Beelbeebub Posted September 17 Author Posted September 17 22 minutes ago, ProDave said: We WERE self sufficient in electricity production when we mined and burned our own COAL. If we had half an eye on energy security back then, we would have not bothered with using gas for electricity generation, and instead ramped up renewable generation much earlier and decreased coal burning as renewables ramped up. We are now paying the price of short term policies without regard to energy security. We were self sufficient in gas for a fair while so the switch wasn't as completely mad idea. But we are where we are and our best par forward is ramping up renewables - investing in battery storage at a domestic level, longer term storage at a national level and electrifying as much as we can.
SteamyTea Posted September 18 Posted September 18 10 hours ago, ProDave said: If we had half an eye on energy security back then, we would have not bothered with using gas for electricity generation It was partly because of the insecure coal supply that we changed to gas. The insecurity was caused by the British labour force. We had out first interconnect to France in 1961, a 160 MW.
sgt_woulds Posted September 18 Posted September 18 2 hours ago, SteamyTea said: The insecurity was caused by the British labour force. It was due to the exploitation of the British Labour force and ideoligy of the Neo-Liberal government mindset that hated the idea of a nationlised industry that they couldn't divert money from. They didn't consider national security in their energy policy, other than stockpiling coal reserves so they had breathing room to crush the 'rable rousing unions'. Then they sold off another national asset (North Sea Oil and Gas) to be exploited by private companies and used the 'environment' as an excuse. I'm sure others here can provide their own more nuanced version of events... 🙂
sgt_woulds Posted September 18 Posted September 18 Forwarded this email? Subscribe here for more The North Sea is not just about the North Sea The weird and wonderful world of gas, in all its different flavours. And what the strange chemistry of methane has to do with one of the most controversial issues facing the new UK government Aug 18 You will know, if you’ve read Material World, that there are many different flavours of oil: sweet and sour, heavy and light, gloopy Canadian tar sands and light, clear fracked crude. You will also know, if you’ve read much of my subsequent stuff here, that such things actually turn out to have outsize, sometimes geopolitical significance. But did you know that something similar also goes for natural gas? When it first comes out of the ground, natural gas can also be sweet or sour, depending on its sulphur content. It can be wet or dry, depending on how many other liquids have come up in the pipes alongside the gas. Natural gas from Algeria is decidedly different (richer and heavier) than the stuff that comes from Trinidad as a consequence of the variety of organic material laid down millions of years ago and the conditions under the ground since then. I learnt this a month or so ago, touring round the Isle of Grain LNG terminal, while filming a documentary for Sky News. The film itself (which I’d love you to watch if you have a moment) is really about something else, about the fate of the North Sea and the question, significant here and, I think, actually of some international import, of whether Britain should be doing more drilling in future. But as is always the way when you’re filming these things and trying to compress it all into a finished film (even a mammoth 30 minute film - mammoth, at least, by Sky News standards), some of the interesting, chewy, nerdy stuff ends up on the cutting room floor. So it was with the various different flavours of natural gas. But such things are actually quite consequential. Consider the gas in Groningen, the first great gas field of Northern Europe in the Netherlands. Groningen gas naturally contains an unusually low methane content and quite a lot of nitrogen. The upshot is that most Dutch appliances - boilers and gas cookers - are designed to work with this low-calorific, gas. However, the Groningen field was recently closed. Since gas from elsewhere has a far higher methane content, the Dutch network operators have had to build vast nitrogen production facilities to blend it into the imported stuff and make it “taste” a little more like Groningen gas. This is quite an expensive operation, since producing nitrogen is very energy-intensive. But given the alternative is to ask the country to buy new boilers, it was considered the least bad solution to an awkward problem of what economists would call “path dependency”. Something similar goes for the UK, where the particular flavour of the gas in the southern North Sea - the gas that really started Britain’s era as a hydrocarbon producer - happens to be pretty lean and dry. When the powers-that-be began to lay down Britain’s national gas grid in the 1960s and ‘70s, they did so with that flavour of gas in mind. Even today, the UK gas network (or rather, the boilers and cookers plugged into it) is designed for a very particular flavour of gas, with a very particular calorific rating. If one of the LNG tankers coming into Isle of Grain to unload gas from Algeria were to send that gas straight into the grid, it would raise the risk of something bad happening: older cookers leaking carbon monoxide, sooting up, and generally not working properly. And so in Britain this foreign gas also has to be treated to bring it into line with British standards. Surprising as it might sound, this is the single most energy-intensive process at the Isle of Grain terminal. Given LNG is already considerably more carbon intensive than the sort of gas you pipe directly from a gas field into your system, this sort of thing matters. It matters all the more today, and will matter still more in the coming decades, since one of the consequences of the rapid decline of North Sea oil and gas production is that Britain is coming to depend on LNG imports even more than in the past. To put it another way, if the only thing you cared about was carbon emissions, you could make a strong case that the green thing to do is to try to squeeze as much gas out of the North Sea as possible. This will sound counter-intuitive for many people, but it is the logical consequence of the energy transition. Even in the best-case scenario, it will take decades to reduce Britain’s dependence on gas down to a level consistent with net zero carbon emissions. As Material World readers know, there are some fossil fuel processes that can be relatively easily decarbonised (electric cars are a genuinely decent, by many yardsticks superior, substitute for petrol ones, for instance). But when it comes to other things: the production of fertiliser for instance, or the grid-scale intermittency support we need for when the wind isn’t blowing and the sun isn’t shining, the greener alternatives aren’t quite there yet. So while the amount of gas Britain is consuming is going down, and will continue to go down as more people buy heat pumps and more renewable power becomes available, we still need rather a lot of it. And so the question of where that gas will come from is rather important. Especially since, well, as you already know, not all gas is alike. And since Europe has now committed to importing less gas from Russia, that means more gas shipped in in the form of LNG from elsewhere. And since LNG is far more carbon intensive (even before you get to the extra steps to convert and blend that gas into a form palatable for the UK grid), that means more pollutive not to mention more expensive gas. All of which raises two questions (well, actually plenty more than that but let’s stick to the two biggest ones): first, is there really much more gas left in the British half of the North Sea and, second, what does this all do to Britain’s net zero commitments? Let’s take the second question first, since this gets to the knotty, uncomfortable reality. If you presume that the world is really committed to net zero and that carbon emissions are going to fall everywhere in the coming years, consistent with a glidepath to 1.5 or 2 degrees of extra global warming, then you could make the strong case that more North Sea gas production will be better for the environment than gas from elsewhere. Why? Because more domestic gas production in the UK means we have to ship in less LNG from elsewhere and since LNG takes a staggering amount of energy to liquefy and ship (you need to reduce the temperature of the gas to -162 degrees celsius - this is challenging physics), it is surely more efficient to produce the gas domestically and just ship it through the existing infrastructure. But while this would mean lower global emissions it would nonetheless mean more of those carbon emissions happening in the UK than elsewhere. From the perspective of carbon emissions, this ought to be entirely irrelevant, after all the atmosphere couldn’t care less which country is pumping more CO2 into it than the other. However, politicians (and the various climate frameworks they’ve signed up to) fixate instead on domestic carbon emissions. So, yes, by this yardstick, more North Sea drilling would be bad for the UK’s domestic emissions and humiliating for the politicians who promised to reduce it at a particular speed. Photo: Patrick Hutton However, more germane and I think a more serious objection to more North Sea drilling comes back to something else, something a little less about physics and thermodynamics and a bit more about the gloopy world of geopolitics. If you believe that Britain has a leadership role in global climate politics - and given this country has pushed towards net zero faster than any other developed nation that seems like a fair notion - then actually the decision over the North Sea is of outsize importance. It is, you might say, not just about the North Sea. If many other nations see that the country that led the push towards net zero is now committing to a different path, might they follow suit? In other words, might the very act of promising more North Sea drilling send a signal that changes the global trajectory of carbon emissions? If so, that completely topples the logic I’ve laid out above. It would mean more domestic gas production in the UK actually raises global carbon emissions rather than cutting them. So, this isn’t exactly simple. So how about the other issue, the question of whether Britain actually has enough gas to exploit in the first place? The conventional wisdom, as you will know, is that the North Sea is a “mature”, “declining” basin, which is hard to disagree with. The question is whether this means, as many assume, that its path of decline is somehow set in stone. And it so happens we have a rather helpful natural experiment right across the international maritime border in the form of Norway. One of the people we spoke to in the course of making our film was Wood Mackenzie, the leading oil and gas consultancy who arguably know more about the prospects for the North Sea than anyone else. And one of the charts they showed me showed the starkly diverging paths between UK and Norwegian oil and gas production. While UK North Sea output has declined rapidly since the peak in 1999, in Norway output peaked in 2004 and then, critically, stayed relatively high. The lines on that Wood Mac chart diverged. Anyway, one of the great things about AI is that it enables you to make pretty good websites pretty easily, so in the following weeks I used Claude to make a site pulling the publicly available data on oil and gas production in the various UK and Norwegian North Sea fields, and the end result was a rather helpful website. You can find it here. I’d encourage you to look at the numbers yourself (and do let me know any thoughts that occur in the comments) but one striking thing I found is that for all that we are often told that the UK section of the North Sea is simply more “mature” than Norway’s, implying that we have “withdrawn” our share of oil and gas earlier, actually when you tot up the total cumulative output of each side of the basin (see the chart above, right), it turns out Norwegian output has now overtaken the UK. In other words, this isn’t just about maturity, it’s about something else. Either the UK’s side of the North Sea simply has less oil and gas available, or this comes down to politics and economics, down to the differences in the way Norway runs its side versus Britain. I’m not sure there is yet a definitive answer to this question, but it seems like a reasonable one to ask. Would the UK, with a regime similar to Norway, be able to produce as much oil and gas as Norway? These are questions that most politicians have sought not to ponder in the past decade or so. But they are relevant all over again. And they are relevant not just for the UK, but because many people see the North Sea as a sort of test case for the future of the industry - not to mention for global climate policy. Anyway, do watch the film we made, which has far more detail on all of this, Do check out the maps and charts and be assured, this is an issue we’ll come back to again soon. A reminder that if you pre-order my forthcoming new book Trade World between now and Sept 2 and email me at [email protected] attaching a proof of purchase, I will send you an exclusive essay containing bonus material that didn’t make it into the final edition of the book. Material World is a free newsletter, mostly about topics relevant to my recent book, of the same title, and my next book, Trade World. If you enjoyed this post, please do share it with friends. And if the above whets your appetite, please do order a copy of Material World or, even better, pre-order Trade World. And let me know what you think! Buy Trade World © 2026 Ed Conway 548 Market Street PMB 72296, San Francisco, CA 94104 2
ProDave Posted September 18 Posted September 18 55 minutes ago, sgt_woulds said: But while this would mean lower global emissions it would nonetheless mean more of those carbon emissions happening in the UK than elsewhere. From the perspective of carbon emissions, this ought to be entirely irrelevant, after all the atmosphere couldn’t care less which country is pumping more CO2 into it than the other. However, politicians (and the various climate frameworks they’ve signed up to) fixate instead on domestic carbon emissions. So, yes, by this yardstick, more North Sea drilling would be bad for the UK’s domestic emissions and humiliating for the politicians who promised to reduce it at a particular speed. Some common sense explained well at last. Will be totally ignored by politicians and the green lobby who will ensure we take the worse path for CO2, importing more LNG because it is "wrong" to drill any more. 1
Beelbeebub Posted September 18 Author Posted September 18 2 hours ago, sgt_woulds said: It was due to the exploitation of the British Labour force and ideoligy of the Neo-Liberal government mindset that hated the idea of a nationlised industry that they couldn't divert money from. They didn't consider national security in their energy policy, other than stockpiling coal reserves so they had breathing room to crush the 'rable rousing unions'. Then they sold off another national asset (North Sea Oil and Gas) to be exploited by private companies and used the 'environment' as an excuse. I'm sure others here can provide their own more nuanced version of events... 🙂 Just some context The average age for a miner in 1980 was in the region of £115 a week (excluding any other perks like free coal) This was towards the upper quartile of manual workers wages and about 50% of all workers wages.
saveasteading Posted September 18 Posted September 18 3 hours ago, sgt_woulds said: stockpiling coal reserves so they had breathing room to crush the 'rable rousing unions Sad to say I was part of that, working for a contractor to double all water storage at pits. Huge expense for very short lived infrastructure.. Scargill proofing we found out later it was called. 3 hours ago, sgt_woulds said: sold off another national asset (North Sea Oil and Gas) to be exploited by private companies Watch Simon Reeve series "Scandinavia" to see what Norway did instead and the national wealth amassed.
SteamyTea Posted September 18 Posted September 18 2 hours ago, saveasteading said: Norway They have a population of 5.6million, so much easier to manage. They also lived with a huge political system threat next door for a couple of generations. Substitute Norway for Piddington and you may start to understand how a 'common enemy', can help any cause.
saveasteading Posted September 18 Posted September 18 6 minutes ago, SteamyTea said: Substitute Norway for ....Scotland and we see why the huge sums involved were made secret and only revealed in the 10 year release of documents from parliament. Harold Wilson demanded it was not revealed or "they" will vote for independence. 1
Beelbeebub Posted September 18 Author Posted September 18 9 hours ago, sgt_woulds said: You will know, if you’ve read Material World, that there are many different flavours of oil: sweet and sour, heavy and light, gloopy Canadian tar sands and light, clear fracked crude. You will also know, if you’ve read much of my subsequent stuff here, that such things actually turn out to have outsize, sometimes geopolitical significance. But did you know that something similar also goes for natural gas? When it first comes out of the ground, natural gas can also be sweet or sour, depending on its sulphur content. It can be wet or dry, depending on how many other liquids have come up in the pipes alongside the gas. This bit was very interesting. One thing that struck me, reading this, is that electrons aren't sweet or sour. They aren't dry or wet. Your car or heatpump will run just as well on electricity from a coal plant as a wind turbine as a nuclear plant. Again though the point regarding the UK North sea is that it still won't make much difference to any of the metrics CO2, energy prices, energy security. At least as long as the gas is extracted by private businesses and sold on the international market. *If* we are taking about some sort of nationalised gas company that extracts the gas and provides it exclusively for UK requirements (either electricity, domestic heating and/or industrial use) *then* there may well be benefits in those areas - particularly energy prices and security. However I am 99% sure the above is not what the lobbyists pushing for more North sea drilling have in mind....
sgt_woulds Posted Monday at 10:20 Posted Monday at 10:20 On 18/09/2026 at 19:38, Beelbeebub said: *If* we are taking about some sort of nationalised gas company that extracts the gas and provides it exclusively for UK requirements (either electricity, domestic heating and/or industrial use) *then* there may well be benefits in those areas - particularly energy prices and security. However I am 99% sure the above is not what the lobbyists pushing for more North sea drilling have in mind.... Exactly. We'll never have a Norway model or a National Wealth Fund as the capitalist mindset is too deeply ingrained in British politics, even amongst allegedly socialist parties. Paying the bills today, is far more important to politicians than squirreling away a fund for the future prosperity of the nation. Just wait until a certain 'Ltd company' oversees UK politics - money and oil will flow, but not towards any sovereign fund. Any thoughts of ringfencing this for the carbon win - let alone any percieved taxpayer benefit - is just pie in the sky. 1
saveasteading Posted Monday at 11:17 Posted Monday at 11:17 50 minutes ago, sgt_woulds said: not towards any sovereign fund. Does anyone know if Ineos profits would remain in the UK or disappear to Monaco like its owner? 15 billion isn't enough to afford that he pays tax. Ratcliffe says the UK is a mess and something ought to be done about it. He had no suggestions at all other than allow oil, by his company of course and lower taxes for his like. There is some comfort in seeing how utterly miserable he looks in interviews and when Man U lose.
Beelbeebub Posted Monday at 16:13 Author Posted Monday at 16:13 5 hours ago, sgt_woulds said: Just wait until a certain 'Ltd company' oversees UK politics - money and oil will flow, but not towards any sovereign fund. Any thoughts of ringfencing this for the carbon win - let alone any percieved taxpayer benefit - is just pie in the sky. Interestingly enough one of the ways I "discovered" the facts around how little the north sea has left was certain politicians from a certain "party" (ltd) talking about how it would lower bills and ensure energy security. I believe the phrase "Saudi Arabia on Thames" or similar might have been uttered. So I thought I'd look into it and lo-and-behold the politician was full of shit. I don't doubt the UK could have (should have) done things very differently. I do wonder if the volumes extracted and still to extract would be the same with a different approach to exploration and extraction or is it just the Norway had more to start with? <Shrugs> But we are where we are and whether or not Rosebank and jackdaw get licences or any others get granted won't make any difernqble difference in our finances, security or carbon emissions. What will help is reducing our reliance on a product we need to buy on the world market in competition with all the other countries using it around the globe.
Beelbeebub Posted 3 hours ago Author Posted 3 hours ago https://www.theguardian.com/business/2026/sep/24/eu-trump-diesel-export-ban-fuel-prices-europe At this rate banning sales of ICE cars from 2030 won't be necessary as nobody will be able to run them....
Roger440 Posted 1 hour ago Posted 1 hour ago 1 hour ago, Beelbeebub said: https://www.theguardian.com/business/2026/sep/24/eu-trump-diesel-export-ban-fuel-prices-europe At this rate banning sales of ICE cars from 2030 won't be necessary as nobody will be able to run them.... I can imagine how pleased you would be...............
