Pocster Posted January 20 Posted January 20 After an eventful and almost pointless exercise in trying to get any cheap esp32s3 board and screen to work due to poor/no documentation Zillions of boards Even the same model number from the same supplier can be different! e.g. they change the touch screen chip! Lvgl 8/9 variations Toolchain issues e.g. espriff say use their tools - but they don't work always Absolute minefield of shite - no wonder the CYD are so cheap So I gave up and went for something that would work .. the M5stack Cores3!! So first screen is the % of water in the barrel ( this it gets via HA from a standard esp32 with a ultrasonic transducer and mqtt) Backdrop is animating . Wifi symbol to show if connected or not. 2nd screen choose minutes 2/4/6/8 ( some graphics to finish ) Plays a pcm audio e.g. "2 minutes selected" 3rd screen Timer countdown. Uses mqtt to tell HA to turn on the shelly outdoor wifi switch to the pump Some graphics need to be altered ( different background I think - though 8MB PSRAM fills up quickly ). I also added some pc audio that's triggered randomly and says things like "Get (expletive deleted)ed" I thought it was funny ; SWMBO less impressed!! Most the code with quite a lot of effort on my part done with ChatGPT. Before you all jump in and shout Claude is better - I know it is. But I need a lot of tokens!. I enjoyed this project even though as an ex games programmer I made the tiny UI all game like! More projects planned - using chatgpt to accelerate my learning and let its code be sometimes questionable... I've got 2 more cores3 which I want to put above 2 other water barrels i.e. simply to show how much water is in them each - no touch/actions required. Then a compute module 5 with QT to replace my annoying Android home assistant web dashboard!
Pocster Posted January 20 Author Posted January 20 Suppose really this thread should be in the networking/automation section ....
Alan Ambrose Posted January 21 Posted January 21 Neat Can I ask about the transducer - is it reliable & accurate? I need some set-ups where I control a pump based on water depth in a sump…. 1
Pocster Posted January 21 Author Posted January 21 17 minutes ago, Alan Ambrose said: Neat Can I ask about the transducer - is it reliable & accurate? I need some set-ups where I control a pump based on water depth in a sump…. Yes its pretty good ! The results from it were a bit jumpy so I got chat to average out readings . This is the unit . For my needs of simply scaling water in a barrel 0 - 100% it’s accurate enough - I would say a 2/3cm error margin .
Pocster Posted February 6 Author Posted February 6 (edited) Today’s tasks were tiling or fun stuff . SWMBO is out so unsurprisingly fun stuff won ! Swapped to an esp32 lite atom . So small . Attached ultrasonic transducer - all seems good . The 2 holes ; ultrasonic lead and usb psu . Couldn’t find grommet connectors for usb lead where it fits through and they tighten for a waterproof connection . So just pumped both holes with ct1 😉 Discoverd these ‘ things ‘ you slide over a wire . Twist two wires together , move the sleeve and heat ! . Soldered joint and heat shrink in one ! I then heat shrank ontop . Tomorrow once ct1 is dry will do a test deploy outside I.e fix to a wooden batton and put it across water barrel opening . Edited February 6 by Pocster
Pocster Posted February 10 Author Posted February 10 Tried and failed with m5stack audio hat . Complete shite . Headphone socket suggesting audio out as would expect . But routes completely different from internal speaker . Couldn’t get it working - tried every example and ChatGPT , best was crackly shite . Swore a lot than wired an amp off gpio . Works but forgot how microscopic everything is !
Nickfromwales Posted February 10 Posted February 10 Does it need to be so complex, and does it need to be proportional? https://www.flowfitonline.com/products/electric-floating-level-gauge-no-nc-with-1-switch-contact-l-400mm?gad_source=1&gad_campaignid=21794319016&gbraid=0AAAAADzzHCEY_4iDYCgXisebrdUdhSWTm&gclid=Cj0KCQiAy6vMBhDCARIsAK8rOgk-rdyVGK0LD4-SkDkY2XZI24iZ0BafQP_MQK02LpIHahQhGC0SI8YaAhekEALw_wcB Cheaper ones about, just a random grab. @Alan Ambrose, 2 of these maybe, at different heights, and a dual pump setup may be better (simpler and more reliable)? 1
-rick- Posted February 10 Posted February 10 Just now, Nickfromwales said: Does it need to be so complex, and does it need to be proportional? I think @Pocster wants to do it for the 'fun' of it. Maybe mistress is away? 1
Nickfromwales Posted February 10 Posted February 10 18 minutes ago, -rick- said: I think @Pocster wants to do it for the 'fun' of it. Maybe mistress is away? No doubt, lol.
Pocster Posted February 10 Author Posted February 10 Oi (expletive deleted) buddies ! We do this because we can . Also other uses for said technology.
Pocster Posted 12 hours ago Author Posted 12 hours ago Deployed ! Loads of issues with the 3d printed case . I’ll rethink that .
Gone West Posted 10 hours ago Posted 10 hours ago 2 hours ago, Pocster said: Loads of issues with the 3d printed case Is that a 3D printed transparent cover on the box? I didn't know you could print clear plastic. 1
Pocster Posted 8 hours ago Author Posted 8 hours ago 2 hours ago, Gone West said: Is that a 3D printed transparent cover on the box? I didn't know you could print clear plastic. No . The box is bought. The internal white support thing to house cores3 , speaker , amp etc - needs redesigning 1
SteamyTea Posted 7 hours ago Posted 7 hours ago 5 minutes ago, Pocster said: My cad skills limited Learn from the Master.
Onoff Posted 7 hours ago Posted 7 hours ago On 06/02/2026 at 16:26, Pocster said: Couldn’t find grommet connectors for usb lead where it fits through and they tighten for a waterproof connection . Print in tpu.
Pocster Posted 5 hours ago Author Posted 5 hours ago 1 hour ago, Onoff said: Print in tpu. Ain’t got any . Using abs
