The problem with all these comparisons is you are comparing the prices from the builders merchants
if buying EPS you can deal with the manufacturer, pir manufactures won’t deal with you.
I got my EPS100 at a third of the price of pir.
45 minutes ago, saveasteading said:
wonder how much the temperature at 1m depth drops by the end of winter.
By the new mean yearly temperature. Ground at a metre depth is generally about the mean yearly air temperature.
But as I mentioned earlier, it is more complicated than that.
Regarding the perimeter losses, a fairly accurate way to compensate for it is to work out the periphery distance, multiply by the square of the slab/insulation thickness. This will give you a volume i.e. 20m3.
Spread that volume over the floor area i.e. 0.2m extra thickness over 100m2.
That will compensate for the finickity losses.
Alternatively add extra insulation outside the thermal envelope around the perimeter.
The Kore slab system, if I remember correctly, has that built in as part of the design.
I have been buying my insulation from https://www.insulationsuperstore.co.uk/
I have had multiple deliveries from them, at least 10. I have purchased rock wool and PIR only once did the delivery come on a huge truck most came on a small van and the drivers were very friendly, delivered from SIG or Markovich, with good delivery communication. The Rockwool I purchased by the pallet, the PIR by the sheet mixing my order 80mm and 100mm and spending the minimum for free delivery which meant I was not stacking rooms full and risking damaging corners. I was often getting discount codes or used my account points to get money off never paid the full price.
I meant after a winter of the ground source pipes removing the therms.
They look like this but with arms and legs: image.png.c6dbaec207b0c67b40dd25bf172b7c9e.png
That needs an Ancient  Greek letter.
You mean deeper to the perimeter? It makes sense to have deeper insulation round the perimeter, and shallower to the middle, but that isn't happening. It's just going to be a less efficient area of the building, balanced by the centre of the slab being over-insulated.
Perhaps PIR to full depth around the perimeter and 2 layers eps centrally is the pragmatic (and finicky) decision.
It is intuitive rather than proven, but I'm confident I could write a page of 'proof' for the building inspector if it was necessary... but it isn't and will just be our decision.
A bubble.
I think it is proven, but may have to ponder it a bit more.
Then do a bit of modelling.
Thermal losses can be quite accurately modelled using the cube root of the sum of 3 dimensions, 4 dimensions if you want to add in time.
Or use a Fourier multiple sine wave calculation, but I never intuitely understood that.
They have the best of the quoted prices online at present, along with Insulation Wholesale.
Some others say they will match any quote but I resent that attitude and will tell them that they must quote their best price first as I don't give second chances. If they are too scared to do that then I don't fancy their service or security will be great either. What is the point of matching another quote unless their is some other benefit?
@Susie was this recent?
Or use a Fourier multiple sine wave calculation, but I never intuitively understood that.
This is getting into science fiction. I need a lie down.
What is the cube root of time anyway?
Or is it a way of proving that  that entropy isn't what it used to be?
It is, by definition, not what it was.
21 hours ago, saveasteading said:
I'm aware of that but reminders are no bad thing.
I wonder how well a soft packaging eps would fare beneath 100mm or more of PIR and a grand piano on top. perhaps with a big enough dish under each wheel it would be ok.  This is whimsical: I am not saving amazon packaging to try it.
Interesting!
In SE terms. For fun let's take a grand piano. That weighs about 550 kg and has three legs. Thus about, say 183 kg per leg. A "20 -22 stone" rugby prop can in the modern fast game can be 110 kg, but say the team just needs dead weight, so take the prop as 140 kg. Not far off the load from a grand piano leg. But the piano does not walk about, the prop does so lets add a bit of dynamic load to their foot fall. Say 20% thus 1.2* 140kg  = 168kg. And all of a sudden we realise that locally on a screed a big lad has something to say and a point to make!
Welcome @rjclark71 to BH!
To delve into @saveasteading question do we put EPS on top or below the PIR? In this case we are looking at a ground bearing slab that is not supported by (at the edges) or transferring load to the perimeter foundations. There is a cement based screed with underfloor heating pipes (UFH) embeded in it.
Now we have a point load ( a piano has a larger foot than a shoe, take the shoe heal as this load is more concentrated. The load from the heal of the shoe gets spread out at roughly 45 degrees down through the screed and onto the first layer of insulation. It then gets spread more down through the insulation thickness. Therefore the compressive stress gets less the deeper you go as the load is spread out more. In conclusion it makes sense to put the weaker insulation on the bottom as the loads are more distributed.
Yes, but does the floor screed move or crack under the foot of Xander Fagerson?
And will the tv packaging be strong enough?
Still ongoing. Hope to put my last insulation order in soon.  The points you get can be used across all the group sites but I haven’t purchased much more on the other sites.
On my phone but quickly. He went to Strathallan so his weight may be under estimated..
Yes technically the screed will crack further. The screed had no residual tensile strength due to the UFH pipes. So it really works in direct beating  only.
On balance the packaging is likely not suitable.
The screed has a small aggregate and thus aggregate interlock is less reliable. But the shrinkage still remains.
Presumably that data is for open ground.
Under my slab will, I imagine, be rather different.
It’s dry ground, no watercourses or the like.  So what temperature should I use for my heat loss calculation for the underfloor insulation?
(This particular horse has now bolted, but it’s still of interest.)
1 hour ago, Russell griffiths said:
zoom in.
It's good enough to find them. Thanks muchly.
S and B EPS.
Their website is comprehensive on strengths and insulation, and some other products. But nothing on where to buy or costs, so I've sent them an email.
Strangely the strength and insulation vary by thickness, presumably a manufacturing density thing. And they make consciously stronger stuff too.
k = 0.036 average.
2 hours ago, saveasteading said:
k = 0.036 average
41 minutes ago, dpmiller said:
graphite EPS takes it to 0.031
Not really that much difference.
When fitting this stuff to walls, does it self support between studs or need some help?
Otherwise fixing ply or other  to the all room perimeters is a pain and a large cost for something that is working for a couple of hours.
i'll get it as 100mm probably.
the screed looks like being between generally 55mm ish, but from 45mm to  85mm due to some extreme wobbles in the floor.
For most rooms I can vary the insulation thickness but the biggest room has the biggest variation.... of course.
Or maybe we first pour some latex in the low points.... is that much cheaper than screed though? (screed seems to be £600/m3 or more.)
Currrent logic is to have 100mm PIR on top of eps, which will be variously 100/125/150 according to the slab level.
Thus the screed top level will be a set level but the thickness will vary at dips and humps.
It's a right fiddle but worth about £4,000 to optimise screed and use eps instead of pir.
That's a good few day's survey, research and analysis by my book.
For context this shows the construction. So to the external face there will be a pir edging onto the block face. The finished floor is at the top of the block. Elsewhere the construction is all stud.20260101_150748.thumb.jpg.a5415b5512485e86a301efdb861798a9.jpg, and no facings yet. Obv we don't want to flood screed through the walls.
Btw that is the offcut pile from several 100 metres of stud.
Just use staples or short clout nails.
