta=01KH4VPDFDKDMYENZNNM2W9712&hash=item29687d4f1f%3Ag%3A0ycAAeSwPE9piN9A&itmprp=enc%3AAQALAAAA0GfYFPkwiKCW4ZNSs2u11xB511a3Nv7c0HhXl3iul7XiW%2BjrfdGUbP3ok1JeJn9jnZE4f0etcNloT%2Bx0jyb73fuAzKXCiT5n4J%2F9hC9nnnIXzhquKe%2BSdaCaECS8OjnpBmaOEGsJ6YuCOO%2BMoUR0vWn7wOzjc7iAf%2FpqoAnNzNDFlZYUSUE4s2me0RQqveFzSh690IMD3plfNX53yQuQtbUBPrGHdvO%2Fh5x9t7GxazIBgsRPeQdZzHc9P9OuJni1GRHY7%2FDSE2O%2Fo1Cnx9lmu0g%3D|tkp%3ABk9SR_7X2ZuJZw&LH_ItemCondition=3000 1
Crofter Posted 3 hours ago Author Posted 3 hours ago 7 minutes ago, Nickfromwales said: Bought both of mine used. Have beat the life out of them since, still going strong and refuse to die. https://www.ebay.co.uk/itm/177846701855?_skw=makita+18v+recip&epid=7003305250&itmmeta=01KH4VPDFDKDMYENZNNM2W9712&hash=item29687d4f1f%3Ag%3A0ycAAeSwPE9piN9A&itmprp=enc%3AAQALAAAA0GfYFPkwiKCW4ZNSs2u11xB511a3Nv7c0HhXl3iul7XiW%2BjrfdGUbP3ok1JeJn9jnZE4f0etcNloT%2Bx0jyb73fuAzKXCiT5n4J%2F9hC9nnnIXzhquKe%2BSdaCaECS8OjnpBmaOEGsJ6YuCOO%2BMoUR0vWn7wOzjc7iAf%2FpqoAnNzNDFlZYUSUE4s2me0RQqveFzSh690IMD3plfNX53yQuQtbUBPrGHdvO%2Fh5x9t7GxazIBgsRPeQdZzHc9P9OuJni1GRHY7%2FDSE2O%2Fo1Cnx9lmu0g%3D|tkp%3ABk9SR_7X2ZuJZw&LH_ItemCondition=3000 Haha, I'd already looked at that one! I'll probably just buy new though. These things just don't depreciate at all- that one is about 75% of the new price!
Apache Posted 3 hours ago Posted 3 hours ago 20 minutes ago, Crofter said: My only slight reservation is that both the driver and drill are a bit on the weedy side. The kit includes more battery than I strictly need. I'll not regret that in the long run, just I wonder if I should be looking for a slightly more beefy impact driver (that ones is 140nM max). What car do you drive? My Discovery's wheel nut torque is 145nm! Too much and you shear things and damage heads. (I never thought I'd say it but I reach for my 12V impact driver the most, and only use 18V for the really big stuff)
G and J Posted 3 hours ago Posted 3 hours ago 17 minutes ago, Apache said: What car do you drive? My Discovery's wheel nut torque is 145nm! Too much and you shear things and damage heads. (I never thought I'd say it but I reach for my 12V impact driver the most, and only use 18V for the really big stuff) I’m using the most basic Makita 18v impie - it’s showing wear and tear but then, it’s built a timber frame house with me. I can understand higher spec ones maybe lasting longer in professional hands, but otherwise I think the basic one does everything brilliantly
Nickfromwales Posted 3 hours ago Posted 3 hours ago 20 minutes ago, Crofter said: Haha, I'd already looked at that one! I'll probably just buy new though. These things just don't depreciate at all- that one is about 75% of the new price! Yup, just wasn't sure of how much of a tight-arse you were
G and J Posted 3 hours ago Posted 3 hours ago 38 minutes ago, Onoff said: I actually thought about doing that and jumping one mains lead into the other. I cable tied a two gang extension lead onto the board. Saves wiring and I’ve two separate chargers for when I eventually return to normal life, whatever that might be.
G and J Posted 3 hours ago Posted 3 hours ago 2 minutes ago, Nickfromwales said: Yup, just wasn't sure of how much of a tight-arse you were I bought my sabre saw when we had started to demolish the timber frame bungalow. Brilliant. Before that I felt it was just too rough. However, it’s now part of the base armoury. I think of it as a super high power jigsaw.
Nickfromwales Posted 3 hours ago Posted 3 hours ago Just now, G and J said: I bought my sabre saw when we had started to demolish the timber frame bungalow. Brilliant. Before that I felt it was just too rough. However, it’s now part of the base armoury. I think of it as a super high power jigsaw. I use mine for tree lopping, cutting up scrap wood for the chimenea in the summer, and all sort of random stuff. Once you have tools, you use them.
G and J Posted 3 hours ago Posted 3 hours ago I would naturally reach for my single handed chainsaw for such (aka light sabre). The sabre saw will see least use in civilian life, methinks. 1
